Question about Dell Vostro 200 PC Desktop
Diagram of how to connect audio and micraphone on a Vastro 200
I don't know if I have the right cable into the right jacks....
    Scholar:
  • 140 Answers
Gday mate,geoff here, now with the speakers ( Green plug) and the microphone ( Pink Plug) there should be on the back of the macine 3 small sockets Blue, green and pink, the blue for auxilary input, alternitively there is a small hatch on the front with these plugs in there, hope this helps, geoff.
Posted on Feb 11, 2012
How do I connect TV-ear 3.0 to a sceptre 23 bv-naga TV. I don't know were the audio out port is?
There are two plugs, a white and a red. Red is for Right, and white is Left. If you have a 3.5" stereo jack on your TV ear, then you'll need to find and adapter, as your television does not have a 3.5" output jack.
Jan 31, 2013 | Sceptre X23BV-Naga 23 in. LCD TV
I cannot hear any sound from my Dell monitor 1702FP. Are there speakers installed within the monitor?. VGA cable is connected. When I use a spare monitor using the VGA cable the sound is loud and clear. ...
The Dell 1702FP doesn't have speakers.The specs of the Dell 1702FP are available here: http://support.dell.com/support/edocs/monitors/1702fp/en/specs.htm . (BTW neither does the Dell 1704FPT.) However, some Dell monitors can have a sound bar (speaker set-up) mounted on the monitor.
VGA cables don't carry sound. Check if a second cable (an audio patch cable is connected to the computer and the second monitor). (There are some cables that actually bundle the 3.5 mm patch cable with the video cable for convenience. (I've seen a number of DVI cables with that bundle option.) The plugs will separate into separate units at each end.
Other monitors do have speakers built in - look for a 3.5 mm audio input jack with the rest of the input connections on your monitor. There are some monitors that accept an HDMI input with a 3.5 mm audio out jack; these monitors don't have speakers and thus are enabling a daisy chain to connect the speakers to the monitor. So you do need to be careful and look for the audio in label.
You can attach a set of speakers to your computer using the audio out (look for a lime green 3.5 mm jack on the back of a desktop). For laptops or to use the front audio ports, look for a headphone jack.
I hope this helps. Please add a comment with more information about your monitor and computer for additional assistance.
Mar 11, 2012 | Computers & Internet
I don't know how to use behringer feedback destroyer DSP1124p
Determine where in the mixer's signal path to connect the unit. Your options are:
1. One or two individual microphone channels via the mixer's CHANNEL INSERT in/out jacks.
2. The monitor mix output via the mixer's MONITOR OUT jacks.
3. The main mix output via the mixer's MAIN OUT jacks.
  • 2 Connect a balanced cable with the appropriate connectors from CHANNEL INSERT OUT jacks on the desired mixer channel to INPUT RIGHT or LEFT on the Feedback Destroyer's back panel for individual microphone channels. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to that mixer channel's CHANNEL INSERT IN jack.
  • 3 Connect a balanced cable with the appropriate connectors from the mixer's MONITOR OUT jacks to the INPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel for the monitor signal path. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to the monitor amplifier INPUT jack or amplified monitor speaker INPUT jacks.
  • 4 Connect a balanced cable with the appropriate connectors from the mixer's MAIN OUT jacks to the INPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel for the main mix (FOH) signal path. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to the main amplifier INPUT jack or amplified house speaker INPUT jacks.
  • Oct 17, 2011 | Behringer Audio Players & Recorders
    Just bought a Harbinger HX121M 2" Monitor, from Musicians Friend it did not come with a booklet on how to wire into my sound system it has two 1/4" jacks and a strange round plug about the size...
    If you don't know how to connect this... well we don't either because you did not tell us what your sound system is. The larger plug is what is known as a "Speakon" connector and is a fairly reliable speaker connection that is used now. For your use you will PROBABLY use either of the 1/4 inch jacks with a cable from the amp that will drive the monitor(s). If you have multiple monitors you will daisy chain them using the 1/4 inch jacks and SPEAKER rated cables creating a string of speakers with input going into one and an output from the same one to the next speaker and so on...USUALLY you will be limited to two speakers per amp output...
    Aug 15, 2011 | Harbinger HX121M 12" Stage Monitor
    GE audio/video switch AV93294 has what appears to be a adapter port on front , no voltage given. Says audio output. Please explain
    As the label says, it's an audio output. The audio from whichever source you have selected appears at that jack so you can plug in something like a pair of headphones or the cable to a wireless headphone transmitter. If you don't have anything to connect there, don't worry about it. It's a convenience, but you don't need to use it.
    Aug 14, 2011 | Audio Players & Recorders
    I have a set of T 912 wireless headphones. I am unable to set them up on the TV. I am using the white and red cables from the base station to the TV audio red and white. Do you have any instructions on...
