Question about Lasko 5540 Ceramic Compact Heater
Iflo digistat+2RF remote control for combi boiler
As its getting colder thought i would put the central heating on but it doesn't seem to be working. I cannot overide it aswell
    Problem Solver:
  • 16 Answers
There should be an overide button on reciever try checking if stat is still communicating with reciever when stat is turned up and down light should flash on reciever
Posted on Aug 17, 2009
Boiler was underwater in flooded basement, is it really dangerous to try to ignite it after drying out as Peerless manual says?
The manual says this and you are asking me? I'd go with what the manual says or a technician in this field of work.
Jan 09, 2017 | Heating & Cooling
70 series boiler model #70-148. I need the pionts/box that controls the thermosstat. It runs but it does not matter what the thermosstat is set at. I was told by a pro that the points are sticking. I
Be sure the thermocouple is still working, clean the contact points with crocus cloth and be sure the voltage going in to the controller is correct.
Jan 21, 2015 | Heating & Cooling
Johnson Starley boiler main board fuse blowing
Chances are the fuse on the circuit board is for control circuit protection. Take note of the location of all the thermostat connections on the circuit board and remove them. Do this with the power OFF. Replace the fuse and re establish power. If the fuse did not blow, the problem is in the wiring to or from the thermostat. It could even have the insulation rubbed through and making contact with the side of the boiler or a mouse could have chewed through the insulation causing a short to a metal object.
Once the issue with the thermostat wiring is resolved, reinstall the low voltage connections and you should be good to go.
Jan 08, 2015 | Heating & Cooling
What is a TPR valve on a Utica Boiler?
TPR Temperature and Pressure Relief valve. Usually mounted directly on the tank and has a lever on the valve.
Dec 27, 2014 | Heating & Cooling
Why does my home A/C unit result in a constant stream of water coming out of the overflow drain? I've had the same unit for 5 years, and it seems that it drains water in ever-increasing amounts. Als
Sounds like it is freezing up. Kind of hard to say since you did not say whether it is a central heat and air system. My overflow was constantly draining onto my patio from overflow. I crawled up in the attic and followed the pvc pipe where it came in from the outside and closer to the central unit in the attic I drilled a hole in the 90 degree elbow of the pvc and unclogged the pipe which was frozen from running so long. Then I covered the hole with silicone. no more leak coming from overflow
How do I get my radiators to start working?
ch1 indicates wirless thermostats? check the thermostats in the room have fresh batteries. this type can be wired but may be running on batteries you have to use a screw driver from below to open the unit. if you dont have a manual here is a link.
http://www.manualslib.com/products/Danfoss-Randall-Tp5000-Si-Range-2781091.html
i hope this helped
Oct 22, 2014 | Heating & Cooling
A/c fan not working=thermostat is working(central a/c system)a/c
The fan on the outside unit is powered from it's 240 volt source. Check that the breaker for the outside unit is not tripped. Also, a contactor is inside the outer unit that starts the fan - it may be faulty.
Jul 26, 2008 | Friedrich QuietMaster Electronic SS12J30D...
Lasko 5540 Ceramic Compact Heater Logo
1,354 people viewed this question
Top Lasko Heating & Cooling Experts
Dave
Level 1 Expert
Steve
Steve Oakes
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
