Question about Air Tools & Compressors
Rigid air compressor reset button keeps popping
Starts and trips the reset button within a few seconds
  • 21 Answers
SOURCE: clarke hunter 60 2.5 hp compressor , trip switch keeps tripping
if you are talking about the brass valve with a small pin in the middle.it leaks untill the pressure get to 15-25 lbs then the pin pops out and stops leaking and the compressor pumps to pressure. this is normal that valve it a cold start valve that allows the compressor to start with out binding
Posted on Dec 26, 2008
digritz
  • 530 Answers
SOURCE: runs 3-5 seconds and then the breaker trips
The problem could be caused by one of several issues.
  • Cold compressor
  • Extension cord
  • To main items using the same circuit as the compressor
  • Faulty unloader valve.
First one's easy. Depending on where you live if it's cold it means the compressor's oil is cold also. I need to place a small space heater near my compressor to warm it up or the same thing happens to me.
Another issue is the use of an extension cord. Normally Air compressor manuals warm against you using any extension cord. They recommend using a longer air line instead. If you must use one you need to over due it on the size or gauge of wire used. The best place to get good grade cord is from boat supply shops. Ask for shore power supply line. Even using this you should still limit it to no more the 20 feet.
How about you circuit you are using? Air compressors should be on a dedicated circuit. Even though you may have a smaller compressor you should consider creating a dedicated circuit for it. Even small compressors draw a lot of power.
The unloader valve is what bleeds the pressure that remains in the cylinder head and line all the way to the tank check valve. If this fails to bleed off this pressure then when your compressor starts it can be working against as much psi as the max. To check this simply bleed off all the tank pressure using either the water purge at the bottom or the safety relief valve. You may also need to loosen the line coming off the pump manifold to the tank check valve. Just enough to bleed off any exes psi. Now try it. Let it run through a complete cycle. If the problem repeats you may need a new unloader valve.
If you live in colder climate.
My personal guess is that your compressor is just too cold. Compressor oil is normally straight 30 weight. It has no ability to increase it's viscosity during the winter. So bring it inside or place a spae heater hext to it for 10 to 15 minutes. Then give it a try. Once you start using it it will be fine again until it set out in the cold to long without being used.
Do you have a dog? If so just move it in to his house and tell him it's for guard duty. Say it with a straight face or he will wiz on it as soon as your back is turned. ":-}
Hope this helps and "Happy (fill in you personal preference here)" To you and your.
Let me know if you have any more trouble with it.
Posted on Dec 21, 2009
  • 885 Answers
SOURCE: im plugged directly into a good outlet no
If you are plugged into a 10 amp circuit or if the line from the circuit breaker to the outlet is long or 14 guage wire, it could possibly still be the outlet. Try plugging the compressor in to an outlet closer to the circuit box to see if the problem persists.
On the compressor the only thing that would create problems like you're describing is excessive friction in the moving parts. Check where two parts that move together are not doing so without excessive wear or heat. Check to see if the motor is turning freely, the eccentric to connecting rod joint should be free moving and smooth and the piston in the cylinder should be tight but smoothly operating.
Posted on Feb 01, 2011
  • 3 Answers
SOURCE: the compressor reset button trips
Where is the reset button located
Posted on Dec 27, 2011
  • 7 Answers
SOURCE: My speedaire compressor hasn't been turning on
Sounds like the release valve is not working. When the compressor shuts off, you should hear a slight hiss, draining residual air in the cylinder. If the motor starts up and can't rotate, it will blow the breaker. When you rotate the pulleys, you take the load off giving the motor a fighting chance.
Cabinetman54
Posted on Nov 19, 2009
What would cause my emerson quiet kool air conditioner 10GC13-L to keep tripping the breaker?
It probably has something shorted to ground or the compressor or motors are stuck causing a high amperage problem. The breaker is probably fine but it also could be weak but normally its the compressor or a component has faulted to the compressor. If the unit immediately trips breaker its probably shorted to ground. If the unit struggles to start and a few seconds pass before it trips then it may be a component fault.
Jun 09, 2015 | Emerson Quiet Kool 10GV13 Air Conditioner
Htachi ec89 Thermal Protection trips
Its your reset button on the compressor that's bad! I have the exact same compressor (EC89) and it did the same thing! Compressor would run great for 15-20 seconds, then trip the reset button. I ordered a new reset button off e-bay, replaced it, and it works fine now. Good overall compressor! but has cheep china electronics installed. just replace the reset button and you will be good to go....cheep fix!!!
