My SONY Audio /video system MHC GNZ7D Music system does not work in DVD position and is showing Please Wait.The tray does not open and the system is not taking any commands.It is working fine in other positions viz.,Tape,FM,AM,etc.Please help.The Lens assembly and 5 belts were changed by SONY service centre last year when we had the same problem.Pls Advise.Tks.Narayanan Shankar
  • 883 Answers
SOURCE: Sony MHC-RV888D - TAPE Recording to Laptop as mp3
on laptop, ensure the following: 1. go to Volume control (look for icon on system tray). 2. under Options tab select Properties. 3. under Adjust volume for recording option, ensure that microphone is is check-boxed if no luck, borrow a second amp and connect your L/R jacks (red and white colour) to the borrowed amps line in jacks and test whether you hear anything to confirm your line out capability.
Posted on May 27, 2007
snakehead
  • 1074 Answers
SOURCE: mhc-gnz88d (sony hifi DVD System)
plug out the dvd and leave it to stand for a day.after the day is out plug it in back if that does not remedy your problem have a tech look at your set.
smarthome2
  • 1114 Answers
SOURCE: dvd not playing.c 31 00 occur
The only thing you can do is get a CD DVD player cleaner with liquid. Found at any store these days, then run it a couple times. If it plays, Problem solved, if not, it must be repaired. They will put a new transport in the unit. Usually runs 100-150 to replace. Weigh the cost to fix vs. the cost to replace and the age of the unit before you get it repaired. Hope this helps
Posted on Jun 02, 2009
SOURCE: sony mhc-mg310av cd changer wont release cd
Check if the tray got a belt and change it
Posted on Oct 02, 2009
toolkits
  • 1099 Answers
SOURCE: HX-D7 DVD Compact Stereo Audio / Video System with 5 DVD Changer Shelf System: my jvc was working fine but all of a sudden it sto...
Hello
this could be a power fault, but first check the power plug if it is in contact with the power socket and if it is then you have to open the back cover of the system to check the fuses if blown resistor,capacitor and transistor with the use of a multimeter to check for back component and if bad replace faulty ones.
Then power on to confirm, if not on then take it to the manufacturer or a skilled personnel to handle it
Posted on May 19, 2010
DVD tray not coming out fully and dvd disc tray not rotating and screeching sound is coming
it sounds like the "Tray" loading belt has stretched, You could try cleaning it, this would prove a point but will need replacing. the belt is small (about 20mm diameter) and is located under the disc tray near to the front, removing/replacing it will require the hifi to be dismantled.
Apr 07, 2014 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
I can not able to open the dvd tray in sony music system mhc-rv777d
If your system was not used for a long time , then there are more possibilities for failure of belt . I have also faced the same problem. Better get the belts replaced in SONY Service Centres
Dec 25, 2013 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
MY MHC-GNZ7D MUSIC SYSTEM ONLY SHIWING PLEASE WAIT , ITS NOT WORKING PLEASEGIVE ME SUJETION
One possibility is that the power-on speaker protection delay is stuck on. The most common cause of this is a shorted transistor in one of the power amplifier channels. In that case, you will need to replace the speaker driver transistors in that channel. I don't have service information on your particular model; it may use power amplifier modules rather than individual transistors.
The tricky part is identifying the amplifier power and speaker output terminals to test for this problem. To find a shorted output transistor, you need to measure the resistance between the output of each channel and the plus, then the minus power supply connections. There is a relay between the amplifier output and each speaker terminal on the back; this relay is turned off by the speaker protection circuit, so you can't measure from the speaker terminals. If you have a fried transistor, one of the tests will show a resistance of a fraction of an ohm. A good transistor will have a very high resistance or read open. This will be the case whether you have modular amplifiers or discrete transistors.
If you see a blown fuse, that is a strong indication that you do have a fried transistor. Sometimes the speaker protector circuit shuts down fast enough to save the fuse, but not always.
Apr 27, 2011 | Sony Audio Players & Recorders
I have sony mini hi-fi mhc-gnz88d now it's displaying DEST ERROR and can't open disk tray or run a CD. how to solve this?
i hv also this problem from yestrday.. all function are ok. bt when playing dvd ... there is 'please wait'error long time. and also tray not open after pressing open or exchange cd also... whats problem.. please help me.. waiting
Dec 25, 2010 | Sony Televison & Video
I have mhc-gnz7d home theater system .and it display showes loked when i press eject switch
Turn unit On and press STOP and EJECT button on unit for 5 seconds to unlock disc tray.
Thanks.
Jun 19, 2010 | Sony Audio Players & Recorders
133 people viewed this question
 Grubhead
Grubhead
