Question about Juki Sewing Machines
Skipping interlock, the thread are skipping - Juki Sewing Machines
  • Juki Master
  • 7,365 Answers
Skipped stitches
1. Is the needle bent
2. Is the needle inserted correctly
3. Is the machine threaded correctly
4. Is the pressure foot pressure right for the fabric?
5. Needle or thread are not suitable for the fabric
Posted on Feb 11, 2012
Why does the stitches skip when I'm sewing?
Needle old or bent, incorrect size. Incorrect thread for material, packed with lint. The sewing foot is not on correctly or the needle is not pushed in high enough. Old thread. Hope this helps.
Aug 19, 2017 | Sewing Machines
My machine is skipping stiches it seems its not picking up from the bobbin
Install a brand new needle and confirm it is inserted with the flat side facing the proper direction.. A bent, damaged needle will sometimes cause skipped stitches or even needle strikes inside the machine. A new needle is the least expensive cure for a lot of sewing machine problems. The needle should be changed about every 8 hours of sewing or at least when starting a new project.
Remove the top thread. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Sometimes, skipped stitches will occur if the needle, thread, and fabric are incompatible. Be sure to use the correct needle for your project. Use a good quality thread--AVOID old or bargain bin thread!
If the machine continues to skip stitches, then it may be out of time. Search for sewing machine timing or take it for service.
Basic Maintenance Tension Skipped Stitches
What to Do If Your Sewing Machine Is Skipping Stitches
Don Ignore Your Sewing Machine Skipping Stitches Simple Solutions
May 24, 2017 | Sewing Machines
My pfaff hobbymatic 875 is skipping thread on the bobbin side
Be sure to use a brand new needle. If the needle is bent or damaged, it will frequently skip stitches. Also, if you are using the incorrect needle for the fabric & thread you are using, it will skip stitches, ie a ball point needle on woven fabric.
All About Needles
10 reasons for skipped stitches
Oct 21, 2016 | PfaFF Sewing Machines
Skip stiches
Changing the needle may be helpful. A bent/damaged needle will tend to not pick up the bobbin thread properly.
Try a different type of thread--avoid old or bargain bin threads.
Could also be an incompatibility of the needle, thread, and fabric.
All About Needles
If it still skips stitches, then it may have a needle/hook timing issue that would require service.
Aug 19, 2016 | Sewing Machines
Hi, I just need to know how to thread this machine properly or, where can I get a manual please?
Search the internet for:
Make + Model + the word "Manual"
or contact manufacturer support. Most machines are threaded similarly, so even if you can't find a manual for your model, a manual for a model similar to yours will be helpful.
You can also search YouTube videos for threading instructions.
When threading, be sure to always raise the presser foot during the upper threading process. This releases the tension disk and allows the thread to seat properly.
For skipped stitches, try installing a brand new needle.
May 19, 2016 | Sewing Machines
Skipped stitches
lower your needle. If up to high can't catch the bobbin thread.
Aug 31, 2017 | PfaFF Tiptronic 2040
I have Usha allure,sometimes it gives skipped stitch,and sometimes it gives bunches at the bottom. If I use thin thread for interlock, it dosnt accept, what is the solution?
Sounds most likely to be either thread tension issue - check bobbin tension OR dull / bent needle - put a new needle in suitable for fabric being sewn. Use good quality thread.
Oct 13, 2013 | Sewing Machines
Elna 1500 sewing machine stitches dont interlock
it's possible that the machine is out of time
you can check with youtube or fixsewingmachines.com for video's on the problem
Apr 09, 2012 | Elna Sewing Machines
How to thread euro pro serger. threads aren'y interlocking
If the thread guide in printed on the side of the door or on the machine, you will need to follow the threading sequence.
Turn off the power.
Raise the thread antenna to it's highest position.
Open the tensions (set at zero). If the serger has automatic tensions, raise the presser foot as this also opens the tensions.
Turn the handwheel so the loopers are at their highest position.
Begin threading from the right to the left - lower looper is usually the first to be threaded.
After threading, set the tensions back to the normal setting and stitch a chain of thread and it should be knitted/interlocking.
Mar 23, 2010 | Euro-Pro Sewing Machines
Sewing Machines Logo
109 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
Derek Massey
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
