Question about Venturer PLV36220S1 22 in. LCD TV
What are the caps? Where do I find them on a veturer 22
I really need help please.
  • 1,684 Answers
Here is a link to an article explaining what caps are and how to tell if they are bad.
http://www.ccl-la.com/blog/index.php/capacitors/
The caps will be on the power supply board, If you send me a picture of the board to tech@ccl-la.com I will mark the caps that need to be replaced.
BuddyMc
Posted on Feb 11, 2012
Where is the termastat on 1999 chevy veture
The upper rad hose is attached to the thermostat housing containing the thermostat. It is under the exhaust crossover pipe area and is not an easy to change
May 09, 2015 | 1999 Chevrolet Venture
Expiration date
Most car seats have a six year expiration from the date of manufacture (not first use). Some seats may have an expiration date on a label, or may have an expiration date embossed into the plastic. To be certain, call the manufacturer. In the USA, call 800-544-1108 (Dorel Juvenile Group).
There are several recalls on the 22-150 model. See www.carseat.org and click on "recalls."
Jun 19, 2013 | Cosco Alpha Omega 22-150
My 2002 x type keeps blowing a fuse that controls the right side tail lights.
electrical problems are sometime very hard to find and take a lot of time. I would veture to say that the wiring harness has a short somewhere whe it is pinched.
Sep 15, 2010 | 2002 Jaguar X-Type
Head bolt torque specs?
I really really really hope you turned the bolts an additional 90 degrees after torquing to 22 Ft-lbs. Otherwise, you may be taking that head off again.
Best of luck,
David
Feb 09, 2010 | 1994 Toyota Celica
I replaced compressor for a hussman refrig and its hums loud
God day,
Some thoughts.
1. Are the evap fan motors running, and at full speed. That would give you abnormally low suction pressure.
2. Cap tube sized too small. or partial restriction in the dryer cap tube/dryer when brazing in the lines.
3. Low ambient. What's the temp the machine is running in.
4. Over sized compressor.
5. Moisture. God, 134A is touchy on that one.
6. Was original cap tube soldered to the suction line to create a heat exchanger. Needed on many apps. Definately would cause flash back on start up.
7. Superheat a little low, should be 12 to 15 degrees.
Jan 31, 2010 | Hussmann Freezer Gelato Pan Rack (For 12...
VK222U 22 inch Monitor drops to blank screen regularly the blue on light stays on most of the time but occassional the monitor turns off and needs to be switched back on, please help!
Open it up and look for bad caps, measure some voltage in the inverter circuits for 12~18vdc, also look for bad caps with bulging tops. See some example of typical failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 12, 2010 | ASUS VK222U 22" Monitor
Where are the O2 sensors located on a 2004 Chevrolet Veture Van and do I need to do anything special to install the sensor(s)?
located on the exhaust pipes before and after the catalytic converter there is a special socket with a cut away on it but not necessary to have can use wrenches=just be careful of connectors
Nov 18, 2009 | 2004 Chevrolet Venture Passanger
All my DRC8335 vcr-video system says is hello
X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK Solution #1 posted on Feb 22, 2009 Asker's Rating 0%20stars_w.png
noavatar_s.gif dvickery926
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Thanks to the help on this forum, I was able to fix my DRC8335 power supply. C226 was the problem, went to Radio Shack and found the 470uf 35V replacement. It came up and worked like a charm after soldering it in. (See the picture of the cap on the board). It was just slightly swollen when viewed from the top but when i removed it, the bottom was really distorted. Thanks to micro065 and Mike Powellebbca66.jpg
Comment posted on Feb 22, 2009 Thanks to Mike Adams not Powell, sorry. Mike Adams is a FixYa Expert.
May 02, 2009 | RCA DRC8335
BIOS Password Problem
The only thing that a bios update would do would update the bio your password info should stay the same maybe your not typing it right try typing with or without cap lock
Mar 10, 2009 | ASUS F9S-B1 Intel Core 2 Duo T7500 2.20GHz...
Venturer PLV36220S1 22 in. LCD TV Logo
94 people viewed this question
Top Venturer Televison & Video Experts
john milligan
Are you a Venturer Televison and Video Expert? Answer questions, earn points and help others
