Question about KitchenAid 24 in. KUDM01TJ - Multiple Color Built-in Dishwasher
Kitchenaid dishwasher kudm01TJ won't start
Wont start
  • 9 Answers
SOURCE: KitchenAid model KUDM01TJ
Check for loose wires on all switches and their is a fuse on the electronic panel that should be checked.
Posted on Aug 31, 2008
SOURCE: KitchenAid 24 in. KUDI01TJ will
http://www.applianceblog.com/mainforums/kitchenaid/17513-fixed-cancel-drain-light-flashing-not-working.html
Hi it's hard to diagnose from symptoms described, but try this post and fix below i am pretty sure this may be whats happening with your unit? Please read right through to the bottom....
Posted on Jun 18, 2011
oldTech2332
  • 2341 Answers
SOURCE: I have a KitchenAid dishwasher model #
what most likely is going to be the problem is a blown thermal fuse that attaches to the control panel housing. gain access to the control panel and use should see the thermal fuse,the housing for the control board is grey and this part is white.Remove the wires to it and check for contininity on it using a ohm meter set to a low ohms setting. If it turns out to be good the next thing to check is the switch(s) on the latch asm using the same method to check them as the fuse.BEFORE CHECKING EITHER OF THOSE BE SURE TO DISCONNECT POWER TO THE DISHWASHER
Good luck, i hope that i 've helped you to figure out what is wrong with your dishwasher,
Gene
Posted on Aug 06, 2011
mc1bean
  • 3053 Answers
SOURCE: kitchenaid dishwasher kuds220t3 won't start
Hello, star
I was trying to help you out here. I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 27, 2011
  • 107 Answers
SOURCE: KitchenAid Dishwasher won't drain KUDI01ILBL6
Do you have an air gap on your sink? Check it to see if its plugged.
Posted on Nov 15, 2011
No dry heat
Sounds like ur heating element has blown but because u also say light doesn't work check 4 power at plug or wall socket if this ok then check ur fuses in plug and fuse box on the wall if all ok then un screw bulb and replace like 4 like also same applys 4 the heating element hope this helps u
Sep 03, 2012 | KitchenAid 24 in. KUDM01TJ - Multiple...
Kitchen aid KUDM01TJWH0 dishwasher- stopped mid-cycle, normal and rinse buttons are flashing.
I have same problem. I can't find the Troubleshooting diagnostic instructions. These are usually hidden somewhere on the washer. Do you know where they are?
Apr 26, 2011 | KitchenAid 24 in. KUDM01TJ - Multiple...
Kitchenaid (KUDM01TJWH0)
wires where thy bend at bottom of door and heating element....water in motor
Aug 14, 2009 | KitchenAid 24 in. KUDM01TJ - Multiple...
I have wirlpool dish washer and it is lock.I cant start it.
First thing to check is the micro switch in the handle assemble.It may be bad.When you shut the door a lever comes in contact with that switch which allows the unit to start.Next would be the thermal fuse(see manual).
May 17, 2009 | KitchenAid 24 in. KUDM01TJ - Multiple...
Upper spray arm tower came off
You can find a replacement for the upper spray arm (3rd level). Kitchenaid #8268298. See www.pcappliancerepair.com. Their part number is 8193504. $9.15 plus shipping. Good luck and happy holidays.
Joe
Nov 16, 2008 | KitchenAid 24 in. KUDM01TJ - Multiple...
Kitchenaid KUDM01TJBS1
Open the door and at the bottom right is a float switch. Make sure it's working and nothing is obstructing it.
Jun 01, 2008 | KitchenAid 24 in. KUDM01TJ - Multiple...
Mar 31, 2008 | KitchenAid 24 in. KUDM01TJ - Multiple...
Lights are on, but wont start
The water pump can hum and still have a defective coil.
Jan 13, 2008 | KitchenAid 24 in. KUDM01TJ - Multiple...
Stopped Dead
thermal fuse attached to control board. it is white in color. You should have power at both terminals on this part.
Dec 15, 2007 | KitchenAid 24 in. KUDM01TJ - Multiple...
KitchenAid 24 in. KUDM01TJ - Multiple Color Built-in Dishwasher Logo
41 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
