Question about Fisher and Paykel DE27CW1 Electric Dryer
Fisher Paykel Dryer Fault Code 22 Info
We are geting a Fault Code: 22 and the Dryer stopped mid cycle. When we powered down and hand rotated the drum then powered back on then the drum would open up and allow access to the clothes. Now the dryer is working as if nothing ever happened. I am curious as to what Fault Code: 22 is for the DE27CW1, DG27CW1 series Fisher Paykel dryers?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 103 Answers
That is a fault for the "Door Actuator Open Circuit". You may have not had the door closed completely and when you opened the door to check it out, you closed it completely. Another possibility is the sensor module is going bad.
Posted on Jun 14, 2016
4 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: My Fisher Paykel DEGX2 dryer is stuck. The drum
A dryer2_bing.gif may not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Apr 26, 2010
  • 32 Answers
SOURCE: Dryer not providing any heat during cycle
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ Check posts on "Heaters" in this forum will work you through your problem
Posted on Oct 15, 2010
SOURCE: Have fisher paykel drier model DE27CW1 -
http://www.technostation.com/user-guide-owners-manual/Fisher+%26+Paykel/Fisher+%26+Paykel+DE27CW1+Dryer
Ok, well unfortunately, this symptom doesn't tell us much :( Other than, the dryer is getting power? Obviously, it will NOT perform any functions. Now when something like this happens, it can, unfortunately,be one of many, many, many things. From, bad sensors, to spiked electronics. There is no real way to tell, unless specific symptoms, or Error codes are displayed. Accordingly, one will have to troubleshoot the entire system to find out exactly what is wrong, often the place to start is with the main Brain, and Sensors, however to do this one either must be experienced or obtain a service manual, as all units differ in operation and circuitry.
So, it is my professional advice to you, that you contact an F&P repair center, and ask that they call and give you a "Quote" as to the cost and type of repair required. This way at least one can get an idea of costings before making a decision as to what to do, repair or replace.
Many of my customers these days often prefer to put any larger amounts of money, that would be spent on a repair towards the purchase of a NEW unit, with a full warranty, now i also say this as I am aware of statistics that show to overall, a unit that has been repaired after a major failure, for whatever reason, will usually fail again within the next 12 - 18 months..
Posted on Apr 01, 2011
When turned on it makes noise like it wants to engage but after 3-4 tries it stops and then only the Extra Dry and Cool down lights stay on while it beeps.
There should be a little bit of resistance when you turn the drum unless the belt is broken or there is a problem with the belt tensioner. Press the Power button once to see what happens. Your dryer should be displaying a fault code. When you have that, the next step is to find out what it means.
Jun 16, 2015 | Fisher and Paykel SMARTLOAD DE62T27G Gas...
Why does Drum does not rotate
can be severl causes check drum rotates by hand freely is good most common fault is the capacity needs replacing
Jun 08, 2014 | Fisher and Paykel Dryers
Fisher paykel dryer DEIX2 squeaks when drum rotates
I've had the same issue with my FP washer, thanks for the tips!
Jan 17, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Why would it stop mid cycle? You can hear the engine trying to start.
It is not the engine but the motor that makes the noise. perhaps it can be a mechanical issue that stops the machine at mid cycle due to friction on the drive or it can be due to faulty control panel or even a dirty/ clogged drain pump.
Sep 07, 2012 | Fisher and Paykel Washing Machines
Jun 26, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Fisher & Paykel Dryer model ED56 constant beep
Diagnostic Mode
Entering the Diagnostic Mode
(a) Turn the power supply to the dryer on.
(b) Press and hold the Auto Dry down button, then press the Power
button.
The dryer is now in level 0 of the diagnostic mode. After initial entry into the
diagnostic mode, the Start/Pause button operates the dryer as normal. Press
the Auto Dry up or down buttons to scroll through the fault levels.
There are several levels of diagnostics, most of which are used in
development and production. These levels may bring on various LEDs, but
the level of use for the service technician is that of the last fault.
Last Fault
To enter the last fault diagnostics, enter the diagnostic mode as described
above, then press the Auto Dry up button three times. The last fault will be
displayed on the drying progress LEDs.
The manual is here
Sep 08, 2009 | Dryers
Wont start. Extra dry light on and cool down light on.
Fault #3 Drum Stalled; unable to move.
  1. Check drum movement mechanisms: belt, motor and motor harness (if motor moves drum slightly, treat as fault #2)
  2. Replace the motor control module.
  3. Replace the motor.
Fault #2 Drum Gap Cannot be Located
  1. Ensure sensor module is correctly located and clipped in.
  2. Replace the lens on the sensor module.
  3. Replace the sensor module.
  4. Remove Top Deck and clean the sensing bumps on the outside of the drum end.
  5. Replace the drum.
May 02, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Stops mid cycle
CHECK DRAIN PUMP AND DRAIN HOSE FOR RESTRICTION
Jun 01, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel DE27CW1 Electric Dryer Logo
501 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
