Question about Technics SA-EX320 Receiver
In wich input channel its best to connect my computer?
  • steve Feb 10, 2012
    it is for a Technics SA-EX320 tunjer/amplifier
Wont receive digital channels after scan non found
Hi Patrick,
You must have a UHF / VHF antenna connected to the antenna input of the TV to scan for digital channels. Most new TV's have a threaded, round 75 ohm coax cable connection for this - but yours might even have connection consisting of 2 small screws to connect a 300 ohm twin lead antenna cable instead. Use which ever yours has.
If you are using this input for the input of a cable TV "set top box" (STB), satellite STB, or similar, you will likely only find a single analog channel (Ch3 or Ch4) after a scan as the scan will only find the output of the STB - which is usually on Ch3 or Ch4 - and not be able to scan the STB channels.
Additionally, the antenna input of the TV will only provide a standard definition picture if connected via coax cable from the STB. It will only provide a high definition picture if connected to a UHF / VHF antenna and a broadcaster is close enough for its signal to be received by the antenna. The way to obtain the best possible picture (high definition) when using an STB for tuning channels is to use an HDMI cable between the STB and TV. An HDMI cable will provide the very best picture and audio signals from the STB to the TV; all over a single cable and is the recommended practice.
I hope this helps!
Dec 26, 2014 | Televison & Video
How can I get the best video image quality with Nec np1000 projector ?
Your best option is using the COMPONENT IN input of the projector (Y, Cb, Cr). Though the highest video signal the projector will support is 1080i.
May 09, 2014 | NEC Televison & Video
Cubase studio 5 has deactivated the VST system links due to too many internal errors
In my experience, reasons for seeing errors in VST System Link (VSL) are usually due to the digital signal path (audio and/or data) not being routed properly within the System Link dialog box. If for example, you're using s/pdif between two ASIO 2 compatible audio cards properly (OUT of card #1, to IN of card #2 - then OUT of card #2 back IN of card #1), you also have to set your s/pdif System Link I/O channels in the dialog box to the 'same' channel...If say your options are s/pdif channels 9 & 10 (or whatever they are), you set the I/O's of both computers VSL dialog boxes to either channel 9, or all to channel 10. You of course need to route your digital audio properly within your audio interface! (see your cards documentation on that).
You can test if it's routed properly by 'listening' to audio from each computer, from the other...meaning listen at computer 2, from computer 2 & visa-versa. If you hear the audio thhen it should be correct. But in order to 'hear' the audio (besides proper settings in the VSL dialog box) you must 'also' set those digital audio s/pdif channels within Cubase's VST Inputs/connections. But in 'this case', you use both channels 9 & 10 for your Inputs/Outputs. They also say it's best to place your VSL digital audio channels at the top of the Inputs/Outputs list.
You do not need to keep the s/pdif channels in the VST Inputs/connections to make System Link work however, that's if you need to 'listen' or if you need to test whether it's routed properly.
Getting VST System Link working can seem complicated at 1st, but once you understand, and have it working, you realize it's actually not that hard at all. I recommend taking notes, and writing down what you did to make it work, as you go along the way. That has come in very handy when I need to use it again. Also READ your PDF manual and follow that to the letter!
Oct 08, 2013 | Lexicon Omega Desktop Computer Recording...
Vst system link errors
May 23, 2012 | Lexicon Omega Desktop Computer Recording...
To connect gps to computer wich pins do i connect of nmea cable?
pins 2(-) and 5(+) on a 9 pin serial cable, then you need a usb to serial adapter for input into the computer if you do not have a built in 9 pin serial port on you computer because the usb moves the information faster than the gps signal. gps is roughly 4800 baud, usb is moving so much faster you need a buffer
May 19, 2010 | Furuno GP32 GPS Receiver
How to connect a sr430qx equalizer to abpm500 gemina mixer and a carvin dcm2000
All of three of these components have balanced connections. There are many different ways to connect- but this is the best option. You will need 4 x standard XLR3(cannon) mic leads. Starting from the Gemini mixer:
take the left output and plug it into channel 1(A) of the DOD EQ
take the right output and plug it into channel 2(B) of the DOD EQ
then...
Connect the EQ output of channel 1(A) to the input 1(A) of your Carvin amplifier
Connect the EQ output of channel 2(B) to the input of 2(B) of your Carvin Amplifier
Happy DJ'ing
Rus.
Feb 19, 2009 | Dual Audio Players & Recorders
Tv is not cable ready
You need to buy a cable output to television antenna input adaptor. One end will allow you to connect the cable box output to a cable input. The other end will hook up to you television just like a antenna, on the two screw hook -up. The usually can be purchased at any electronics store, like Fry's, Best buy,Radio Shack. Or you can buy them online. Use google to search cable output to television input adaptor's. Hope this helps you with your problem.
Nov 28, 2008 | TruTech PLV16320 Television
Lexicon Lx-7 buzz sound
Hi chupetin2
If the problem is present with ONLY the speakers connected, that is no other powered devices like subs, or input/output cables, it will be a power supply problem inside the amp. If you have electronic fault finding skills, there will probably be a capacitor in a regulated rail that has failed.
If you do have a sub connected, be sure it is powered from the same mains source as the amp, or at least a GPO that is on the same phase. Different phases will induce mains hum, as will multiple earths. Try also temporarily moving the amp(whilst monitoring the hum) from where it is sitting and see if the hum is being induced into the amp by any other devices
Happy to talk to you more about this. Just ask:)
regards
robotek
Aug 18, 2008 | Lexicon LX-7 7-Channel Amplifier
Pioneer vsa e06
depends what audio outputs you have on the sky box,analogue (two phono usually red for right channel and white left channel)in which case just use phono leads to the phono inputs,Optical(toslink),connect an optical cable from the output to the optical input on the dvd channel of the pioneer,coaxial (spdif)connect to spdif input on the laser disk input of the pioneer,dont connect to the attenuated spdif.In the unlikeley event of the sky box not having any audio outputs,just use the outputs from the tv to the pioneer.The optical digital input gives the best quality on the vsa eo6
Jan 24, 2008 | Pioneer VSX-1015 Receiver
Input for cable
Most tv's dont need to be on an input for cable. Just channel up and down or change from LIne1 or Input1 to TV or CATV.
Dec 10, 2007 | Televison & Video
29 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
