Question about Olympus DS-30 Digital Voice Recorder
DS3300 when plugged in doesnt automatically download VFs
When plugged in via USB I can see it in the system tray, but the Olympus app. normaly opens and begins to download from the handheld to the folder A that was created upon installation.. Not doing so... I open the software and the device is there and I will then need to go into the folder on the handheld and manually download the VF and then manually convert it to .WAV.. shouldn't be due to the download options are all set to
1. After detecting device, download all audio files
2. After downloading file, delete orginal file
3. Convert DSS files to WAV during download.
can someone please help, thanks in advance
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
Check the services to see if the dm1 service is started
Posted on Dec 16, 2008
Olympus SP500 connection problems to Windows 7 via USB port. Software is unable to find an Olympus digital camera on a USB port on your computer.
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Aug 02, 2013 | Olympus Camedia Stylus 300 Digital Camera
I cannot connect Olympus SP500 via USB port to Toshiba Satellite computer using Windows 7. Error Message: The Software is unable to find Olympus digital camera connected to a USB port on your computer.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
Aug 02, 2013 | Olympus SP-500 UZ Digital Camera
Olympus master 2 disk does not load down from tray; needed is to install Olympus vr-310 camera disk in-order to move pictures from camera to computer file, say disk D or E; could you provide?
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Mar 05, 2012 | Cameras
PORTABLE COMPUTER . EVERY TIME I TRY TO OPEN MY WEBCAM THE COMPUTER REST TART ? WHAT IS THE PROBLEM ????? MY CAM OR PC
if its a usb webcam uninstall the drivers reboot the computer plug in the webcam and if you running windows 7 it should automatically download safe drivers for it . also i would suggest updating your drivers if that doesnt work. make sure the webcam is plugged directly into the computer not via a usb hub i hope that helps.
Mar 14, 2011 | Samsung Computers & Internet
Olympus fe 4000 - when plugged into the computer doesnt work
Is the computer or the camera telling you the battery is bad? If it's the computer, you might have some bad pins on the camera, or your usb cable may have a problem with it. If the camera is reporting this on it's screen, not sure what the problem is there. I would instead, just transfer the pictures to the computer via a card reader through the USB port. Check your printer- many printers these days have memory card slots on them, and you can transfer pics to the computer through them.
Apr 12, 2010 | Olympus FE-230 Digital Camera
Olympus fe-330 no connection to computer
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Mar 25, 2009 | Olympus FE-220 Digital Camera
I want to transfer my photos from Olympus Master to an email. I can't seem to find my pictures the way I used to with my old camera. I used to be able to find the photos in my documents. Please help......
Need more info, but you might be better off just to get a multi card reader for about $20 - $30.
1. Plug your multi card reader to your computer via USB port
2. push in your memory card from your camera
3. Memory card will automatically open, or you can open from "my computer" folder.
Multi card reader will come with instructions anyway.
Oct 08, 2008 | Olympus Cameras
Driver for VN-1100-PC
Olympus has provided new software for VN recorders to used with VISTA plus a few updates.
Uninstall the Digital Wave Player
Uninstall the recorder in device manager
Download and install the New digital wave player,
olympusamerica.com/files/digitalwaveplayer.zip
then go to Olympus america and download all VISTA related updates. Once you have installed and updated the Digital Wave Player software, plug in the recorder and Windows will use the Olympus Driver (not digitally signed) to install and the Digital Wave player software will open automatically.
Feb 22, 2008 | Olympus DS-2300 Digital Voice Recorder
Olympus FE 240 - downloading problems
Remove the Software
Restert the Computer
Plug camera in and turn on set it to the upload mode.
Windows will then fid it via the Camera/Scanner Wizard.
If there is still a problem
A cheap card reader will do the trick
Dec 13, 2007 | Olympus Camedia C-350 Digital Camera
Problems downloading photos from camera
Unless someone else on the forum offers something more specific, I'd be very tempted to borrow a USB cable from a friend and see if using that instead of yours works. (Doesn't have to be from an Olympus camera - anything that has the same connectors on - camera, MP3 player, etc lead will do). A.
Apr 21, 2007 | Olympus SP-500 UZ Digital Camera
Olympus DS-30 Digital Voice Recorder Logo
117 people viewed this question
Top Olympus Audio Players & Recorders Experts
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
