Question about Motorola Walkie Talkie 2-Way Radio
What will happen if i overcharge walkie talkie for 3 days?
  • Motorola Master
  • 1,654 Answers
You will age your batteries some, by them being left on the charge. However, for a weekend or 3 days on occasion, you will cause no serious damage. However, if you were to leave them on an extended time, say 10-30 days, you could conceivably "cook" the battery and cause it to fail.
Many modern chargers have a safety feature where they will go to trickle charge after a battery is full.
Best regards.
Posted on Feb 13, 2012
eradiostore
  • 1654 Answers
SOURCE: motorola walkie talkie t4508
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T4500_User_Manual_E.pdf
This one should be a very close match. The T4508 is a foreign version of the T4500.
Posted on Jan 07, 2009
eradiostore
  • 1654 Answers
SOURCE: Motorola FV200 Walkie-Talkie
Scanning Channels
Use scanning to monitor channels for transmissions or to find someone
in your group who has accidentally changed channels.
1. Short press
MENU until the "Z" appears. The current setting
On/Off will flash.
2. Press either
+ or to turn On or Off.
3. Press the PTT to confirm or
MENU to continue set up.
Here is a link to the manual http://www.motorola.com/mdirect/manuals/FV200_userguide.pdf
Posted on Oct 23, 2008
msmichalko
  • 17 Answers
SOURCE: motorola talkabout ta288 walkie takie
http://www.theusermanualsite.com/manuals/mfg/motorola/motorola_twoway_radio_product_list_4.html
You will find the manual here. The radio is part of the 280 series radios, so there is a general manual on all in that series.
Posted on Jan 09, 2008
eradiostore
  • 1654 Answers
SOURCE: I'm searching for a User Manual Walkie Talkie T8550R Camo
I think you'll think this is fantastic: http://www.giantintl.com/ContentManage/manuals/Moto/T8500%20English%20only%20June5.pdf
Best regards.
Posted on Nov 14, 2009
eradiostore
  • 1654 Answers
SOURCE: One of my tlkr-t3 walkie talkie's will not recieve.
You have your interference code eliminator set differently on the two radios. Here is a link to the T5 user guide (sorry I didn't have a link to the T3, but they should be very similar): http://www.gouldelectronics.co.uk/product-downloads/T5-20Manual-20EU.PDF
Posted on Feb 28, 2010
I have slyvania walkie talkies model no.fbs201 working but not sure how to turn off and on..
I could not find your model on the internet. Sylvania was never a walkie talkie manufacturer, so they were made by someone else. The ones I found on eBay had an off/on switch tied to the up down keys. Try pressing and HOLD for about 3 seconds the left side bottom button, then release. If that did not power it on, try the other buttons but be certain to HOLD for about 3 seconds since the button is dual purpose.
Oct 31, 2016 | Walkie Talkies Radio Communications
The battery is fully charged on the walkie talkies and all are on the same channel, however out of 12 walkie talkies only 2 will work. When ever you push the push to talk button the walkie talkie shuts...
Your batteries are either no good, or not charged. When you press the PTT button it takes more energy than being in standby mode. If you have a battery problem it will fail quickly when the PTT is pressed.
Rechargeable batteries last approx. 18-24 months. Check your battery for a 3-digit date code. It is usually a 3 digit number followed by a couple of letters. The numbers tell the date of manufacture. The first number is the year, followed by the week of the year. 025 would be 2010 the 25th week. (or if very old it could be 2000 the 25th week.)
If you feel age is not a problem, you might check your charger(s) to see they are fully powered, and clear of debris on the contacts (and the radio contacts as well). Clean with a pencil eraser if needed.
A few tips: Be certain when placing your radios on the charge they are turned off. Check your wall outlet to be certain it doesn't get shut off with a light switch. Expect to replace your batteries every 2-3 years.
Best regards.
Nov 09, 2010 | Motorola Walkie Talkie 2-Way Radio
When i try To walkie-talkie it wont work
They do not have signal to receive the walkie talkie service. Try texting them and telling them to get in an area where they can get better service. Walkie Talkie coverage is very spotty.
Jun 24, 2010 | Motorola Mobility Boost i415 Cellular...
Walkie talkie batteries don't last
What you have been using are consumer grade walkie talkies. The rechargeable battery packs in them should last a full business day, unless you are in a high use area. This being said, it is also possible you might need to replace the rechargeable battery pack as they usually have just a one year life expectancy. As they start to fail they will go less and less time in a day.
To answer your question about a radio which will go a full business day, any of the business division Motorola handheld radios would work. Radios such as the CP110, BPR40, CP185, and CP200 are all make to go a full day and sometimes more. Their battery packs depending on chemistry would also need to be replaced every 18-24 months.
Best regards.
May 14, 2010 | ICOM Informatique Icom IC-F11 5W 16ch VHF...
Motorola Walkie-Talkie will not turn on.
Unfortunately problems involving electronics don't fix them self. If the radio did not work and then it worked after a day or two then it is quite possible that you did have water in the radio. if this is the case. then you will probaly have more problems in the short future as the contaminants from the water start to destroy the board. In this case the best thing to do is open the radio and use an electronics parts cleaner like the tuner cleaner from radio shack and clean the board. Trust me, I have had many customers that have ignored the problem and it cost them later.
Good Luck
Patrick
Nov 14, 2008 | Motorola Walkie Talkie 2-Way Radio
Nextel i850 can't receive calls
  • may be the walkie talkie can recieve signals only to an certain distance,so it may be due to the signal problem........
  • if the reciever is beyond the permitted distance it loose its frequency...........
  • or else the person who is calling walkie talkie might not hav signal in that area.....
  • and if the walkie talkie does not recieve any signal then the receiver component present inside the walkie talkie might be damaged.........
  • and if it does not reply to an signal transmitter might be damaged..........
  • i hope my answer would be sufficient for u.....thank u......
Sep 10, 2008 | Motorola Mobility i850 Cellular Phone
Columbia Telecommunications Group 2-way watch - battery needed
A close but not a perfect match....
Columbia FRS22-WH L301 Li-ion 3.7 Volt 500 mah Rechargeable Battery
Battery code L301
1 7/8" by 1 5/32" by 1/4
Contacts are on the flat side - 3/16" from the wide edge and 1/16" from the long edge
Brand New Original Pair Battery For FreeWalker RD-810, RD-820, RD-008, RD-820 Features
***Brand New Original Pair Battery For FreeWalker RD-810, RD-820, RD-008, RD-820***
Best replacement battery for FreeTalker Walkie-Talkie RD-810, RD-820, RD-008, RD-820.
Crafted with latest Lithium-Ion technology, it is intended to delivers long lasting talk times.
This Li-Ion based battery provides power in a thin, short and light package, fits the compatible
Walkie-Talkie model perfectly. It has power capacity of 600mAh, which allow you constantly talking
for 3 hours. standby time up to 3 days. It is absolutely an ideal choice that you won't be sorry
for getting.
Features:
* Battery Type: Standard Li-Ion Battery(Model: RD43048)
* Capacity: (600mAh)
* Voltage: 3.70 V
* Talk time: 3 hours. Standby time: 3 days.
* Color: black
* Dimension(L*W*H): 4.6x3x0.5mm
* Weight: 0.015Kg
Compatible Model:
RD-810, RD-820, RD-008, RD-820 FreeTalker Walkie-Talkie
Jun 17, 2008 | Columbia Telecommunications Group FRS 22...
Radio Communications Logo
410 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