    The audio jacks on the TV are most likely inputs, not outputs. They're meant to take the audio signal from something like a DVD player, along with the video input on another jack, so you can play it through the TV. There isn't an audio signal coming out from those jacks, and if you connect your headphone transmitter to them all you'll get is silence. Almost all sets now have at least one set of AV inputs, but most don't give you outputs. The manufacturers figure the TV is just a display device, and not a signal source.
    Unfortunately, there isn't any easy way to connect your wireless headphones if the TV doesn't have audio output jacks or a headphone connector. If you're comfortable with soldering and willing to do some modification to your TV, it's possible to add a headphone jack. Most people don't want to start tinkering with their sets, though.
    If you're using your TV on a cable system without a converter box and the cable hooks right to the set, you're out of luck unless you're willing to add a headphone jack as I mentioned before. But if you have a cable converter box, or you're using a satellite receiver or other set-top box, you can use your headphones with those. These devices typically have direct audio and video outputs available on the rear panel, and you can use that audio output to feed the headphone transmitter.
    What most people do these days is use a home theater receiver along with the TV. All sources (the cable box, DVD player, video game console, audio CD player, etc.) connect to the receiver, and the receiver's audio and video outputs go to the corresponding input jacks on the TV. This way, the TV is just the end of the line. The receiver also would provide an output for the wireless headphone transmitter. This system offers some advantages. You'll be able to connect the proper speakers to enjoy surround sound when not using headphones. And you'll be able to use your wireless headphones with the tuner and audio sources like music CDs when not watching TV.
    I have external speakers / woofers with amp ..what i nedd is to connect those with my Sony bravia LCD TV.. i mean i need the audio output from the TV which will connect with the external speakers .. if...
    I do not want to sound patronizing, but I have no idea how much you know about wiring ... so I'm probably going to over-explain everything. Hopefully it won't read like stereo instructions ... ha ha ha
    Depending on your TV, theremight be a door covering the wire access .. or there might be audio outputs on the front of your TV ... but these are more likely to be inputs for game consoles and other things. You should have a red and a white jack in the back of your TV marked "Audio Out" ... those are left and right audio outputs from your TV. Use RCA cables from Radio Shack or wherever and connect that to your amp left and right audio inputs -- the RCA jacks should be the same color as the wire connecting them, which makes it easier to trace wires later. Generally, the amp should have a red and a white RCA jack as well .. make sure they match your wires , too ... or you'll end up hearing things in reverse. You should find sterio wire inputs on the back of your amp -- if your speakers have the wire connected, set them up and then plug them into the appropriate jacks. There shoud be some sort of lever on the side of each of thee jacks, push it open and insert the wires. Some of these are spring-loaded so you might have to keep your finger on it to hold it open. Just put a bare cord from the speaker into it, and make sure the lever closes again, securing the wire. Your amp should have the left and right speaker outputs, subwoffer output, and everything labeled, but you'll probably need a lot of light on it to see it (usually it is just a recessed or relief letter L and R for the left and right speakers.
    I am not exactly well off, so most of the electronics I have are a bit old. You might only have a different audio output from your television, in which case I would recommend speaking with someone at Radio Shack -- they tend to know a lot about wiring electronics together (more than at Best Buy or other big-box stores) or if you don't have one of those around, find a local electronics store, or a pawn shop ... people who work in these types of places usually enjoy the challenge of putting a round plug into a square jack.
    May 24, 2011 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
    I HAVE NO CABLE BETWEEN TUNER AND AMPLIFIER
    Normally you should have a stereo "line" connection. The cable consists of a pair of "RCA male connectors" on each end of the cable, "RCA" is the style of the connectors, usually one red and one black or white on each end.. "Line" refers to the type signal and voltage level of the signal. The tuner should have a pair of output jacks labeled as such and also labeled Right and Left. The power amp should have similar jacks labeled "tuner input" or "tape in", "phono in" etc. don't use phono or "mic in" if that is a choice. Use tuner in or tape in. Connect the same colors to the same channel on each unit, ie, red to right and black to left on each unit. On the amp you may have the option to select the input source. Select the one you are using for the tuner. Turn on the tuner and the amp and listen. Good Luck.
    Apr 16, 2011 | Audio Players & Recorders
    Yamaha RX Z9 and two-channel system integration
    The A-B speaker switch is intended to direct amplifier output to a pair of speakers in a different location when set to B.
    Feb 26, 2017 | Televison & Video
    I cannot connect my amp to my pc
    Make two audio cables L+R hook up the cable from your Audio AMPLIFIER, lift and right if your amp is sterio, connect the other end of cable with stereo jack to your PC audio output,and play it,
    Thanks & enjoy,
    Jack
    Jul 20, 2008 | Packard Bell Computers & Internet
    Dell Vostro 200 PC Desktop Logo
    85 people viewed this question
    Alun Cox
