Question about GE JE1860 Microwave Oven
Replace control panel on a GE microwave oven JE1860
4 Suggested Answers
MicrowaveSvc
  • 9085 Answers
SOURCE: GE Microwave Keypad or Control Panel
If some pads on the keypad are not working, then you have a failed keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
On this model, the cover will have to come off to replace the light bulb. If it's mounted in the wall, it will have to come down.
The installation instructions are nice to have in this case. You can download GE owner's manuals and installation instructions here.
I have attached a drawing to show where the bulb is on this model. It is located on the right side of the oven next to the wall of the cooking cavity.
The bulbs are available in local grocery stores, hardware stores, and stores like Wal-Mart and Lowe's.
Please feel free to contact me directly if you need more help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 27, 2008
  • 181 Answers
SOURCE: microwave not working
faulty relay or solder joint on the power module, but a bad door switch is most common.
Posted on Nov 13, 2008
ginko
  • 19396 Answers
SOURCE: GE JE1860 Microwave is not heating
Test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
The diode and capacitors can br tested. The capacitor must be alloweddischarge before testing, or you risk to get electrocuted, even ifpower is off. Capacitors can get discharged by shorting their twocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Posted on Apr 27, 2009
HELLO. I HAVE A GE MICROWAVE MOD JE1860WB. THE MONITOR READ "F3" CODE. WHAT IS THAT?
The F3 code means that the Key panel also called touch pad is shorted. This code usually comes up when when the Microwave detects the shorted panel continuously for over 60seconds.
To correct this error, you have to Replace the key panel also called the touch pad.
Thanks.
Sep 14, 2011 | GE JE1860 Microwave Oven
It is behaving as if there is no power to the plug. There ias power i checked it.
If the microwave control panel doesn't light up, then your fuse is blown. unplug the microwave. unscrew the vent grill, (2) screws at the top of the microwave. then you should see 1 screw holding the control panel. after removing that screw, gently push up then out. there should be a metal plate on top of the control panel. remove that plate and the fuse will be in that opening. remove the fuse and check for continuity across the fuse. Replace fuse and microwave should start working again
Feb 10, 2011 | GE JE1860 Microwave Oven
Microwave not working after it ran without food in it.
try unplugging the microwave for a while then plug it back in.
Aug 29, 2009 | GE JE1860 Microwave Oven
I have a GE JE 1860. Someone ran the microwave for 15 minutes with nothing in it. Now it doesn't work at all , no power, no lights, nothing. Is there a fuse that may have gotten burned out? Is this...
There is a fuse and cavity thermal fuses as well as one on the magnatron that is supposed to reset itself.. The fuse is behind the control panel and the cavity fuses will require removal of the cabinet. Did you check for power at the plug?
Eric
Jun 20, 2009 | GE JE1860 Microwave Oven
How do I replace the magnetron in my GE JE1860?
Considering the cost to have the microwave repaired: both labor and parts, it is more economical to purchase a new one unless it is still under warranty.
Jan 01, 2009 | GE JE1860 Microwave Oven
Dec 16, 2008 | GE JE1860 Microwave Oven
Nov 13, 2008 | GE JE1860 Microwave Oven
GE JE1860 Microwave Oven Logo
78 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
