Question about Fujitsu LifeBook N3530 Notebook
UNDER MEMORY STICK CL1 AND CL2 ARE THEY FOR CLEARING BIOS PAEEWORD?
I HAVE THIS FUJITSU N3530 LAPTOP I AM TRYING TO CLEAR BIOS PASSWORD WITH OUT OPENIG IT AND FINDING CMOS BATTERY ,THERE ARE 2 CHECK POINTS UNDER MEMORY STICK.SAY CL1 AND CL2 CAN I SHORT THEM AND CLEAR BIOS PASSWORD ?IF YES HOW LONG I HAVE TO SHORT THEM.ONE OF THEM READ 3.4 VOLTS TO GROUND WITH NO BATTEY AND ADAPTER CONNECTED.THANK YOU
3 Suggested Answers
mdsaeed67
  • 849 Answers
SOURCE: fujitsu n series n3530 lifebook
you need to open your laptop, you will find it on the motherboard, near the battery you will find the CMOS reset jumper or switch.
Posted on Oct 22, 2008
emissionwiz
  • 66602 Answers
SOURCE: How do I reset the
Hello
If you don't know the administrative password then the only thing you can do is reload the operating system using the manufacturers operating system recovery disk(s). There is no way around the password other than this. If you don't have the recovery disk set then call the parts dept. of the maker of the computer and you can order it, the price of the recovery disks varies by manufacturer, but the last time I ordered a set of disks (for this exact same problem, no password) it was $20.00 if i recall correctly. You can also email Fujitsu support (email support is free) to confirm what I'm saying is correct.
Below is a link to Fujitsu USA support.
http://support.fujitsupc.com/CS/Portal/supporthome.do
Posted on Sep 21, 2011
SOURCE: turn on touch pad fujitsu n3530
HI,
Try to go to control panel and then click mouse icon, then go to touchpad properties..Enable it from there. If it does not work, then update you chipset drivers. Go to shopfujitsu.com scroll down click download. Put in your Model and series numbers then look for the chipset drivers.
Hope this helps.
Regards,
Meir
Posted on Nov 11, 2011
How to reset bios password in lifebook ah531/gfo series
you need to force a bios clear. often you need to get the system to default into a bios setup to do this, if you have more than one memory stick installed try removing one an boot up. this should generate a bios error due to the memory size mismatch. If it doesn't, power back down, reinstall the simm and boot back up and see if this error will bring up a bios error and allow you into setup. If neither of these work, try removing the hard drive and power up. If none of these work, Fujitsu (the original mfg) played an obnoxious game and used an external software access bios config, and this will require an original disc to access.
Sep 05, 2014 | Fujitsu LifeBook Computers & Internet
I have a fujitsu stylistic q702 hybrid tablet notebook pic I forgot my bios password The computer will load up windows 8 but if I try to enter bios menu on startup I am asked for a password
I can't find a decent manual for your laptop but there will be 2 pins on the motherboard that will say BIOS Clear. Short these 2 pins and turn the computer on. This is the only way to bypass the BIOS password. This operation will clear the BIOS and reset to factory defaults. After the BIOS is cleared, turn the computer off and take off the short.
Jan 27, 2014 | Tablets & eReaders
Bios password miss how can start
to reset BIOS password in laptop all you have to do is open the memory compartment, remove the memory sticks then you will see a big piece of clear tape covering the bottom of the memory slots. This clear tape has some stickers with bar codes and numbers. Just carefully remove the tape, and you will see JCMOS right next to two flat copper contacts on the motherboard. Just get a set of tweezers and touch both contacts at the same time for few seconds. Replace the memory sticks, close the memory compartment, replace the battery and turn on the laptop. it may work
Oct 03, 2012 | Toshiba Satellite 2450-S203 Laptop DC Car...
Fujitsu siemens s7110 laptop bios password
if youve forgotten the bios password you will need to remove the main battery, the power cord and disconnect the cmos battery to clear the bios password
its better to have a tech do this for you
Dec 07, 2011 | Fujitsu Siemens LifeBook S7110 Notebook
My celsius R610 sends the error correctable memory mod = 2. Anything to do about it ?
Reseat the memory sticks. Make sure the sticks all match if any have been changed. You can not mix types of sticks. Clear all logs in bios.
Nov 26, 2010 | Fujitsu Siemens Celsius R610 PC Desktop
FUJITSU LIFEBOOK N3530, INTEL CENTRINO DUO. THIS LAPTOP WILL GO THRU THE WHOLE 9 YARDS OF REFORMATTING AND INSTALLING BOOT FILES FROM FLOPPYS,WINDOWS XP, WINDOWS VISTA. BUT WHEN IT COMES TIME TO BOOT UP IT...
check the BIOS...
check the boot sequence in bios...
may be it's not set to boot from HD....
pls let me know if u can make changes in BIOS and can set HDD booting...
i will explain how to do it if u need...
have u formated and reinstalled windows...?
let me know more details pls...
Dec 20, 2009 | Fujitsu LifeBook N3530 Notebook
Omnibook 4150 password
One Time, I forgot BIOS PASSWORD OMNIBOOK 4150XE2.
I had to find a way to clear the CMOS on my own.
(1) Remove the memory access panel.
(2) Remove the sticks of memory.
(3) I believe it is the top stick, but it may be the bottom. There are two solder points that stand out.
(4) With a small screwdriver or other tool, short these two contacts.
(5) Replace the memory and put the access panel back on.
Your CMOS should now be cleared. I have only done this on an XE2, but chances are there are similar ways on other HP laptops.
Make much attention... it can be dangerous.
If you want, try this solution, BUT YOUR RESPONSABILITY.
or
H.P. will provide a solution FREE OF CHARGE even though the laptop is out of warranty.....unbelievable I know !!!!
You have to try and give proof of purchase, very important, then a code is given which you enter in the bios. Then you contact H.P. with the resultant code and then your bios password will be unlocked........
regards
Nov 24, 2008 | Computers & Internet
Fujitsu n series n3530 lifebook
Oct 22, 2008 | Fujitsu Computers & Internet
BIOS Password - UNKNOWN
Remove the battery. That will clear the cmos known as the bios. Check the manual there may also be a jumper that can also clear the bios. Remove the battery & unplug the power before doing this.
please vote...
Feb 05, 2008 | Fujitsu LifeBook S4510 Notebook
Fujitsu LifeBook N3530 Notebook Logo
288 people viewed this question
Top Fujitsu Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant  Sharma
Prashant Sharma
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
