I tried shaking the TV a little bit and the power went back on and then shuts off in several minutes. I removed the cover of it and desturb the wirings gently with a none conductive wood and it went back on. So it appears to be working in proper but then it a few minutes it shuts off again. I can no longer open the back of the TV again and again since the TV set is extremely heavy. What should I do?
yes i agree with pavin but let the tech know that you know is a cold solder or varius cold solder, that will help you in the price of the repair,you can say this to him,"look at the circuit board closely for cracked solder joints. Resoldering any bad joints will solve the problems"...good luck
If the set switches ON when you shake it, or shake some wires inside (after opening the back cover) then in all likelihood you have a 'dry' or 'cold' solder.These are not easy to track, and so best left to a professional technician. call for a service tech.
My sony kv 32fs320 is having a problem with the colors. The overall hue slowly shifts from normal...
(More)
My sony kv 32fs320 is having a problem with the colors. The overall hue slowly shifts from normal to pinkish, then bluish, then greenish. This is particularly noticable with whites. It is somewhat intermittant.
I have a Sony Trinitron Model KV-32FS320. a while back it just would not turn on. The red indicator...
(More)
I have a Sony Trinitron Model KV-32FS320. a while back it just would not turn on. The red indicator light keeps flashing 5 times then pause then 3 times. I have unplugged it for a long period of time and tried to see if that would reset what ever was wrong but no luck. any suggetstions?
Blinks 5 times and then pauses and then 3 blinks....Repair shop I spoke with says it means no h...
(More)
Blinks 5 times and then pauses and then 3 blinks....Repair shop I spoke with says it means no h drive issue...Any help would be appreciated
I have a trouble where my sony kv-32fs320 blinks 5 times. called service repair centers and all 3 gave me a different problem description. Just wondering if an explanation of what is wrong can be given to me.
