Question about Viking VGIC305-4B Gas Kitchen Range
Viking Range Broiler ignitor
Broiler ignitor
  • Jim Rouse Feb 10, 2012
    Need to replace ignitor. Wires go through back wall, but cannot find connector
SOURCE: burner ignitor will not turn off after the burner lights Viking
replace the electrode that's the wire or pilot tip, it has a sensor built in, when it gets hot it stops automatically. if the electrode is between the front and rear burners, there are small holes on the burners going down on the side of the burner facing the ignition. they need to be clean. try a paper clip and insert the clip in side the holes.
Posted on Dec 14, 2008
bobsteelesp
  • 22 Answers
SOURCE: Have a Viking range, gas top, electric oven, neither work.
Check connector block where electric is brought into stove for loose or burnt wires. Check Breaker in house power box. Push the breaker firmly to off and then return to On position. Read owner's manual to see if ignitor circuit has a fuse and check said fuse.
Posted on Sep 12, 2009
  • 23 Answers
SOURCE: Viking dual-fuel range ignition problem
You may have wet it somehow. There are two fixes. Leave them on for 20 minutes on high to let the ignitors dry out. If they dry and stop clicking you have solved it. If not then contact Viking 888-845-4641 and purchase a 6 point spark module. You can try to replace this yourself. With the power OFF. Remove the wires one by one placing them on the new module and then attaching it to the wall. (this is if ur spark module is located under the burners.) If it is in the rear of the unit and u can pull out your range yourself without hurting yourself then you do the same thing. Good luck. If none helps you you may need to replace all 6 burner bases or ignotrs. Also easy. Good luck.
Posted on Sep 18, 2009
  • 42 Answers
SOURCE: Gas Viking range: VGRT3624QSS four yrs. old.
check if burners are burning ok,if correct one of the spark electrodes is faulty.
Posted on Sep 30, 2009
  • 15 Answers
SOURCE: How to install ignitors on Viking Range
I am assuming your referring to the stove top burner ignitor. Well - I can only say on my Viking 48 inch - it was located at top RHS of the stove on the 'back wall'. I was advised by an 'come to my home tech' that it would be located at the back of my stove (ie he would have to pull out the built in unit and cost me 500$). In fact I replaced the unit in 30 minutes ... I removed the two RHS burners (one screw each), disconnected ignitor wires, removed the bracket holding the burners (one screw), followed ignitor wires to silver box covering the ignitor unit (2 screws), opened it & replaced ignitor. Forgot to say - 1st thing I did was turn off power & gas to the range
Posted on May 22, 2010
New ignitors in Viking range oven do not heat up
You will need to measure for 110 VAC at the control switch located on the thermostat. Pleazer Appliance...
Apr 15, 2014 | Viking Kitchen Ranges
Oven will not light ,broiler and top of range light fine
the ignitor is not working its bad,you should see a bright orange glow below the oven base just as when you start the broiler look up at the top of the oven and watch this ignitor glow before ignition,the bottom should do the same,you can also see this from the back side of the range at the base,if you don't use the broiler you can use that ignitor for the oven ignitor as these ignitors are identical,but then you will have no broiler
May 11, 2012 | Frigidaire Ovens
I have a gas viking oven and it does not heat up,i cannot see the piolt light glow anymore(even the broiler light),but the fan works
Sounds like an ceramic ignitor problem - if you are handy at all they easy to replace. One screw & two wires. If the lighter doesn't heat up to the proper temperature the gas flow doesn'tt start....
Apr 15, 2010 | Viking VGSC366-6B Gas Kitchen Range
Viking Griddle thermostat issue
replace the hotplate ignitor. you may in the future have simmilar problems with the ovens or broiler, there are 4 ignitors in my unit I have replaced each at lease once. it seems to be a weak link in the design. If you need more information contact c2d6c2 at yahoo
May 27, 2009 | Viking VGSC306-4B Gas Kitchen Range
Viking pro. gas range/oven leaks when all knobs turned off
check both oven ignitor and broiler by turning the oven first, and time the time that the ignitor takes before the flame lights up, it should not take more then 60 to 70 seconds, and do the same to the broiler.the one that takes the longer passing that mark of the 70 seconds needs replacing it 's not getting hot enough to light the burner on time that's the one that passes gas with out igniting. replace that one.
Dec 10, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Viking stove
no the termostat but the ignitor that's the part that's nest to the broiler burner. the part that ignite the flame. when you turn on the broiler the ignitor becomes red like a glow.
Nov 25, 2008 | Viking VGIC305-4B Gas Kitchen Range
Viking Range
I'm having a similar problem. I don't know the exact fix yet, I'm just starting to research. Check this link: http://www.applianceguru.com/forum1/1916.html
It sounds like the ignitors are suspect. This may be a weak component for Vikings. This link recommends a Maytag replacement part.
Dec 08, 2007 | Viking VGSC366-6B Gas Kitchen Range
Viking VGIC305-4B Gas Kitchen Range Logo
27 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
paulcarew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
