Bizhub C25 Call service 13F0 after warm up?
My c525 i restting very often
Why are you resetting it what is it doing showing a code ? powering off? Jamming? please explain
Sep 03, 2014 | Konica Minolta New Bizhub C25 Color Laser...
Bizhub 164 service call no c3451 please help me
Fusing warm up problem.To reset press Utility Stop00Stop01 ,enter in the service mode select Trouble reset.If do not work you have need to remove and repair the fusing unit.
Jul 13, 2014 | Konica Minolta bizhub 200 Printer
Where is the transfer belt located on a Konica Minolta C25
above the 4 drum units have to remove the 4 toners the 4 image units and the transfer belts is removed from the right side after removing a section of the duplexer on the right side door.
May 08, 2014 | Konica Minolta Bizhub C25 C35 C35p Color...
My bizhub c25 waste toner was full so replaced and will not now reset.
The C25 stores toner in a waste toner container. On the front of that container there is rectangular clear window that fits into a sensor when installed into machine. The sensor passes a beam of light through that window. When the bottle is full there is toner inside that clear plastic window which stops the light from making it through the window and the machine will tell you the waste toner is full. Just dumping the container out will not clear that window and by putting it back in the machine you will get the same toner full message. If you are going to try to reuse that container you will have remove the black plastic cover that is glued to the container above the clear plastic. Then use something like a Qtip to clean all the toner off of that clear window(much easier and faster to just replace in with a new container). if you still get the waste toner full message after you install it then remove it and wipe off the sensor that the clear window sits in. This will clear the message and you can continue your copy job.
Apr 02, 2014 | Konica Minolta Office Equipment & Supplies
How can I rest the admin password on Bizhub c25
Why do u want reset it? Default password is administrator all lower case
Nov 22, 2013 | Office Equipment & Supplies
C-13fa
Sir/Mam, Have C-13F0 in the service manual but no C-13FA
. C-13F0 Has to do with the LASER Inside the Print Head which puts the image on the drum. Might want to have that looked at or the Image control board that controls the Print head.
Nov 05, 2013 | Minolta DI-2010F Copier
Send to E-mail tx result report
go to utility then got to reporting then select TX result report change to on if fails or off
Nov 05, 2013 | Konica Minolta Office Equipment & Supplies
Bizhub C25 scan to email
Is the file that you are scanning to a shared file, required
Apr 25, 2013 | Konica Minolta Bizhub C35/c35p/c25 Magenta...
My Bizhub 350 is saying malfunction dectected C3452
This code means you have a fuser warm up failure. The fusing unit uses heat and pressure to "fuse" the toner onto the paper. It is located right where the paper exits the machine. Here is the info directly from the service manual:
The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Most likely you have a thermistor failure in the fuser. You are going to need to call your local service company and have them repair then reset the machine.
Good Luck and Thank You for using Fixya.
Sep 08, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
149 people viewed this question
jasbo
jasbo
