SOURCE: Scratched Sony LCD screen
The cost of replacing the screen (it is the entire LCD panel) is more than the TV is worth
SOURCE: Need replacement screen for Sony Flat Screen TV
Replacement screens are to come by. Check E-bay try and find a TV that wont power on. Also www.RNS-Systems.com Has used screens from time to time
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
SOURCE: KDL-46XBR2 sony broke lcd screen
I had a kdl46xbr2 go out on me repair company said screen went bad and they told me warranty dept would not fix it cause the screen ran 2800. So now im in dis with them for a replacment tv and they wanna give me the xbr9 i want the xbr8. Theres a reason i spent 3500 on the xbr2 the bravia pro engine is in a nother class than the standard bravia.
