Question about Lexmark X4580 InkJet Printer
Printer keeps saying busy printing another document
I keep getting an error message saying printer is busy printing another document and it is not.
  • Official Brand Answer
  • 3,344 Answers
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Posted on Feb 14, 2012
checkitright
  • 1362 Answers
SOURCE: lexmark x1180 printer all in one
Clean the contacts on the cartidge and printer ( open the replace ink door wait for the printhead to come to center and turn off power) if that does not work then replace cartridge, it might be a recycled one that they did not chane the chip.
Posted on Oct 11, 2007
SOURCE: printer cover open error message
Thanks but this suggestion didn't work.
Posted on Jan 04, 2008
SOURCE: Lexmark X125 keeps saying cover open change cartridge
try to make sure that the clear "ribbon" is situated correctly inside the unit, otherwise it will not communicate correctly with the moving electronics in the cartridge tray
Posted on Mar 11, 2008
LuckyJackson
  • 72 Answers
SOURCE: printer wont print at all. error message is 50C.
Hi Try These Solutions:
its quite simple really just turn off your printer then unplug it remove both cartridge's get like a wet baby wipe or something similar let them sit on it for @ 10 secs then just real easy wipe the front piece as well take the same wipe and wipe the heads in the printer well sort of dab them dont wipe let dry for @ 10 secs put them back in (note you will need to move your cartridges over to where load position by hand to and back) run a cleaning test then align test , then print a test page and wah lah works on every one i ever had to do . sort of fix the things u know. have fun hope this eases your day or better. merry christmas to all and to all good night in essence what has occured is the cartridge got shorted and has dried at the surface as well. try it any other tips you need well ask but not to many thats why i quit giving tips like 15000 email a week blow your mind apart
or
Well, I did all that but no dice. But then I noticed that the "protective" tape on the new cartridge had left sticky junk on the cartridge -- but NOT on the print heads, just on a regular part. I got rid of the sticky stuff and voila!
Posted on Jul 07, 2009
komguy
  • 2306 Answers
SOURCE: 4650 printer. New printer. We keep getting
Check your color ink by dabbing on a damp paper towel, you should see 3 distinct lines, one for each color.If any color is weak or missing it will never pass alignment and you need a new cartridge.
Posted on Jan 29, 2010
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Why do I keep getting an error message when I try to print on plain paper?
try to check your document paper size settings. if your document is in pdf format, try to unchecked the select paper size automatically but it will not respond since it is dependent on the paper size setting of the document.
Jul 17, 2014 | Ricoh Aficio SP C811DN-DL Printer
I'm getting an error code Illegal attribute value on my hp 4050 printer
Nothing to worry about. It just means that you have printed a page or pages that all the trays do not have the correct paper size. Say your trays all have A4 papers and you printed a PDF document (US letter size) downloaded from America. Printer prints the page, then print another page with your error message just to tell you your pages do not match the papers. This is HP PCL6 code. A Postscript printer driver will just refuse to print if page size mismatches and keep the user wondering why.
To avoid the message, just make sure that your documents have the same page settings as papers in your printer trays.
Nov 26, 2013 | Computers & Internet
Whenever i try to print it does 1/2 page then the cartridge keeps getting stalled on one side. Error message on screen says print cartridge stalled, error message on printer says clear carraige jam. Cannot...
If there's a carriage jam. While the printer is turned on, Open the access door of you printer.
If the carriage is stuck at the left side, try moving it manually by hand to the right most part of the window. If it's stuck on the right, try moving it by hand to the left.
If you've already done that. While the printer is turned on, unplug the power cord from the back. Close the access door. And then plug it back in.
Make sure you restart the computer first just to avoid documents getting stuck in the print queue. Try printing again. Usually it does the trick.
Feb 03, 2011 | Office Equipment & Supplies
My printer keeps saying this document failed to print before it prints or half way through the job
When I go to print a document it feeds paper through without printing anything ... my x63 keeps saying clear system error then press clear. ...www.fixyourownprinter.com/forums/inkjet/13953
Dec 06, 2009 | Epson Stylus R265 InkJet Photo Printer
Printer wont print (colured ink low) canon ip1600
TYPE IN ON ADDRESS BAR OR MENU
CANON PIXMA IP1600 PRINT ERROR 5200
ENTER
ROD
Feb 09, 2009 | Canon PIXMA iP1600 Printer
Print head error message
reset it in window printing menu. perhaps it works.
Dec 03, 2008 | HP Business InkJet 2800 Printer
Printer keeps saying insert memory card
The message is not an error message and does not indicate an issue with the product. The message is designed to be an invitation to print photos from a memory card. Follow these steps to insert a memory card into the product. For more information please check the link bellow: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01436439&cc=us&lc=en&dlc=en&product=3194498 Good Luck
Aug 21, 2008 | HP Photosmart C6280 Printer
Canon i320
Try unticking ENABLE BIDIRECTIONAL SUPPORT on the Ports Tab under Printer Properties accessed through control panel / Printers and Faxes. Try to print - get error message Enable Bidirectional Support. Reverse back into Ports Tab and re-enable Bidirectional Support and try printing again.
Jan 13, 2008 | Canon BubbleJet i320 Printer
FRAGO DTC550 ID MACHINE
The is usually resolved by replacing the head lift motor or sensor.
Dec 17, 2007 | Fargo DTC550 Thermal Card Printer
Lexmark X4580 InkJet Printer Logo
264 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
