Fisher 3cd direct access tuner remote - doors won't open and close with open / close button / also looking for a south Florida repair facility - thanks
  • 137 Answers
SOURCE: Remote slide door will not close or open all the way.
there is a cable of wires that lay in the track under the slider they break from normal use.. the harness it fairly easy to change.. when you open the door lok in the opening you will see the harness there in black plastic
Posted on Jan 23, 2009
  • 60 Answers
SOURCE: 2002 honda odessey sliding door
Is it the automatic door?If it is check the fuses
Posted on Jul 12, 2009
ronaldo_ross
  • 1056 Answers
SOURCE: cd tray won't stay open--when
It has a misaligned loading mechanism. I have dealt with this kind of problem before. What is happening is that before the tray have a chance to open all the way it gets stuck and gets pulled back in.
Posted on May 24, 2011
  • 14585 Answers
SOURCE: How do we disable the door ajar chime? My driver
You have to pull the door panel off. Then there are a couple of plugs that go to the door latch mounted on the jam. One of the plugs is for the chime. Pull it, but you might have to put a jumper wire in the plug. I work on a lot of different cars and seen them work both ways. So I am not entirely sure how yours works. Unplug it and if it goes off your done. if it doesn't, use a jumper wire in the plug.
Posted on Aug 22, 2011
  • 3197 Answers
SOURCE: My Liftmaster garage door won't open or close. I hit the button and it make a sound and clicks but won't close
Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad. Tell me - if it won't open how do you know it won't close?
Posted on Feb 22, 2012
I live in Retreat , Cape town . where can I find remotes for this garage door opener units. And what is the cost.
as I live in the US I have no idea what kind of stores are there , but here most home improvement stores carry them .
Jan 29, 2017 | Building Materials
Need to fix door on expedition liftgate won't open
In this case it is usually necessary to remove the interior panels of the liftgate to gain access to the linkage inside. The only problem is: removal of those panels is much more difficult with the liftgate closed. Take to a professional, or risk breaking the attachment points of your panels, and associated fasteners. I usually charge around 50 to 100 dollars to get these open, then an additional charge for further work to repair the lock, latch, or linkage.
Oct 16, 2012 | 2000 Ford Expedition
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Door on Sharp R-K520S won't stay closed.
check the hooks and door release button and repair or replace, when this is broken, the switch is not close the microwave will not START.
SEE the diagram
God bless you
Jul 14, 2012 | Microwave Ovens
Push buttons on remotes won't raise/close lift master mod 81lm
Check to see if the light in the wall control is flashing. If it is press and hold the lock button for 3 seconds.
Jun 13, 2012 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 9902 won't close at times
Does the motor run? Does it make a noise. What actually happens?
Apr 09, 2012 | Sears Craftsman LiftMaster Chamberlain...
DVD player not working.
Hello
The changer mechanism should be suspected. It is a skilled work to look into. You have to disassemble it. There are three microswitches inside the mechanism, which give signals of the state of the mechanism to main system control IC. If the loading gear wheels have some problem, these witches won't engage well, and the the whole mechanism will be inoperative.
Mar 04, 2012 | Panasonic Televison & Video
Feb 22, 2012 | Sears Craftsman LiftMaster Chamberlain...
I have a Sanyo unit (same as Fisher Slim-4000). It was unplugged during a renovation and when I plugged it back in it was making a funny noise. Couldn't get it to go back to CD mode and when trying...
inside the rubber O on motor that controls the door open and close got uncoiled it should look like a side ways 8 and have that twist on it took me forever but i figured out thats why my door wasnt closing not enough pressure on rubber belt to pully u need to just put that twist n it should work good luck!
Sep 14, 2011 | Fisher SLIM 4000 Shelf System
I had to manually close my craftsman garage door and now it won't respond via the remote or the wall button. Chains move but not engaging with door.
Look for a red handle with a rope attached along the bar from the main unit to the door. Pull this handle and release until it engages the track again.
Jul 07, 2011 | Craftsman Sears Liftmaster Garage Door...
139 people viewed this question
 Grubhead
Grubhead
