Potterton wiring diagram - Heating & Cooling
  • Heating & Co... Master
  • 2,557 Answers
Look on the baxi potterton wedsite you can down load mauals for your potterton or e-mail there tech line .
Posted on Feb 11, 2012
How can I download an installation guide for potterton ep6002 programmer
Unfortunately unless you are trained as an installer of Potterton equipment you will not be able to get any advice from Potterton, they don't even supply direct to trade, everything is supplied through nominated suppliers, ie; Plumbers merchants.
This programmer should be quite easy to install I would have thought, in general all remote programmers have a mini wiring diagram on the back of the unit, though this will only show connections for the programmer outputs, ie heating on/off and water on/off.
If you require a wiring diagram for a complete heating system, you need to know the type of heating plan you have/are installing.
Hope this helps, if you need any more info get back to me.
I have just googled this and you can actually purchase from Amazon (not that I would do myself, I would use the merchants) there is a wiring diagram on the site. Just google Potterton EP6002, it comes up straight away Good Luck
May 23, 2014 | Garden
Install guide for ep6002 programmer
It would probably be best to contact Potterton or Baxi Potterton
at the email address: enquiries@potterton.co.uk
www.potterton.co.uk
Potterton Myson, send all enquiries to Baxi Potterton
I only found one PDF file online and it was a general book that showed how to wire most of the wire systems and controllers.
http://atibook.com/dl/en/Others/Tutrial/9780750664363_domestic_central_heating_wiring_systems_and_controls.pdf
Need diagrame for potterton composite gas valve 402923
Look on The Baxi Potterton wed site you can down load manuals there or ask there tech line
Nov 07, 2012 | Heating & Cooling
Replacing an ST699 with a ST9400C following repl wiring diagram, but programmer does not come on. Is the diagram incorrect? Wiring colours do not follow any of the plans. Syst has room stat, cyl stat,...
Disregard wire colors. Instead wire by terminal designation. In other words :
Wire on "R" Terminal on old thermostat to "R" Terminal on new thermostat no matter the color.
Jun 14, 2011 | Honeywell Heating & Cooling
Hi. We recently moved to a rented property. We have a ST7100 Central heating and a Potterton Profile 50e boiler. However even though I have set the times on the ST7100, the heating ligth comes on, but the...
You definetly have a control issue. However trying to diagnose the exact problems that you have would be very difficult without actually seeing the wiring. You defintely have a wiring/control issue but I cannot tell you exactly what it is without more info. Sorry, I would love to help you more...
Nov 13, 2009 | Honeywell Electronic Programmable...
How do i wire a potterton programable controller
All you need to do is look at the wiring diagram on the back of the old room stat, you will have the following:
(normally wired with these colours)
OLD COLOUR CODING
Live (sometimes called common) - Red
Neutral - Blue
Switch Live - Yellow
NEW COLOUR CODING
Live - Brown
Neutral - Grey
Switch Live - Black
All you need to do is wire up the new stat with this in mind. (please note: if the wires are not colour coded like this then do not proceed and get an electrician)
Any problems or questions let me know
I hope this helps
Steve
Apr 23, 2009 | Honeywell Programmable Thermostat Heater
Changing boiler programmer
take digital pictures - label all wires and reconnect - you do not need manual.
Oct 27, 2008 | Water Heaters
Changing a room thermostat a potterton to honeywell t6360
I think I've done it - but don't take this as absolute truth.
For the Honeywell T6360B the original Potterton wiring should be rewired as follows:
Brown [Live] goes to terminal 1; Blue [neutral] goes to Terminal 2 and the yellow/green [which is not an earth but a switched live - i.e. gives live to the heating system when the thermostat clicks in] goes to terminal 3.
Obviously all done with the power isolated and when it was switched back on we had heating again :o)
It's been on over two hours now and all seems fine.
Jan 13, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
722 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
