Question about Garden
What is the gas/oil ratio for a McCulloch Model MP370GL chain saw
  • 11 Answers
SOURCE: petrol to oil ratio McCULLOCH 55cc chain saw 2 stroke
25 to 1
Posted on Apr 07, 2009
  • 42 Answers
SOURCE: I have a McCulloch 10 10 Automatic Chain Saw. What is the oil to
40:1 of two stroke oil roughly 2..5% 40 parts fuel to 1 part oil mixed Good Luck the Yeti
Posted on May 17, 2009
dontbother10
  • 2220 Answers
SOURCE: McCulloch chain-saw fuel-oil ratio 3200
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 2gal premium/8oz chainsaw 2-cycle engine oil - used for many years) and finally the last 5 (±) years 50:1 (1gal premium/2.6oz Stihl 2-cycle engine oil)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few weeks. Anything over 1.5 months old use up in a 4 cycle engine. HTH
Lou
Posted on Nov 07, 2009
  • 3 Answers
SOURCE: Gas/oil ratio mixture; chain oil lubricant
Call their customer service at 1-800-242-4672 there are options to choose for gas/oil ratio mixtures info.
Posted on May 26, 2010
  • 54 Answers
SOURCE: McCulloch 14" chain saw Model CS 38 EM It quit
Most often there is a dust-oil clog in the bottom of the bar slot which closes an oil passage between the bar slot and the hole drilled half way through the side of the bar. This provides a passage between the thin shim plate with the two bar bolt holes beside the bar and through to the oil tank or pump output. You can remove the bar and chain and punch out the blockage in the bar with a paper clip if the chain is removed. Make sure the wire can be pushed from the bar slot right through the side hole in the bar. A gravity feed chainsaw should leak right out into the slot of the shim plate, a button pumper should squirt out there with the bar removed. With a button pumper you may have a tiny check valve in the line or the push button to take apart, replace the spring or unstick the ball inside the check valve. This is why they went to the gravity feed oil system which just leaks in there and gets picked up by the bottom of the links as the chain races past the passage between the bar side hole and the chain slot.
Posted on Mar 24, 2011
Testimonial: "I checked as you suggested and I removed the pump from the crank shaft and the plastic gear is stripped. Now I can not find a pump. Thanks Jim"
McCulloch chain saw What is the oil to gas ratio
50:1 - 50 parts Gas to every 1 part oil.
If you have to error one way or the other, it is better to error a little on the side of having more oil. Sears has a Craftsman chain saw 50cc that is/was made by McCulloch and it's fuel ratio is 40:1. The lack of lubrication(oil) in fuel will lead to engine damage, too mush oil in fuel can lead to low performance. Hope this helps.
Jan 20, 2016 | McCulloch Garden
Chain gas saw
If you are looking for the gas/oil ratio, McCulloch recommends 50/1 gas/2cycle oil mixture.
Oct 05, 2013 | McCulloch Mcc1635a 16-inch 35cc 2-cycle...
What type of gas do i use for my McCulloch 16 Inch Gas Chain Saw
If using an oil other than McCulloch, the ratio is 40:1. Brand Specific McCulloch two cycle oil is 20:1.
Jul 02, 2012 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
What is the oil/gas ratio for a McColloch "Titan
40:1 is the ratio for modern saws so I expect it's the same for the older ones. Use good 2 stroke oil like Husqvarna or Stihl brands rather than the cheaper stuff you can buy at car service stations which don't really protect a saw.
Jan 05, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Trying to determine gas-to-oil ratio on a chain saw.
Confirmation to #1: Recommended for all McCulloch chain saws at 40 to 1 ratio. 3 oz. per U.S. gal.
Jun 28, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
2 cycle oil to gas mixture ratio
40:1 for a McCulloch 3214.
Jun 24, 2009 | McCulloch Garden
May 17, 2009 | Garden
Garden Logo
51 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
