Question about Whirlpool Dishwashers
Dishwasher will not turn on - Whirlpool DU1100XTPS1
PROBLEM: Whirlpool Dishwasher DU1100XTPS1- "Start" button has no effect at all when pressed. "Normal" cycle light does not come on when button pressed, but other cycle light do come on when their buttons are pressed. "Start" button does not respond at all, even when one of the responsive cycle lights is lit. "Cancel/Drain" does activate the drain cycle and clears water, but the drain cycle does not turn off automatically; must be turned off manually. DETAILS THAT PROBABLY DON'T MATTER: Some screws around door frame seem to have stripped thru plastic in frame so door torques easily. Second owner of this home, so don't know history. WHAT I'VE TRIED: I tried to reset using 'hitemp-heat-hitemp-heat' button press sequence (suggested by Rylee Smith for another posted issue) with no effect. I WELCOME your suggestions, especially those that are cheap, effective, simple and fast!! (Listed in order of preference) Thank you!!
  • Mike Smith Feb 10, 2012
    I received this reply (I accidentally posted the same problem in the Automotive category). Other thoughts? "his is a problerm caused by the main control circuit board that is behind all the control buttons, the part is about $150.00 and about 1 hour to replace it. By Dennis Weid. Feb 10, 2012"
4 Suggested Answers
  • 3247 Answers
SOURCE: KitchenAid dishwasher KUDS01DJ does not
Please confirm your model is the same as the one shown in this manual.
i am unable to find any mention that "start pad" -- means door switch problem.
You can check out the door switch by getting to the right parts using this diagram. Door switch is item 12.
Please post a comment to confirm what you found.
Posted on Dec 16, 2010
rickead1
  • 1998 Answers
SOURCE: We have Kitchenaid Dishwasher KUDP02FRSS1
unplug where the dishwasher drains into your garbage disposal and visually assure by looking in that hole that there is no build up there. You could have a partial blockage either at this spot or in the drain line itself. I do tend to find this alot for people that do put there coffee grounds down there garbage disposal. If you have looked and checked the entire drain line and drain port that goes into the disposal one of the next places you would look would be to assure that the float switch is activating the switch in the right postion and is not bent. Also on the inside of your tub you will see the float itself this connects to the float switch which is located on the underside of the tub usually to the right of the water inlet valve. If the float switch checks out well then you would look at the drain pump itself and remove the pump from the unit and use a extension cord that you would cut the female end off and add two electrical connectors to which by doing this you have just created a powered jumper wire. You can then connect the two connectors to the pump and the other end to the wall to visually see the impellar on the inside of the pump functioning. Also before removeing the pump sometimes I also find that on some units the way the drain hose is run is the issue as well where as it should be higher then the port hole on the disposal and not just run along the floor and then right to the disposal. If anything it should be run upwards to the highest point of the underside of the sink and then connected to the disposal which causes a better vaccum in the drain line and the pump doesnt have to constantly be pushing the water upwards. If you have any further questions message me back I await your reply. Please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future. Thanks again
Rick
Posted on Sep 13, 2011
emissionwiz
  • 80668 Answers
SOURCE: Dishwasher start button has no effect: Whirlpool DU1100XTPS1
This is a problerm caused by the main control circuit board that is behind all the control buttons, the part is about $150.00 and about 1 hour to replace it.
Posted on Feb 10, 2012
Testimonial: "Thanks to Dennis for a quick reply!"
