Question about Kenmore 15516 Mechanical Sewing Machine
Thread snagging on shuttle
...I believe that is the name of the pices that the thread is snagging on - see pics below - the first shows the underside of the garment once snagged bunch of thread is removed from the assembly. The next pics (in reverse order) shoe the thread snagged up in the assembly, then as I take the assembly apart to remove the "birds nest" of thread that has built up. It's like the bottom stich is not leaving the assembly, but gets snagged (as does every stich to follow) please assist if you can!
  • chefneil Oct 24, 2008
    Yes - it is a problem w/ the needle thread tension - but I had to temporarily "solve" this issue by wrapping the thread around the bobbin-winding thread tensioner (atop the machine, which you loop the thread around from the original thread spool to the bobbin when winding the bobbin) - this is just a fix to finish the job I am on, but longer-term - it seems the needle-thread tensioner has stopped working (and I would further guess that many other posts for the same issue are also a result of this) A previous post mentioned "cleaning" the tensioner out - tried this, but still seems like no dice....(still doesn't work) and I found nothing "stuck" in there - could "cheap thread" have damaged the tensioner? So - any suggestions short of diassembling the whole machine or taking to a repair shop (@ $40/hour + parts! yikes!) Thanks so much again, MissFlossie & FixYa!
    New Friend:
  • 46 Answers
Maybe I sticking my nose where it doesn't belong but this looks like a simple threading problem. Be sure that the thread is in the TAKE-UP lever. There are four thead guide the thread must pass through. From the spool through the first thread guide at #1 than straight down to #2 than up to #3 throught the take-up lever and straight down to the left of the needle and throught hte neele form fornt ot back.
If the thread is not in that take-up lever the machine will not have any top tension (or be regulated) it will flood the machine with thread and wrap around that bobbin.
Also, be sure have you presser foot int he up position while threading this way the thread will surely pass through the tension disks, Set your top tension at 4, use good quality thread (get rid of the dual duty or all purpose) All of these steps will ensure a perfect balanced stitch.
Bonnie
Posted on Nov 06, 2008
  • 46 Answers
My first guess is a tension problem, my second guess is you could be using cheap thread. Sewing machines don't like cheap thread. But check out your tension first.
Posted on Oct 24, 2008
  • MissFlossie Oct 25, 2008
    ah, it looks like you'll have to take it to a repairman. but if you're using cheap cotton, don't. it's not worth it.
Singer Futura XL-580 thread tangles on underside.Machine makes a loud "clicking" sound.Was doing free motion quilting and got a jam. Changed needle,changed bobbin,and rethreaded both top and bobbin.
Sounds like there might be some thread stuck in the bobbin shuttle area. Refer to the users manual for your machine to see how to disassemble the bobbin shuttle and race to check for thread. It would be a good idea to put a drop or two of sewing machine oil on it while you have it apart.
Aug 21, 2017 | Singer Sewing Machines
Thread keeps breaking.had it serviced reciently.thread and tention correcthelp
1. Replace needle
2. Get good thread. One without fuzz. Usually embroidery thread is better quality.
3. Adjust the bobbin carefully. I've enclosed a guide how to do this.
4. Thread the top while the pressure is up. While threading the machine give tugs to check for snags. If there are any snags you must fix them first.
5. Check the needle to ensure it is installed the right direction. Thread the needle.
6. Adjust the tension to four. Pull just a little bit to see if the tension is a little or way too much which won't allow the thread to flow at all.
Once the tensions have been set correctly and there are no snags the sewing machine should run smoothly.
Jul 24, 2015 | Sewing Machines
Brother innov-is cs8080. Tangles underneath all the time Sometimes top thread wraps around the shuttle. Will not move forward. Have cleaned shuttle and changed spool but still not difference. Could...
Check your bobbin threading tension (is bobbin thread loose on bobbin?); check needle thread tension (does it snag or jump when feeding?)
Be sure bobbin case, etc. is properly installed in shuttle housing.
Aug 29, 2013 | Brother Sewing Machines
My Singer 3116 Simple is tangling up by the bobbin and leaving knots of thread on the underside of material?
Thread it right...with the lever up. Then adjust your top tension.
If you still have problems check the bobbin carrier/shuttle for burrs. If you find burrs carefully sand with fine grit sand paper.
Sep 19, 2012 | Singer 3116 Simple
My shuttle race is tight and it is gathering all the threads.
what the name & model number of the machine?
try taking out the shuttle race & then putting it back in
also change the needle
clean under the needle plate & in the bobbin area for lint & thread
May 01, 2012 | Sewing Machines
I get major tangles with lower thread and cannot sew. I've cleaned the shuttle and machine, changed needle, thread, bobbin and wonder if the shuttle is damaged....How could I tell? If so, is a...
It could be a mechanical problem but before you do more first check your UPPER tension. If the upper thread tension is too loose and the bobbin tension is tight you can get looping on the underside of the stitch. So pull on the upper thread and feel if there's tension there. You can try to increase the upper tension and see if that helps.
Jun 19, 2011 | Brother CS-80
I was sewing on my Consew 206Rb-4 when the thread jammed in the shuttle area. I have removed the shuttle, needle, and pulled what thread I could see out. Turning the wheel to raise the needle is not...
There is still thread binding in the bobbin area. My advise is the remove the bobbin shuttle, I believe there is still thread locking your machine up. This is not an easy task and whatever you do don't lose the small screws. I can talk you through this the best I can, but if you are not comfortable taking the the bobbin shuttle out, please contact a commercial sewing machine repair shop.
Apr 19, 2011 | Consew Sewing Machines
Top thread won't catch the bobbin thread
First check the upper and lower tension adjustments according to link below and then check the knob (bobbin case) that makes the bobbin tension which lies inside the shuttle if it is too loose. Restricted it with the sheet metals around it so that it shouldn't move so freely up and down or back and forward. Be careful it should move freely a little but not too much.
http://www.wikihow.com/Adjust-the-Tension-on-a-Sewing-Machine
@ytac...
Feb 24, 2010 | White Sewing W3300 Computerized Sewing...
I need to know how to clean and oil the machine
From the Sears Kenmore manual:
Using a small brush, remove the lint that accumulates in the shuttle area and around the feed dogs.
To Clean the Shuttle Area:
  1. This area must be kept free of dust, lint and occasional tangled thread. Raise the needle bar to its highest point and remove the bobbin case.
  2. Push levers of shuttle race aside and lift shuttle race cover and shuttle out.
  3. Clean the shuttle race with a small brush.
  4. Put a drop of oil on the center pin of the shuttle and shuttle race.
Jan 25, 2010 | Sewing Machines
Shuttle
The bobbin should be placed in the shuttle, with the needle at the top end travel. You can watch the shuttle move as the hand wheel is turned.
Jul 09, 2008 | Sewing Machines
Kenmore 15516 Mechanical Sewing Machine Logo
407 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
