Simple comfort 2001
The digital display is blank and the heat does not come on when I move the switch to heat.
2 Suggested Answers
  • 3 Answers
SOURCE: Display is blank. Just moved in to
YES IT CAN BE THAT SIMPLE / CHANGE THE BATTS FIRST AND USE NEW ONES
NOT FROM AN OLD TOY!!
Posted on Oct 29, 2011
Simple comfort 2200 ~ what is the E terminal for? the brown wire is hooked to E terminal
E is for emergency heat which locks out the outdoor heat pump and brings on auxiliary heat when the t'stat is switched to "emergency" . This circuit will also be energized when the outdoor unit goes into defrost.
Jul 02, 2017 | Heating & Cooling
Simple comfort thermostat
most thermostat are plus or mines 5 degree for turn on or off
Jan 29, 2018 | Cars & Trucks
I have a Comfort Zone cz20110 and I need help. The heater will turn on and blow out heat, but the display screen is blank. It was not blank when we first plugged it in however and I know there's a way...
i have a digital quartz infrared heater comfort zone cz20110. does the fan keep running all the time and when it reaches the temp to your room why doesn't it it shut off.
Jan 02, 2013 | Heating & Cooling
When I switch the camera on the screen in blank
when you connect the camera with a cable to the television the screen is blank because that the default settings what you get in camera the television screen acts as a LCD of the camera , when u move your camera to click pictures you get the display on the television screen
Nov 21, 2010 | Canon PowerShot A75 Digital Camera
Blank readings on Carrier Comfort 3 zone thermostat
The stat that works is called the main and the other two are called slave stats. The stats must be set to heat or cool the same as the main. If you want one room to cool and one to heat , sorry. Need to upgrade to auto changeover. Is this AC actally a Heat pump?
Jul 01, 2009 | Carrier 38CKC042 Air Conditioner
Switching thermostats
The two wires are the control circuit from the heater your running. They go to the thermostat and close when it get below the thermo. setting and start the heater.
Jun 28, 2009 | Honeywell Electronic Programmable...
Digital dash lights on 2001 Mercedes CLK 430 CONVERTIBLE
these displays ared l.c.d. displays and what happens is over time the vacuum pack on the crystal element ruptures and get air in the tube and that part of the display is ruined permanently.I'm not sure if your saying that there are pieces missing or if the whole display is blank. If there are peices missing the only way to fix it is to repkace the instrument cluster. If they are blank it is very likley it is either the backlighting bulb or the dimmer switch. If you take a blanket and cover your display and can see the display very dimmly try replacing your back lighting bulbs- hopefully it is just your backlighting because the clusters are about 1,000 dollars and have to be special ordered with your mileage engraved in the new unit.
Jun 18, 2009 | 2001 Mercedes-Benz C-Class
Eror e6100 flashing
error is generic hardware error. normally some part of the infrared or display has malfunctioned.
Feb 02, 2009 | Sony Cyber-Shot DSC-P71 Digital Camera
Sony digital camera dsc s40
code error 61 related to internal lens problum.i think lens movement moter stuckup this is reparable
Jan 13, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Heating & Cooling Logo
74 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