Tip
How to Unlock Any Appliance or Turn Off Child Lock
<span style="font-weight: bold;">Bosch Dishwasher:</span><br /> <ol> <li>To deactivate, press and hold the "&lt;" button until the Child Lock LED goes out.</li></ol><span style="font-weight: bold;">Bosch Microwave:</span><br /> <ol> <li>Press "Settings" followed by the number "5" to deactivate Child Lock.</li></ol><span style="font-weight: bold;">Bosch Washing Machine:</span><br /> <ol> <li>To deactivate Child Lock, press the Start/Pause button and hold down for 5 seconds.</li></ol>or<br /> <ol> <li>Press the Menu button until CHILD LOCK :ON appears in the display.</li> <li>Press the Select button until CHILD LOCK :OFF appears in the display.</li> <li>Press the Start/Pause button and the key symbol should disappear.<br /></li></ol><span style="font-weight: bold;">Danfoss Thermostat:</span><br /><br /> <ol> <li>Press the control knob or button and hold it in place.</li> <li>Turn the knob counterclockwise until you see the word "Code" appear in the display.</li> <li>Turn the knob clockwise and select the code "0033."</li> <li>Press on the control knob until you see an icon of a clock or a hand appear or disappear indicating that the child lock has been set or unset.</li></ol><span style="font-weight: bold;">Delonghi Microwave:</span><br /> <ol> <li>To deactivate Child Lock, press the STOP/CLEAR key until the beep is heard.</li></ol><span style="font-weight: bold;">Delonghi Portable Air Conditioner:</span><br /> <ol> <li>Pressing the "+" and "-" buttons on the control panel together for more than two seconds unlocks the keypad.</li></ol><span style="font-weight: bold;">Fisher & Paykel Dish Drawer:</span><br /> <ol> <li>Disable the child lock by pressing and holding the key with a key and lock symbol printed on it until the padlock symbol disappears from the screen.</li></ol><span style="font-weight: bold;">Frigidaire Dishwasher:</span><br /> <ol> <li>Press and hold the No Head Dry button (or the Rinse Only, Delay Start or Air Dry button depending on model) for 3 seconds.</li></ol><span style="font-weight: bold;">Frigidaire Dryer:</span><br /> <ol> <li>Press and hold the "Control Lock" button for five seconds to release the lock.</li></ol>or<br /> <ol> <li>Press and hold the "Options" and "Select" buttons simultaneously and hold for 10 seconds to release the door lock.</li></ol><span style="font-weight: bold;">GE Dishwasher:</span><br /> <ol> <li>Press and hold the Heated Dry button for 3 secs.</li></ol><span style="font-weight: bold;">GE Electric Stove:</span><br /> <ol> <li>Press and hold "Lock" for three seconds to release the child lock function.</li></ol><span style="font-weight: bold;">Kenmore Dishwashers:</span><br /> <ol> <li>Press the "Heated Dry" button, and hold for four seconds until the "Lock On" icon light turns off.</li></ol>or<br /> <ol> <li>Hold the "Sensor Dry" or "Lock" symbol down for three seconds until the lock indicator light goes off.</li></ol><span style="font-weight: bold;">Kenmore Dryer:</span><br /> <ol> <li>Press and hold the AUTO DRY LEVEL button for 3 seconds.</li></ol><span style="font-weight: bold;">Kenmore Microwave:</span><br /> <ol> <li>Touch and hold Cancel for 5 seconds to deactivate the lock.</li></ol><span style="font-weight: bold;">Kenmore Range:</span><br /> <ol> <li>Push and hold the Lock button for 10 seconds.</li></ol><span style="font-weight: bold;">Kenmore Washing Machine:</span><br /> <ol> <li>Press and hold "Drain & Spin" for 3 seconds to release the child lock.</li></ol>or<br /> <ol> <li>Press and hold Cancel for 10 seconds.</li></ol>or<br /> <ol> <li>Hold the "End of Cycle" button down for 5 to 6 seconds.</li></ol>or<br /> <ol> <li>Hold the Child Lock button for 5 seconds.</li></ol><span style="font-weight: bold;">Kitchenaid Dishwasher:</span><br /> <ol> <li>Press and hold Energy Saver/Dry button for 5 seconds.</li></ol>or<br /> <ol> <li>Press and hold Lock button for 5 seconds.</li></ol><span style="font-weight: bold;">Kitchenaid Microwave:</span><br /> <ol> <li>Press and hold the "Cancel" or "Start" button for five seconds.</li></ol><span style="font-weight: bold;">Kitchenaid Oven:</span><br /> <ol> <li>Touch and hold START for 5 seconds.</li></ol><span style="font-weight: bold;">LG Dishwasher:</span><br /> <ol> <li>Press and hold the Spray and Rinse button simultaneously for 3 seconds.