Test of Premium rating system process
RE: the Premium Question test
Can you log in with a different or borrowed board name and visit:
http://www.fixya.com/support/t1162878-test_premium_rating_system_document
to see all the input?
As you stated that you can only see one response at a time and then not go back to a previous solution: Do we like this paradigm? No. Quite frankly, I don't. This detracts the customer from the crowd sourcing model in the long run.
I believe the impetus to make change so the system is as it is now, was to deal with those experts who:
1.) were possibly using more than one board name to post
2.) experts who were quick posting with a one liner (not a valid assumption, as some problems require we ask for a model name, etc.)
3) experts using Place Holding techniques, similar to number 2
At the very least, the customer could have on a second page/tab screen or a pop up with a list of responding experts that are a link to that experts response. This would allow for 'going back' and re-rating an expert.
So, if the initial initiative was to calm down the waters for the customer so it appeared less overwhelming to them... this effort failed in part. That part being what I just wrote above.
To reiterate, giving the customer a flowing list of experts as links to their posts with the chance to in fact 'go back' to an expert and re-rate an expert, would be the single most change, for the better and have the most impact.
I won't go into details here, but programming a new window pop up or open a second tab or even initiate a floating frame on screen is not a difficult thing to do in web page script programming. You could get half a dozen of us volunteer to write the code for you.
We are all looking forward to the screen shots and the conclusive summary.
Regards,
Worldvet
    Master:
  • 538 Answers
I already have that page, courtesy of robotek, and varpun not pretty, but it shows all the input. Now, I am just waiting on the premium support folks to respond to my enquiry, as the buyer of the session..
Posted on Oct 23, 2008
My camera samsung when turned on , the lens out and log in again and power then die
Suspect battery - won't hold a charge. Go to Walmart, borrow a replacement battery that is charged, and test the camera - if no issues with borrowed battery, purchase a new one. Enjoy.
DO NOT force the lens in or out, the gears are tiny and very fragile - another possibility, if the lens moves and then stops and the power dies - gears are jammed or broken. But go for the battery test first. Good luck.
Sep 19, 2016 | Samsung Cameras
Will not power up
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Oct 13, 2012 | Dell Inspiron M5030 Laptop Computer 3D...
"Unknown Devices" keep logging in and out every
you mAY CHECK THE RAM BY USING BIOS MEMMORY CHECK OR TRHU OS MEM TEST.
Mar 14, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Can not update the dash board how do i fix it
I fixed mine by going into System Settings, Network settings, then running a test on xbox live. Initiating the test logs your profile out then runs a network test. The test completed with no problems and then asked me if I wanted to update again. Without logging back into my profile I clicked OK and the update ran without a hitch. I think the solution lies in the fact that my profile was logged out and from what I have seen, the only way to connect to xbox live without a profile being logged in is with a network test. Once you connect to xbox live it senses that you don't have the update and asks you again, this time without a profile logged in and you are able to do it.
Nov 01, 2010 | Microsoft Xbox 360 Console
07,010,43:49314 system error
Here is the solution for your problem.
7,010.43: The printhead is stuck in the tilted position, or is not tilting properly over the CAM, due to problems with the process motor gearbox.
1. Reboot the system.
2. Did this correct the problem?
Go to Step 2. Complete.
2 1. Do the printhead lock arms rotate correctly? Go to Step 3. Repair or replace the lock arms.
3 1. Is there spilled ink around the printhead? Clean the print-head area.
Go to Step 4.
4 1.
Check the process gearbox for obstructions
or damaged.
4.2. Ensure the gears are correctly aligned and homed.
4.3. Verify the process shaft and drive module
shaft are at their home positions.
4.4. Did this correct the problem?
Complete. Go to Step 5.
5 1. Verify the headtilt gear will engage. You can
manually set the headtilt gear.
5.2. Is the gear engaged properly?
Go to Step 6. Set the head tilt gear.
6 1. Use service diagnostics to run the Tilt Axis
Drive
test.
6.2. Did the test fail?
Replace the process gearbox.
Go to Step 7.
7 1. Use service diagnostics to run the Process
Motor
test.
7.2. Did the test fail?Replace the process motor.
Go to Step 8.
