Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Need amana manual for side by side model SXD23vw
Need owners manual
3 Suggested Answers
  • 385 Answers
SOURCE: Amana SXD23VW side by side....Light
There is a door switch that has gone bad.Hope this helps.
Posted on Jun 03, 2011
oldTech2332
  • 2341 Answers
SOURCE: Amana side by side refrigerator dumps a large
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,
there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
Posted on Aug 07, 2011
Does my Amana refrigerator model number SBD20S4E have a water filter, and if so where is it located?
THis is a great question to go to the owner's manual for but I believe yours is a side by side. SOme filters are low behind the grill, others are inside:
Here you go Amy:
Jan 11, 2015 | Amana Refrigerators
Ice maker on amana sxd23vw not refilling
could have a bad ice maker or the line froze up again,check this site out
http://www.youtube.com/watch?v=0PRQWoxTtLg
Aug 07, 2012 | Refrigerators
We never received a manual and now need to replace the water filter. model no. ASD2522WRW03 - ser. no. S01831393. also how do we order a replacement manual
The direct link to the manual from Amana is http://www.kitchenaid.ca/assets/pdfs/literature/User%20Instructions%20-%20W10237701A.pdf . If the direct link doesn't work, start here: http://shop.amana.com/product_literature/search_results.jsp?searchTerm=ASD2522WRW03&siteCd=AMA&userType=Consumer . The manual is also available at Manage My Life: http://www.managemylife.com/mmh/owner_manuals/17324/AMANA-Side-by-Side-Refrigerator-L1002225?brand_name_search=ASD2522WRB03+AMANA .
The filter you need is T2RFWG2 and P2RFWG2 (part number 4396841) . The filter is in the base grill on the freezer side of the side by side. There is a cap over the filter. You need to push the release button on the cap to remove the cap and filter. Save the cap and put it on the new filter before replacing the filter. If you replace the cap, you can use the water and ice dispenser without the filter.
If you want a printed copy of the manual, you can order it from Sears Parts Direct. They also have the filter. See http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-ASD2522WRW03/1268/0165000/W1009009/00001?blt=06&prst=&shdMod= . The manual is part 1 ($5.99) and the filter is part 30 ($54.98). The filter is also available from Partstore.com http://www.partstore.com/Model/Maytag/Maytag/ASD2522WRW03.aspx for $37. Amana sells the filter here: http://www.amana.com/accessories/refrigerators/water_filters/refrigerator_water_filter___in_the_grille_fast_fill_push_button_4396841.pro?scr=category for $40. If you go here: http://www.amana.com/accessories/refrigerators/water_filters.cat , you can order several filters at once.
I hope this helps.
May 22, 2011 | Amana Refrigerators
How much space is needed between the refrigerator and cabinets, top and sides?
Down to zero on the sides ... 4 iches in the back ... couple inches at the top ... unless Amana tells yo something different in the owners manual ... http://www.amana.com/
Thanks for your visit today.
Feb 02, 2011 | Amana ASD2626HE Side by Side Refrigerator
Amana Model ACS3350AS Oven temp is 25 degrees hoter than display. What do I need to repair it? How do I find a manual for this. This came with the house.
Oven temperature can be adjusted for a maximum of 35 degrees farenheight.
Refer to the page 11 of your owner's manual.
A PDF version of the owner's manual can easily be find at
Jan 11, 2011 | Amana ACS3350 Gas Kitchen Range
Need owner's manual for Amana ACF4265 range
Here's the link to get a free owner's manual and installation instructions that you can print up from your computer. Just pick the exact model # from the list of choices. Douglas
http://shop.amana.com/product_literature/search_results.jsp?searchTerm=ACF4265&siteCd=AMA&userType=Consumer
May 31, 2010 | Amana ACF4265 Electric Kitchen Range
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
80 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
