Question about Nokia C1 Cell Phone
Memory card in use by another application
When I connect usb cable to phone and pc I then go usb mass storage on phone but it says memory card is in use by annter application
mortega
  • 43 Answers
SOURCE: N95 8GB.Problem in connecting the phone through USB cable
I suspect the message you're receiving is:
"Unable to Activate Data Transfer Mode. Mass memory is in use by another application."
It's likely that several applications are running in the background of your phone. I believe the N95 runs on the Symbion OS. I'm not sure how to walk you through pulling up a task manager application to manually close the running applications, but the simple answer to this problems is for you to turn your phone completely off and turn it back on again. This should close all the applications that were running in the backgound.
Hope this helps.
MO
Posted on Jul 13, 2008
  • 37 Answers
SOURCE: Nokia N96 Corrupt Card
Open the card on your PC and copy all your files to a folder on your desktop. Then go to my computer, right click the memory card and format. When a little window appears just click start.
If your files are deleted then paste them from your desktop back onto your card. This should fix the problem.
Posted on Jun 23, 2008
dapidc
  • 111 Answers
SOURCE: my nokia 6300 can not be detected by pc suite or any pc
You should choose Nokia Mode on your phone when connecting to PC.
Posted on Dec 24, 2008
anandg27
  • 1272 Answers
SOURCE: i have nokia xpress music 5130 and it gives me
I myself own this awesome music phone.
Find the answers below:
1) As it shows less internal memory, it seems that you have transfered some data like mp3, video clips through bluetooth to this phone and it was saved in the recieved folder which autmatically saves in phone memory. Try saving the data to memory card and you will get the phone memory free.
2) Check the above reason for this same issue.
3) You need to select proper connectivity mode under settings of this phone. Go to settings and then open connectivity folder. Here select the connection mode.
Make sure to install the latest PC suite software on the computer. This can be downloaded from the NOKIA website.
Regards
Anand
Rate it, if it helps.
Posted on Jun 23, 2009
SOURCE: phone start-up failed. contact the retailer
phone start-up failed contact the retailer
Posted on Oct 03, 2009
How can I download music to my fusion2 phone
First you:
2.9.1 Using the microSD Card as USB Mass Storage
To transfer all your favorite music and pictures from your PC to your mobile phone's microSD card, set the microSD card as USB mass storage.
1. Connect your mobile phone to your PC with the USB cable provided. Your PC will detect the microSD card as a removable storage device.
2. Open the notification bar, and then touch USB connected.
3. Touch Turn on USB storage in the dialog box that opens to confirm that you want to transfer files You can now transfer files from your PC to your mobile phone's microSD card. When your microSD card acts as USB mass storage, your mobile phone will not use this memory space. Ensure that you follow the correct procedures to disconnect the USB mass storage device (your mobile phone) from the PC when you have finished transferring files.
Then:
8.3.1 Copying Music to the microSD Card
1. Connect the phone to your computer with a USB cable and mount the microSD card.
2. On the PC, navigate to the USB drive and open it.
3. Create a folder in the root directory of the microSD card (for example, Music).
4. Copy the music from your computer to the folder you have created.
5. After copying music, unmount or eject the drive as required by your PC's operating system to safely remove the mobile phone.
6. Disconnect the mobile phone from the PC.
Once done open music player and play music.
Ref: http://www.att.com/support_static_files/manuals/ATT_Fusion2.pdf
Dec 13, 2012 | Computers & Internet
How to connect laptop with samsung gt-s5620 thru usb to copy the songs from laptop to mobile
just plug in the data cable from your phone to usb port on your laptop, then open setting from your phone and find pc connectivity then set as mass storage, it will detect your memory card of your phone to your pc, drag the music you want to my music folder in your memory card.
Jun 05, 2011 | Samsung Cell Phones
Hiya can you use a usb cable without a cd
while it depends on the phone model, but most Samsung phones have 3 options when connected via a USB cable.
1.Media mode
2.Mass Storage
3.PC Studio
If you need to work on the memory card(browse file Etc.) then select Mass Storage.
MEDIA MODE does the same thing but it also allows you to browse the phone's internal memory.
to use PC Studio,you need the CD
Mar 04, 2011 | Samsung Cell Phones
How to install games and applications in memory card when i install java files it saves only in phone memory plz tell how to install in memory card
I think that u are copying and pastin in the wrong folder. With your usb cable, the option automatically comes up for eg. phone or removable disk e, click on removable disk which is your memory card and tranfer your files there. But make sure your phone is set on mass storage in usb mode. Go to settings, usb settings and chose mass storage. This might help.
May 31, 2010 | Sony Ericsson Walkman W205 Cell Phone
I have a LG Cu920 model and bought a micro sd 8GB card and used the USB data cable to connect to the PC and i am unable to get connection established as it displays connecting to mass storage device and...
When it displays insert memory card for connecting as mass storage device, switch off the phone and reconnect so the phone will perform as a memory storage device.
Good luck.
Mar 16, 2010 | LG Vu CU920 Cellular Phone
Cant get usb data cable to work
As long as you have a memory card installed in your phone, you should have no problem. Use a micro SD card of no larger than 4 GB. Attach the cable to your phone and computer via an available usb port. Your pc will then recognize your memory card as a mass storage device, and you cn drag and drop your files to and from the computer.Make sure your phone usb connection is set to mass storage.
Aug 06, 2009 | LG Vu CU920 Cellular Phone
My compter does not regonize my LG Dare or Sd Card? How can I sync music to my LG Dare with the software. My carrier is Telus and I did not get the cd with any of the downloads to do so?
In order for the phone to work with ur pc u have to set/change the connectivity.
Go into Phone settings, then Connectivity, then USB Connection Mode, then select either Mass storage or Data Service, to use Mass Storage you must have a Memory card inserted into the phone, then you can select mass storage and use your phone as an external hard drive/memory stick. In this mode u can only transfer pics, music, videos etc from pc to phone and vice versa via your Computer Windows Explorer.
It will not enable you to use the LG PC suite Application. To use the LG PC suite, you must select Data Service, then connect your phone to the PC via a USB port.
May 13, 2009 | LG RUMOR Cellular Phone
How can I download music and videos on my i9 phone
To fix this problem go to your menu go to settings than go to connections, now go to the USB hit OK now you will see memory card access, data modem, application access, GPS NMEA and finally help. Make sure it is on memory card access and not any of the other ones the memory card access is to allow a PC to use your phone as a memory card reader. The data modem allows a PC to use your phone as a modem. Application access allows certain PC applications to access the phone. and finally the GPS NMEA allows the phone to output GPS signal from EMU port.
Nov 15, 2008 | Cell Phones
Samsung Wafer R510
get a usb cabel and tranfer it across or get bluetooth and send it across
Feb 02, 2008 | Samsung UpStage SPH-m620 Cellular Phone
I can't download music to my phone
Did you able to see Removeable Disk after connecting to PC?
If not then there are two possiblities...
1. Check the setting of USB mode at
Connectivity > USB Connection Mode > Mass Storage
It should 'Mass Storage'.
2. Even though Mass Storage is there and you are still not get Removeable Disk then replace Phone's memory card with SandDisk's Memory card.
Once you verify above two points you will get Removable Disk, and then you can make Copy/Paste to download songs into your phone.
Jan 18, 2008 | LG CU500 Cellular Phone
Nokia C1 Cell Phone Logo
326 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