8 1. Use service diagnostics to run the Head
Maintenance Wiper Clutch
test.
8.2. Did the test fail?Replace the wiper drive clutch.
Go to Step 9.
9 1. Ensure the wiper is properly aligned.
9.2. Use service diagnostics to run the Wiper
Drive
Test.
3. Did the test fail?
Go to Step 10. Replace the exit module assembly.
10 1. Use service diagnostics to run the Load
Maintenance Clutch
test.
10.2. Did the test fail?Inspect the maintenance drive system, replace any defective
parts.
Hope this helps and rate your response.
Thanks, SF
Feb 18, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
845 GLVA. problem is --- power led is on but no display SMBS, RAM ,, PROCESSER, & HD Are all ok
if you have a seperate graphics card that may be faulty try and borrow one to test it and if its the built in type, again try and borrow one for testing otherwise you may have a faulty motherboard
Aug 06, 2009 | Intel Desktop Board D845GLVA...
Phaser 8400 error code 43:117147
Hi john804:
Thanks for the reply.Here is your problem.
7,010.4x: PM_FAULT_HEADTILT_HOME_ERROR
The printhead is stuck in the tilt position by the tilt arms. The process motor gearbox being out of sync can also cause this error.
1. Reboot the printer.
2. Verify the lock arms rotate correctly.
3. Check for spilled ink around the printhead.
4. Check the process motor gears for damage. Ensure the
process gears are correctly aligned and homed.
5. Verify the process gear box, process shaft, and drive
module shaft are at home position.
6. Verify the headtilt gear will engage, see the home
positioning procedure on page. You can manually
engage the headtilt gear.
7. Run the Tilt Axis Drive test.
8. Run the Process Motor test.
9. Run the Head Maintenance Clutch test, if the test fails
replace the clutch.
10.Run Wiper Drive test. If this fails inspect the wiper
drive system.
Hope this helps
Jul 22, 2009 | Office Equipment & Supplies
I want to read text file which is located in c drive using java code can anybody help me out
import java.io.*;
import java.util.Scanner;
public final class ReadWithScanner { public static void main(String... aArgs) throws FileNotFoundException {
ReadWithScanner parser = new ReadWithScanner("C:\\Temp\\test.txt");
parser.processLineByLine();
log("Done.");
* @param aFileName full name of an existing, readable file.
public ReadWithScanner(String aFileName){
fFile = new File(aFileName);
/** Template method that calls {@link #processLine(String)}. */
public final void processLineByLine() throws FileNotFoundException {
Scanner scanner = new Scanner(fFile);
try {
//first use a Scanner to get each line
while ( scanner.hasNextLine() ){
processLine( scanner.nextLine() );
finally {
//ensure the underlying stream is always closed
scanner.close();
* Overridable method for processing lines in different ways.
* <P>This simple default implementation expects simple name-value pairs, separated by an
* '=' sign. Examples of valid input :
* <tt>height = 167cm</tt>
* <tt>mass = 65kg</tt>
* <tt>disposition = "grumpy"</tt>
* <tt>this is the name = this is the value</tt>
protected void processLine(String aLine){
//use a second Scanner to parse the content of each line
Scanner scanner = new Scanner(aLine);
scanner.useDelimiter("=");
if ( scanner.hasNext() ){
String name = scanner.next();
String value = scanner.next();
log("Name is : " + quote(name.trim()) + ", and Value is : " + quote(value.trim()) );
else {
log("Empty or invalid line. Unable to process.");
//(no need for finally here, since String is source)
scanner.close();
// PRIVATE //
private final File fFile;
private static void log(Object aObject){
System.out.println(String.valueOf(aObject));
private String quote(String aText){
String QUOTE = "'";
return QUOTE + aText + QUOTE;
Jun 22, 2009 | Sun Java Programming Language (cdj-275)
Acer aspire 5562 have no power and won't turn on
what repair shop does work at no cost?? ok first check the voltage from the power adapter, if you have or can borrow a test meter. i have seen these go bad and still seem to work!( incorrect amperage and- or voltage). or you simply have a failed motherboard .good luck !
Jan 06, 2009 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