Sep 01, 2012 | Hitachi EC89 4 Gallon Twin Stack Air...
Trips thermal overload. power source ok. oil ok
Several things to check. Amp draw to be within number on plate, if amp draw not correct check capacitor, should be within 5% of rating on cap.. If amp draw about right and cap reads good suspect faulty breaker. If amp draw high and cap. good check for leak at in-tank check valve. With pressure in tank remove hose at check valve spray soapy water. If check valve good, suspect reed valves leaking. If reeds are leaking the compressor will take longer than normal to fill and the discharge tube/air will get very hot. It is recommended to note the amount of time it takes to fill tank when unit is new and compare this as unit wears. Length of time to fill is an indication of how well unit is working. A combination of leaky valves and leaking fittings as well as leaking checkvalve will cause motor to overheat.
Oct 03, 2010 | Hitachi EC89 4 Gallon Twin Stack Air...
The compressor suddenly trip off and it runs and after few minutes it trip off again
Compressor tipping is typically due to overheating. A single bimetal disc thermostat (e.g. Klixon brand device) in located within the motor windings within hermetically sealed compressors which will cut off motor current after the local windings have sufficiently overheated.
Unfortunately, by the time this limiter has activated, the compressor motor and pump has typically already suffered mild to major damage.
Compressor overheating is typically a result of low freon. The freon, besides cooling the compressor, also carries the lubricant, so low freon results in a hot compressor with poor lubrication, with some degree of permanent damage by the time the internal limiter has activated.
There are a few other possibilities, depending on system design, but some version of the above scenario is typical.
When the compressor runs hot, this also initiates chemical changes in the freon and oil resulting in acids with further attack both the compressor pump, motor windings and motor bearings, a viscous circle.
Compressor overheating can also be a result of contaminants circulating within the freon or evolving mechanical failure problems within the compressor pump or motor.
Better systems (very few high end residential central AC systems) include OEM or field installed high freon pressure and low freon pressure cut out switches connected to circuits which stop the compressor and keep it off when pressure are well beyond desired.
These are far more effective in protecting the compressor and preventing permanent damage.
Additional protection options are a compressor discharge temperature limit switch (shuts off the compressor if the outlet freon goes well above desirable outlet temps), and a flow switch which sense adequate condenser fan air flow and only allows the compressor to run when adequate air flow is present (a second or so after the condenser fan has started). (Since condenser air flow is what removes all the system and interior heat, the compressor should not run unless airflow is appropriate.)
While all the above 4 safety device strategies are relatively inexpensive, they are not present in the vast majority of residential AC systems sold in the US.
Jan 06, 2010 | Carrier Heating & Cooling
My speedaire compressor hasn't been turning on automatically to keep the tank filled with air, The reset breaker pops and so I have to rotate the pullys a few times and then push the reset button which...
Cabinetman54
Nov 18, 2009 | Air Tools & Compressors
I need to reset the service alert on the dash (mercedes ML ,2002)
Within the first 4 seconds after moving the start switch to position 2, press the reset button for the trip counter twice within one second. The display for the service request is activated for about 10 seconds.
Within these 10 seconds, move the start switch into position "0". The service request continues to be displayed.
Press the reset button for trip counter and keep it pressed.
Move the start switch into position "2".
Continue to hold the reset button for the trip counter pressed until the signal sounds and the new start distance appears in the display (it takes about 10 seconds).
Nov 08, 2009 | 2006 Mercedes-Benz ML-Class
How to make reset for service alert for my mercedes ml 320
To reset the service alert light, perform the following:
Clarke hunter 60 2.5 hp compressor , trip switch keeps tripping
Dec 09, 2008 | Air Tools & Compressors
Spanner sign with 500,100 and 0
The spanner or wrench you are seeing indicates how many miles are remaining before your vehicle is supposed to have the oil changed. Normally this is about a 10,000 mile interval and may be reset after an oil change by following this procedure...
Do the following steps:
Move start switch to position "2".
Jun 18, 2008 | 2007 Mercedes-Benz ML320 CDI
Air Tools & Compressors Logo
772 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