</li></ol><span style="font-weight: bold;">LG Dryer:</span><br /> <ol> <li>In models that include a rack dry, usually holding the [rack dry] button for three seconds will disable the function.</li></ol><span style="font-weight: bold;">LG Refrigerator:</span><br /> <ol> <li>Press and hold the Lock button for 3 seconds.</li></ol><span style="font-weight: bold;">LG TV:</span><br /> <ol> <li>Open the menu, select lock (padlock symbol) then select lock system, then select off.</li> <li>Press exit to exit the menu.<br /></li></ol><span style="font-weight: bold;">LG Washing Machine:</span><br /> <ol> <li>Press and hold "Dry" & "Spin" buttons together for a few seconds. </li></ol>or<br /> <ol> <li>Press and hold "options & select" until the light goes off.</li></ol>or<br /> <ol> <li>Press and hold "end of cycle" for over 5 seconds.</li></ol>or<br /> <ol> <li>Press and hold the PRE-WASH/Child Lock buttons for 3 seconds. </li></ol><span style="font-weight: bold;">Maytag Dishwasher:</span><br /> <ol> <li>Press the Heated Dry button for three seconds.</li></ol><span style="font-weight: bold;">Maytag Microwave:</span><br /> <ol> <li>Press and hold the "Enter/Start" button for 3 seconds</li></ol><span style="font-weight: bold;">Panasonic Microwave:</span><br /> <ol> <li>Press "Stop/Cancel" 3 times to deactivate Child Lock.</li></ol><span style="font-weight: bold;">Philips TV:</span><br /> <ol> <li>Using your TV Remote, press the 'MENU' button, select FEATURES and press cursor right.</li> <li>Press cursor up/down to select CHILD LOCK and press cursor right.</li> <li>The screen will prompt you for PASSWORD, key in you password if known. If the password is unknown, then key in the code 0711 twice.</li> <li>Press cursor up/down to select CHILD LOCK, press cursor right to change the status to OFF.<br /></li></ol><span style="font-weight: bold;">Samsung Dishwasher:</span><br /> <ol> <li>Hold down the Delicate and Rinse buttons simultaneously for three 3 seconds.<br /></li></ol><span style="font-weight: bold;">Samsung Refrigerator:</span><br /> <ol> <li>Press and hold the Ice Off/Lock button for 3 seconds.</li></ol>or<br /> <ol> <li>Press and hold the Ice Off button for 3 seconds.</li></ol>or<br /> <ol> <li>Press and hold the Lighting button for 3 seconds.</li></ol>or<br /> <ol> <li>Press and hold the Child Lock button for 3 seconds.</li></ol><span style="font-weight: bold;">Whirlpool Dishwasher:</span><br /> <ol> <li>Press and hold Heated Dry button for 4 secs.</li></ol><span style="font-weight: bold;">Whirlpool Dryer:</span><br /> <ol> <li>Press and hold the END OF CYCLE SIGNAL button for 3 seconds.</li></ol><span style="font-weight: bold;">Whirlpool Washing Machine:</span><br /> <ol> <li>Press and hold the END OF CYCLE SIGNAL button for 3 seconds.</li></ol>
on Jun 17, 2011 | Washing Machines
Feb 09, 2012 | Cars & Trucks
The Whirlpool Dishwasher GU 2400 won't staart
Sometimes I have to push the cancel button on my Kitchenaid and start over and push the selection buttons again. and then push start. Don't know if this will help.
Jan 07, 2012 | Whirlpool Dishwashers
Describe your whirlpool du948pwpq Problem: I have a whirlpool du948pwpq dishwasher in a tenant's unit. They said the delay start button is no longer working. Also, they cannot "de-select" the...
Dmorgant, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Dmorgant), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 19, 2017 | Whirlpool 24 in. DU948PWPQ Built-in...
We have the Whirlpool dishwasher ,Model: ADG6 955. used it smoothly last night but this afternoon, it just will not start up. The green 'START" button keeps flashing and the dishwasher just does not...
Try turning off power to the dishwasher completely by either unplugging it or turning off the circuit breaker for a few minutes, then power it back up. Sometimes this will reset it.
Oct 11, 2017 | Whirlpool Dishwashers
Dishwasher won't start!
I've provided a link to the manual for your dishwasher. You should check for proper wiring and that the water line is connected and turned on.
The washer should start to fill when you press a cycle.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208283509.pdf
May 09, 2009 | Dishwashers
Dishwashers Logo
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
