Question about Liebherr Refrigerators
Liebherr cupes 4653 it keeps freezing on top half of fridge ,seals are ok and fan works with door closed,, tried defrosting and cleaning drain pipe at rest , also grill at rear , any help would be gr
Cupes 4653
jumptrout51
  • 3361 Answers
SOURCE: my fridge in my fridge freezer keeps freezing everything in it.
If the fridge side is frozen you have a door seal issue.
If the freezer side is frozen you have a defrost component issue.
Your post was not clear as to which side is frozen.
Posted on Jun 16, 2009
garing
  • 998 Answers
SOURCE: automatic defrost no longer works
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Posted on Aug 19, 2009
woodchuck789
  • 4070 Answers
SOURCE: the freezer keeps defrosting
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Oct 20, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Since defrosting my freezer my fridge does not
So you manually defrosted your refrigerator and now the fresh food section is warmer than normal. Can you please send me the model number and your location in the world. Some models are totally impossible. I found related models but no parts listings yet. Could you have someone feel the compressor top to see if warm, cool or too hot to keep hand there. Sea Breeze
Posted on Mar 18, 2010
SOURCE: How to find part number of Liebherr fridge freezer
Normally if you remove the LHS salad drawer in the fridge you will see a sticker on the wall of the unit with the relevant information.
Hope this helps.
Posted on Jun 08, 2010
For the last 4 months water has collected in and under produce bins where is freezes if not mopped up. I've tried pulling items away from shelf vents. Could a drain be clogged?
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Apr 21, 2015 | Samsung RF217ACRS Bottom Freezer French...
My bush BFFF55173 keeps generating a pool of water on the bottom shelf? Does anyone have the same problem?
Mar 24, 2015 | Refrigerators
Water freezing on floor of lower draw under ice maker
Dec 05, 2014 | Refrigerators
I have a samsung refrigirator side by side with a bottom freezer door. It is leaking from the bottom of the right side of the freezer right of the free
Jul 15, 2014 | Samsung Refrigerators
Samsung RS275. Water pooling under bottom drawer and freezing. What doesn't freeze, leaks through the door to the kitchen floor. What is happening?
Jun 26, 2014 | Samsung RS275AC Refrigerator
Freezing around door of freezer
Jun 01, 2014 | Samsung Refrigerators
We have a liegherr 7082 214-00 model and the defrosting hole at the back of the refrigerator freezes up. We remove the ice, but a day or two later the ice is back blocking the water-drain hole. We have...
Try moving your settings around..Also check the seals around the fridge.. Make sure the doors closing good. IF it's not sealing good it causes it to run to long and it will freeze up...Also make sure your wife (Lol) is not pushing things all the way to the back or sides. The air has to circulate. Make sure that the fan on the compressor is running also....That will make it freeze up. But if you can fix it it will be better to get someone that knows what there doing. I waited to long and had to change the compressor...It's giving signs that something is about to happen...Don't wait until you have to buy another..
Nov 21, 2017 | Liebherr Refrigerators
The top part of the refrig keep freezing?
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Apr 14, 2010 | Kenmore 71279 Bottom Freezer Refrigerator
Temperatures not staying cold, then getting too cold. First everything in freezer thawed out. Then, fridge wasn't cold enough. We moved everything to freezer just to keep colder (not to freeze). Then, days...
assuming fan now working. clean out vents/ drain holes (make sure no ice in bottom of freezer or in fridge unit)i.e. a total defrost.then check door seals all okay(no air leaks) if unit was trying to defrost itself and you reset to colder it will need to reset itself.....
Feb 11, 2010 | Hotpoint HSS25GFP Side by Side...
My fridge in my fridge freezer keeps freezing everything in it.
Jun 16, 2009 | Hoover HFA270K Bottom Freezer Refrigerator
Refrigerators Logo
41 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
