Question about Coffee Makers & Espresso Machines
Why do I get worms in my solis palazzo coffee machine?
Richie_asg1
  • 1036 Answers
SOURCE: Solis Palazzo - Coffee grinder seems blocked
Hi there!
This is most likely due to a build up of ground coffee at the edges, and the whole lot has become a solid lump.
Disconnect the machine and clean with a small stiff paintbrush.
This is caused by damp beans, or using dark roast beans, or keeping beans refrigerated. Often it is the coffee oil that causes it.
If there are beans in there and the unit is not rotating, please contact here again.
Thanks......Oh, and rate as Fixya! if it helps you.
Posted on Jun 19, 2008
erguel
SOURCE: Solis Pallazzo espresso machine - need maintence manual
Hi, check under: http://www.solis.ch/franzoesisch/kundendienst/kundendienst_f.htm
and choose your machine, under E (english) column, you'll get the pdf.
Posted on Feb 01, 2009
  • 1089 Answers
SOURCE: Solis Palazzo coffee coming out weak & cold,
HI
There could be other things wrong but usually when the water temp goes down, its because you are starting to get scale build up in the boiler. This insulates the water from the heat. What do you have your water hardness set on. It should be set on the max, with all the lights lit. Check it by pushing and holding the small cup and water buttons. While holding them down, turn on the machine. Release the buttons and your ready to program the machine. Water hardness. The pre-ground button sets the water hardness. Push the pre-ground button (scoop) and the lights at the top of the panel should light up one at a time from left to right.. Always set the hardness to the max. Turn on all the lights on top. The machine will tell you when to descale. It’s better to descale more often than not enough.
Descaling the Palazzo: The Palazzo is programmed to descale the boilers on its own, when set in the correct mode. You program the machine to descale it’s self, do the following. With the machine turned on, push and hold the left 2 buttons (clean and pre-ground). This should light the top right red indicator light. Mix your descaling crystals in 32 to 48 oz in your water tank. Stir until they are completely dissolved in the water. Next, have a container that can handle about 2 quarts of water under the steam wand, or have the machine positioned next to a sink. Next open the steam knob on the right side of the machine. You should hear the pump turn on and pump about 2 to 3 oz’s. of water through the wand into the container. The pump should turn off and there will be a wait of about 2 minutes. The pump should turn on again and more water will come out. It will do this until it has completely drained the water tank. Do not interrupt this cycle until the machine has stopped on its own. When it does stop, all lights on the bottom will flash. Rinse out the water tank and refill with fresh water. Place the water tank on the machine again, and then close, and then open the steam knob again and let the water just flow through the boilers until it is emptied by the machine. Don’t turn off anything until the machine stops on its own. This will clear the descale light. Refill the water tank again with fresh water and your ready to go.
Posted on Nov 05, 2009
SOURCE: I have a Solis Palazzo machine. My question is:
The first coffee out of the Solis Palazzo in the mornings will always be cooler. Temperature is lost in the brewing unit and internal pipes the coffee passes through. Try making a decaf with no coffee to pre heat brewing unit internally or throw out the first cup of coffee.
Also try pre heating cups, the difference between a cold cup and hot cup can be as much as 10 degrees celcius.
Posted on Jul 27, 2010
  • 1089 Answers
SOURCE: Solis Palazzo : turn on
Hi
This is for a Vienna but it should work for you Palazzo. It will help you get the brew group out and reset so you can reinsert it.
http://www.fixya.com/support/r2296970-brew_group_stuck_t_get_out
Posted on Aug 04, 2011
Solis Palazzo : turn on machine the brew group does not position it self to prepare coffee.powder coffee, coffee, and espresso lights blink. Brew group is not removable from machine. machine has had light...
Hi
Aug 04, 2011 | Solis Palazzo Espresso Machine
While coffee is moming out,water is coming out as well underneath the machine and the steamer Steamer doesnt work. While trying to use the steamer, i noticed that steam is eveyrwhere. How can i fix this...
http://www.juraprofi.de/Solis-Ersatzteile/Dichtungen-O-Ringe/Solis-Dichtung-fuer-die-X100-Bruehgruppe::9015.html
Try this piston seal, it should fix it?
Jan 22, 2011 | Solis Palazzo Espresso Machine
HI When was the last time you descaled? This can have a temp lowering effect if you don't descale on a regular basis. Program you water hardness so its set on 4. This will tell you when you have to descale. Descals is not the same as cleaning. Its a special acid that disolves the deposits inside the boiler.
Jul 24, 2010 | Solis Palazzo Espresso Machine
Brewer part for solis palazzo
Hi
What part do you need? I have some.
Jul 05, 2010 | Solis Palazzo Espresso Machine
Needs repair
Hi
Where do you live?
Apr 01, 2010 | Solis Palazzo Espresso Machine
Aug 30, 2008 | Solis Palazzo Espresso Machine
Standby
I turn mine on in the morning and off at nite.
Oct 20, 2007 | Solis Palazzo Espresso Machine
Coffee Makers & Espresso Machines Logo
575 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
