Panasonic TX-21GV1 television Remote control eur511200 When i press set up it brings up the menu but wont let me move up and down to change any settings and i need to go down to vcr settings as the timer (rec) is flicking and making a loud ticking noise.
techman
  • 3130 Answers
SOURCE: Panasonic PT-47WXD63G
If you have a problem with the convergence, believe me, going into the service menu and trying to correct it will only give you large headaches, DO NOT USE THR SERVICE MENU UNLESS YOU ARE A TRAINED TECH!!!! Doing so can result in a complete and total failure of this TV set. I service menu is not for any major changes in any adjustment. It is not the cure all. If your convergence all of a suddenly shifted, it is not a service menu issue. Your problem is the convergence amp IC's. Good Luck
Posted on Aug 12, 2007
SOURCE: How to fix my 54" Magnavox rear projection tv
ACS module is bad hard to find vertually impossible, throw away your tv buy a new one.
Posted on Oct 09, 2007
ctf1800
  • 4402 Answers
SOURCE: hitachi ultravision digital projection television
First try a hard reset to see if that will unlock it. Unplug the power cord for 1 hour; the power
Posted on Jan 08, 2008
  • 38 Answers
SOURCE: Using Intellisense without remote
some of the universal remotes by phillips have but not all have the program inside the remote for it u have to look on the box u can allso call magnavox witch is the same thing and ask customer service if the have a universal remote that will do that for u i hope this hp some
Posted on Oct 13, 2008
SOURCE: Service Remote
Sorry, I'm not a problem solver. I had ask a question myself several month's ago that went unanswered. My tv is a LG RU44SZ63D. Through my own diligence I discovered that the special set-up remote for accessing the service menu is a 105-201M. I have no idea how many different model tv's this remote works on. I purchased the remote from www.newremotecontrols.com. It "IS" a tool and unfortunately doesn't come with instructions...
Posted on Oct 21, 2008
How do you remove the self check on a panasonic viera 37 in lcd tv?
Hello:
This procedure will bring up the self test screen and reset the unit to factory settings for you.
First produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote control for more than 3 seconds.
Oct 10, 2011 | Panasonic Viera TC-37LZ85 LCD TV
Tip
Service menu codes panasonic
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes.
Panasonic TV's after 1996 can be set to "Serviceman Mode" with the
following remote control sequence:
-select the SET-UP icon and select CABLE mode.
-select the TIMER icon and set the SLEEP timer for 30 minutes.
-press the ACTION button twice to get out of the menus.
-change to channel 124.
-adjust the volume to minimum (0).
-Hit the VOL down button on the TV itself (not on
the remote) and a red "CHK" should appear in the upper corner.
-press the ACTION and VOLUME DOWN buttons (again, on the
TV, not the remote) you will toggle between AGING and SERVICEMAN modes.
Select Serviceman mode. The POWER button on the remote control will
select one of the five Serviceman Adjustment modes.
The modes are:
B - Serviceman VCJ SUB Adjustments. These include sub-tint,
sub-color, sub-brightness, sub-contrast, colorkiller/ABL/gamma,
audio and video adjustment, and vertical size.
C - Serviceman VCJ Cut-off adjustments. These include Red, Green
and Blue cut-off, red and blue drive, automatic fine tuning
(AFT), RF AGC (RF gain control), horizontal center, beam limit,
etc.
S - Serviceman Options Adjustments. These involce the PIP and
clock.
M - Serviceman MTS (Stereo/SAP) adjustments.
CHK - the mode you first entered. Normal picture and sound, lets
you check things over and still have a hotkey into the
service menu.
There is one more adjustment that isn't in the five modes, it's
global. When in either the yellow or red CHK mode, you can press
RECALL on the remote control to enter the purity field check mode.
This lets you select a pure white, red, green, or blue screen. A
good thing to walk away from if you just want to temporarily freak
out the floor manager, but it will be fixed as soon as the TV is
turned off. Oh well.
To get out of Serviceman mode, press ACTION and POWER on the
receiver simultaneously for at least 2 seconds. The TV will momentarily
shut off and then comes back on.
