Paper getting jammed when rotate sort
We have a e-studio 233 and when we try to set the machine to rotate-sort the paper from the lt-r drawer gets jammed in the machine. Is the paper even suppossed to come from there when we have it set on lt ?
This is the second time this has done this and the first time we had to call a service guy out and he pushed some buttons and it worked right but with 25 people using the copier I need to know how to fix this when they mess it up.
Thanks!
  • 134 Answers
To clarify LT and LT-R are both 8 1/2" x 11", most models of Toshiba will ask what size paper are in the drawer when they are open and shut,. if you have LT paper (landscape) in a drawer, but tell the machine it is LT-R (portrait) when it tries to feed it will jam because it "senses" you are missing 2 1/2" of paper. So make sure your settings are correct, in my experience this is 90% of the jamming issues on Toshibas. Rotate sort uses both drawers to interleave the LT & LT-R into "stacks" so they must be opposite directions but corresponding to correct direction (portrait, landscape)
Posted on Aug 05, 2009
I need help wth a Toshiba e studio 181 it refuses to pick up A3 paper nd wen it does it jams?
make sure drawer is set for a3 if not push user interface button then drawer and set the drawer for that size and be sure you actually have a3 size paper this is not a common size of US paper
Jun 07, 2017 | Toshiba Office Equipment & Supplies
"Toshiba e-studio 166" raining day,cold
this is the problem of humidity.try not to keep paper in the drawer overnight.place a bulb ina box and then put papers in it to get heated.try always to use fresh **** of paper
Aug 02, 2011 | Toshiba e-Studio 161 Copier Copier
How to change paper setting LT-R
Hi:
Press the hard button that says User Function. Then on the touch screen press the button that says drawer. Select the drawer you wish to change. Then select LT-R . Next set your drawer paper stops to fit the LT-R. paper and you should be all set.
Andrew
Feb 10, 2011 | Toshiba e-STUDIO 282 Black and White...
Make A3 Copy (Toshiba Studio 206)
If your copier didn't set any A3 drawer, then u need to insert A3 paper on bypass unit, on left panel select A3 (Original) to A3 (copy) b4 u press the start button. Otherwise paper jam will occur.
Apr 05, 2010 | Toshiba e-Studio 205 Copier
Toshiba e-350 paper jam
rebuild the fusing assembly
Aug 10, 2009 | Toshiba e-Studio 350 Copier
Paper Error
The paper lift housing is cracked. The clicking noise is made by the lift gears skipping teeth.
It needs to be serviced...in the mean time, you might try feeding 11 x 17 paper through the manual feeder (bypass tray). Or if you need many 11 x 17 copies, it is possible to set another paper drawer to 11 x 17 size...just set the plastic tag in the front of cassette to LD so the machine knows what size of paper to expect (if tag is set incorrectly, machine will jam EVERY TIME)
Jun 10, 2009 | Toshiba E-STUDIO 450 Copier
Setup photocopier wirelessly
To change paper size setting, press the user function-->user-->drawer. In order to do network printing using network port (RJ45), u need to make sure printing kit (GM107x) is installed on your machine. It looks like an thumb driver. But u can also enable the 60 days trial periods in order to try out the network printing.
Jun 03, 2009 | Toshiba e-Studio 232 Black and White...
Error code on Ricoh FT5733 copier
Open ALL paper jam locations on the machine. The jam code only means the paper jam is somewhere BEYOND the paper drawer. Check ALL jam locations including duplexer, bypass, and ALL paper drawers.
Nov 12, 2008 | Office Equipment & Supplies
Toshiba Studio 200 CP
Use the manual paper feeder, and set the paper type labels
Jun 18, 2008 | Toshiba e-Studio 200 All-In-One Laser...
Paper Jam
hi im jules_09.have you reassemble the fuser correctly?check again the inside of the machine for small pieces of paper its just there the machine wont flash the misfed if there is nothing stock in the machine.although sometimes the drum can cause the misfed,try to full out the drum.it cant be stock just see if the drum is rotating try to rotate it 360 then slowly full it out,also check if there are srews where the drum process unit is at
Oct 12, 2007 | Toshiba E-STUDIO 650 Copier
jasbo
jasbo
