Question about HP ScanJet 7650 Flatbed Scanner
What does a flashing 04 on a HP Scanjet 7650 mean
On the front of the scanner usually I get an 01 now I'm getting a 04 - I tried to scan 40 sheets, it stopped and said an error occurred.
SOURCE: HP ScanJet 7650 asking for DPE
This problem happened to me to (OfficeJet 6310xi). These steps solved my problem:
When the program has the error, there's a button so you can show it where DPE is. Click the button
Navigate to Macintosh HD/Library/Application Support/Hewlett-Packard/HP Scan Pro/DPE/
Click on DPE 11.6.app
Then I could scan to pdf. When I upgraded to Leopard, I reinstalled my HP software, even though HP says it isn't totally compatible with leopard.
Posted on Nov 20, 2007
SOURCE: Hp scanjet 7650 urgent issue...
just reinstall scanner driver and software
Posted on Mar 21, 2008
  • 91 Answers
SOURCE: We have a HP Scanjet
See the item is placed correctly on the scanner glass or in the ADF.Make sure that the item you are trying to scan is placed face down onthe glass, or face up in the ADF. Ifyou are using the ADF, there might be a page on the scanner glass.Raise the ADF unit and remove any pages on the scanner glass. If you are using the ADF, the ADF window might need to be replaced.
If that is okay, Please check this link.
Posted on Jan 07, 2009
  • 84 Answers
Sometimes, the programmes we install or download from the Internet cause drivers' to corrupt. Your best bet now is to re-install the scanjet driver. Put the cd into the drive and remove the programme. Shut down the pc and disconnect the printer data cable(USB) from the pc. Switch it on and allow to stabilize on the desktop. Then using the driver cd re-install the software. Connect the printer to the pc when prompted and allow the process to complete. Restart your pc and then try scanning again. It will surely work. You could as well download the drivers from the Internet from www.hp.com, incase of cd loss. Good luck
Posted on Jun 03, 2009
SOURCE: my hp scanjet G241 scanner produces a terrible noise wen scanning
i want to dowonload system of my scanjet g 2410 on my laptop
thanks...
Posted on Jan 03, 2011
I need to know how to change the settings on our HP Scanjet 7650 so that I can scan documents in at 300 dpi.
This setting change happens in the HP scanner control software, which needs to be installed on each computer.
Jul 08, 2011 | HP ScanJet 7650 Flatbed Scanner
My HP scanjet 7650 shows error 04 when I switch on
Install the latest drivers from the website. To download:
1 Go to hp.com 2 Click on Support and Drives 3 Enter your product name or number, in this case just type in Officejet 8500 All-In-One 4 Hit go 5 Choose your operating system 6 Hit Next 7 Click on the link that says Driver - Product Installation Software 8 Save it to your desktop
But before Installing the Software, use the Disc that came with the printer so you can do an L3_Uninstall first.
To go for an L3_Uninstall:
1 Go to My Computer (XP), Computer (Vista and Win7) 2 Right Click on the Driver CD, The one that has the HP Logo 3 Open Util 4 Open CCC 5 Double Click on the icon that says Uninstall_L3
The Uninstall will prompt you to restart the computer once it's done. After doing so, Install the newly downloaded software.
Try scanning again, I hope this worked. :)
Feb 03, 2011 | HP ScanJet 7650 Flatbed Scanner
Scanner showing error 04 and cant let me scan
Disconnect the power supply from the back of the scanner base.
Disconnect the USB Interface cable and the ADF Accessory cable from the back of the scanner.
Press and hold the E-mail and Copy buttons at the same time. While pressing the E-mail and Copy buttons, reconnect the power supply to the scanner.
Reconnect the power supply and turn on the scanner.
Press the Scan Doc button. the carriage will start moving back and forth in the full scan bed length. To exit test, disconnect the power supply.
now try to scan the document ..........
Dec 14, 2009 | HP ScanJet 7650 Flatbed Scanner
Green light at front keeps flashing. wont scan
Hi, this might help you:
try to download the drivers and other software from hp.com or some other site and try to reinstall everything.
if you can't find them then search something like: 'hp scanjet 3200c drivers' on google or other....
I hope this is useful, and greets.
Oct 20, 2009 | HP ScanJet 3200C Flatbed Scanner
I am assuming that you're using the XP operating system. If it's another operating system please do tell me.
I see that it's a problem with your software (that came with your HP scanjet). I use a Samsung at home, so I have not used it.
However, here's a tutorial to scan WITHOUT using your HP software
http://www.microsoft.com/windowsxp/using/setup/hwandprograms/printfaxscan.mspx
Since it's urgent,
Cheers
Jun 03, 2009 | HP ScanJet 7650 Flatbed Scanner
The model is actually discontinued now, but you can download Driver Software and a Manual for the Scanjet 7650 from the HP website:
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=uk&prodTypeId=15179&prodSeriesId=434502&lang=en&cc=uk
You can also get Parts information.
Hope this helps
Chris (ziraffa)
Jan 11, 2009 | HP ScanJet 7650 Flatbed Scanner
Hp scanjet 7650 document feeder is not working
did u buy cheaper paper that will do it tease the sensor in it sumties try to dl latest driver form hp.com ok remove old 1st
Oct 09, 2008 | HP ScanJet 7650 Flatbed Scanner
Error code 08
Unplug your scanner and switch off your PC. Check the USB connection is secure on scanner and pc. Wait for at least one minute, then switch both back on. Your display should go back to 01 now.
Sep 04, 2008 | HP ScanJet 7650 Flatbed Scanner
Mar 20, 2008 | HP ScanJet 7650 Flatbed Scanner
HP ScanJet 7650 Flatbed Scanner Logo
146 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