PE77U / PX75U / PX77U / PZ700U / PZ750U
PD60U / PX6U / PX60U / PX600U
PD50U / PX50U / PX500U :
* Hold down the {VOL -} button ON THE PLASMA TV.
* Press the {RECALL} button 3 times on the remote.
* The Service Menu will be displayed.
* Use {1} {2} on remote to navigate main menu items.
* Use {3} {4} on remote to navigate sub-menu items.
* Use {VOL+} {VOL -} on remote to change item value.
* Write down all values before changing
Once a value is changed, THE CHANGE IS MADE.
* Power off to exit service mode and save.
PA25UP / PD25UP / PX25UP :
* Using the remote control:
* Press the {MENU} button.
* Set "Antenna A" to "Cable".
* Select "Timer" menu and set sleep timer to 30 min.
* Press {OK} twice to exit menus.
* Tune to channel 124.
* Press and hold {VOL -} button ON THE PLASMA TV.
"CHK" appears in on top-left corner followed by 5 letter/numbers
(which are the cumulative hours in hex numbers)
* While the "CHK" is displayed, press the {OK} and {VOL+} buttons
ON THE TV simultaneously to toggle between Modes:
?ƒ?¢?¢?€??¬?¢?'¬? Red "CHK" for Serviceman ?ƒ?¢?¢?€??¬?¢?'¬? Yellow "CHK" for Aging ?ƒ?¢?¢?€??¬?¢?'¬?
* Press the {POWER} button on the remote to select one of the six
Serviceman Adjustments Modes.
A. MTS ADJUSTMENT
B. CLOCK ADJUSTMENT
C. VIDEO ADJUSTMENT
D. HDEF ADJUSTMENT
E. VDEF ADJUSTMENT
F. DAF ADJUSTMENT
G. OTHER ADJUSTMENT
* Press {CH+} {CH -} on the remote to select the settings
on each of Service Adjustment Modes.
Write down the original values before modifying anything.
It's easy to erroneously adjust the wrong item.
* Press {VOL+} {VOL -} on the remote to change values.
* Press the {POWER} button on the TV to exit the service menu.
LCDs / CRTs / RPTVs :
* Hold down the {VOL -} button ON THE TV.
Model PT45LC12:
1. Press and hold Vol Dn on center panel and press recall button on remote until Work Mode is displayed on screen.
2. Press and hold Vol Dn on TV and Swap button button on remote until Factory Adjust is displayed on the screen
3. Use Channel Dn button to select Digital and press the Action button.
PROJECTORS :
* Go to "Options" menu.
* Highlight "OSD".
* Then press and hold the {ENTER} button,
until the Service Menu is displayed.
* Press the {MENU} button to exit.
on Apr 29, 2015 | Panasonic Televison & Video
Tip
SERVICE MODE AND POWERS SUPPLY CIRCUIT
PANASONIC TX-20LA80F - TX-20LA80FS
White Balance Adjustment
Instrument
• Remote Control
• LCD WB meter (Minolta CA-210 or equivalent) Condition
• Switch on the TV Set. Enter Service1. Step down to Highlight line and keep the aging time more than 20 minutes.
Procedure
• After aging time above set White Raster No.12 for Highlight and No.4 for Lowlight Press the OK button to store.
• Put Minolta Sensor to the center of the LCD Panel with 25mm gap between Minolta Sensor and LCD Panel. Adjust "x" and "y" values by changing Red and Blue values.
• Press OK button to store setting.
TO KNOW MORE CHECK THE LINK BELLOW
http://electro-medical.blogspot.in/
google.com/+AjinGopakumar
on Feb 18, 2015 | Panasonic Televison & Video
I have a panasonic viera and it is stuck on the PC channle and wont change how do i change it or restart my tv entirely?
Are you using the remote's AV button or the AV button on the TV? Do the other buttons on the TV work? (If the control board has failed, then the remote won't work nor will the input button.)
