Question about Tunturi T90 T90 Series Treadmill
My tunturi t90 stop work it appeir on the screen system check failed
I dont undastand the question
My tunturi 620p has a e2 code how can i fix it
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. check for tunturi treadmill articles
http://electro-medical.blogspot.com/
Feb 23, 2016 | Tunturi Exercise & Fitness
I have just purchased a Tunturi T85F. While running ( not on any program ) it stopped with Motor Overload shown on the screen . Any idea what the problem is ?
The motor is not turning at correct speed and is drawing too much power. Shuts down to protect it from burning out. Check the drive components for excessive friction .
Dec 26, 2015 | Tunturi Exercise & Fitness
Not working after initial start up.
is the new outlet the same as the old or did you put a adapter on the plug? sometimes if the machine does not "feel" the ground, it wont come on.. its a safety thing..
Mar 08, 2014 | Tunturi T60 Folding Treadmill
System check failed
  • Press the "On/Off" switch to turn the treadmill off.
  • 2Unplug the power cable at the bottom, base of the treadmill.
  • 3Push the safety switch in.
  • 4Plug the cable back into the treadmill and set the "On/Off" switch to "On."
  • ssincerely. Merry Christmas.
    ERNESTO CUADRAmanagua, nicaragua
    Dec 26, 2011 | Tunturi T80 Programmable Treadmill
    Speed sensor error
    Your speed sensor may have failed and cause this condition Call Accell Fitness Of North America @ 1-888-388-6887 they are the Tunturi Distributors
    May 04, 2010 | Tunturi Programmable Treadmill with...
    Problem with power point
    These devices get hot when they work. they need cooling. if the cooling system get dirty and fan cant turn clearly then it stops itself for protection.  it need to be cleaned.
    hope it works
    May 28, 2009 | Toshiba TDP-T90 Multimedia Projector
    Canon T90 eee
    I don't have a T90 or an FD lens, so can only guess what this means. This is quoted from the T90 manual:
    "When you use the stopped-down AE mode with the FD lens, do not push in the stop-down lever with the lens set at the "A" mark. If you do, "E" marks indicating an error will appear to warn you of incorrect operation (EEEE EE in the viewfinder and EEE on the display panel), and the shutter is locked.
    In this case, either push in the stop-down lever again to clear the stopped-down AE or remove the lens from the "A" mark. The error display will then disappear."
    The stop-down lever is on the lower left front of the camera, and is what is usually now called the "depth of field preview" button. The "A" mark is the setting on the lens for fully automatic aperture control.
    Jan 02, 2009 | Canon Cameras
    COLOUR MISMATCHING
    befor going anywhere change vga cable between pc and projector.-and run video source from anywhere and check colour mismatch.if you got mismatch from both pc and video go to menu and make some correction to colour . if all failed you have to pass it to service center.
    Jan 29, 2008 | Toshiba TDP-T90 Multimedia Projector
    Tunturi T90 T90 Series Treadmill Logo
    51 people viewed this question
    Top Tunturi Exercise & Fitness Experts
    Electro Med Services...
    Shehu Pro
    Shehu Pro
    Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