Are the cables for other devices connected and were the devices connected and off when the TV was turrned on? Are they on when you try to change the input? Bad cables may limit the sources the TV will allow you to select. Some will not go to an input that isn't providing any signal.
You can try resetting the TV to the factory specifications (you'll lose the channel programming though). Press Menu > Setup > Shipping Conditions
The manual is available here: http://www.retrevo.com/support/Panasonic-TX-32LX70-TVs-manual/id/2920dj480/t/2/ if you need it.
I hope this helps.
Jan 01, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
Need a clone box for multiple Panasonic ct 2522 he televisions
You can get your Panasonic Tv out of hotel mode with the Regular remote control you got with them.
Please follow the steps below.
Press and hold the V/- button on the tv itself.
while you are holding this button down, with the Panasonic remote you got with them press the AV button 3 times.
This will bring up a hidden Installer Menu this is where you can take off the HOTEL MODE. and set up your owe setting.
While you are in this mode, be very care you are not switching things off that you are not sure what they are. as this may put a spanner in the works
Hope you get this all sorted out.
Little Dish Fitter
Please leave a thumbs up if this sorts you out....
Jun 29, 2009 | Panasonic ET-RM100 Remote Control
Tip
HOW TO ENTER SERVICE MODE MENU TO PANASONIC TVs
This is the way to enter service mode menu to most of the Pansonic TVs.
1. Press and Hold Down the [Vol-ve] key, on the front panel of the TV set.
2. Press "Recall" button on the remote control three times.
The service menu window will appear.
3. Use digits [1] & [2] keys on the remote control to navigate Main Menu items.
4. Use digits [2] & 4] keys on the remote control to navigate sub Menus.
5. Press [Vol+ or Vol-ve] keys on the remote control to change the data value to selected item.
6. Power OFF the TV, by its main Power ON/OFF switch to save the adjusted value into memory and to exit from service menu. When you switch ON the set for the next time, it will come alive with adjusted parameters.
on May 20, 2012 | Panasonic Televison & Video
Need to reset owner ID on a panasonic tx-32lxd
Service Mode Function
MPU controls the functions switching for each IICs through IIC bus in this chassis. The following setting and adjustment can
be adjusted by remote control in Service Menu
How to enter SERVICE
In main menu, move to choose sound menu, set BASS to MAXIMUM, and set TREBLE to MINIMUM.
Simultaneously press " i " button on remote control and DOWN button (-/v) on the TV set.
Exit with off switch on tv.
When you next switch on TV it is as brand new giving you the option of setting pin number and user ID.
Mar 05, 2009 | Panasonic CQ-VD7500U 7 Wide LCD/DVD/SD/TV...
Panasonic NV-SJ205 Changing Rf ?
ok. This is a really easy one.
All you have to do is hold down the menu button on the remote control for more than 5 seconds, If that doesnt work hold down the power button on the remote control for more than 5 seconds. If that doesnt work hold down the power button on the actual vcr unit for 15 seconds. The first method should work for Panasonic's fine.
This will then display your current rf output.
You can then change the output by using the up and down arrows or the channel up and down button on your remote or the vcr unit.
Press menu button to save or the same button you used to bring up the rf opposition eg power button on remote or the unit.
all the best. Top tech
Sep 02, 2008 | Panasonic NV-SJ205 VHS VCR
Code
Hi
I have a Panasonic viera TX-32LMD70 TV and a Panasonic
remote control. I also have sky and I cant use the sky remote
control for the sound when I try to change it asking for the code
and I do not have any for the panasonic remote how came with the TV when I bouth it. Can you help me.
Thank you
Gill Plimmer
Aug 18, 2008 | Panasonic VIERA TX-32LXD80 32 in. HD-Ready...
Panasonic Projection TV
6.1. How to enter SERVICE 1
1. In sound menu, set BASS to MAX, and set TREBLE to MINIMUM.
2. Simultaneously press INDEX button on remote control and
VOLUME DOWN button [ - ] on the TV set.
6.2. How to enter SERVICE 2
1. Set the channel to CH99.
2. Press HOLD button on remote control.
Jul 24, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
