Computer can not see hard drive - Computers & Internet
  • 34 Answers
Did the hard drive make any noises before going out or did it just up and not work one day?
Posted on Oct 23, 2008
I put in a new hard drive it says the same thing dell ******* sucks parameter has exceeded its normal operating range
The hard drive may be failing, or just the OS or hard drive corrupted. You could try this... Pull the hard drive out, and use a USB Hard Drive Adapter to connect the hard drive to a friend's computer, and save all the personal files (documents, pictures, etc.) you can to a folder on the friend's computer or an external hard drive.
Then, you could try to do a Factory Restore on the computer, and if that works, copy your personal files back to your newly restored computer.
Good luck.
Jul 26, 2014 | Dell Inspiron 580 Desktop Computer (Intel...
Tip
No Hard disk detected / boootable device
<span>When the computer/laptop cannot see a boot file/disk on either the hard disk or floppy drive it gives an error message </span>- <span>"No bootable device. Insert boot disk and press any key"</span><span><br /><br />First thing, check to see if the is a floppy disk inthe floppy drive, if so removes this disk.</span><br /><span>If there was no disk in the floppy drive then it maybe a hard disk problem.<br />Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the data cable on the hard drive and also where it connects to the motherboard disk controller.<br />If it still gives this error message and the BIOS does not detect this hard drive, then the hard drive is probably faulty.<br /><br />A further check on the hard drive, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port, if this computer does not detect it as an external storage device then the hard drive is faulty.<br /><br />To get the computer operating again, install a new hard drive in your computer and then install Windows on this hard drive plus the computer's device drivers and your programs.</span>
on Jan 17, 2011 | Computers & Internet
My dell windows hard drive won't turn on .. It's was working now it won't turn on there's an orange light inside the box we can see but it won't turn on
The hard drive may be failing, or just the OS or hard drive corrupted. You could try this. Pull the hard drive out, and use a USB Hard Drive Adapter to connect the hard drive to a friend's computer, and save all the personal files (documents, pictures, etc.) you can to a folder on the friend's computer or an external hard drive.
Jul 08, 2014 | Computers & Internet
My computer will only flash gateway on sceern will not do nothing else
Jul 07, 2014 | Gateway One ZX4970G-UW308 All-In-One...
My pc turn on for 2 seconts and stops
Jul 01, 2014 | Computers & Internet
Wont start emachine t3646
Jun 28, 2014 | Computers & Internet
Unmountable boot volume
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an USB mass storage device and you cannot open the various folders and fileson this drive, then this confirms the hard drive is faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Nov 28, 2011 | HP Compaq DC7900 Small Form Factor PC...
What's your cant access my c drive
Nov 05, 2011 | Acer Aspire Z5600 PC Desktop
My computer doesn't detect my hard drive.
Try removing the data cable connectors on the hard drive and motherboard and the reconnect them. Then boot up your computer. If it does not boot up and the BIOS cannot detect the hard drive then the hard drive is faulty.
To get the computer working again, replace the hard drive, install Windows on the new hard drive, plus the computer's device drivers and your programs.
Apr 25, 2011 | Micro Electronics PowerSpec 8420 PC...
How do I get the hard drive out
1 Unplug the computer. As a safety precaution the hard drive removal should not be attempted while the computer is still plugged into the house current.
2 Pull the cover off the computer. This should be as simple as removing a few screws and sliding off the cover. If the process seems more involved that this, then consult your owner’s manual for the computer.
Locate the hard drive.The hard drive usually comes in the shape of a black-plastic rectangular box enclosed in a metal casing. It is linked to other components by a unique connecting device that is easily recognizable. This device is a long plastic ribbon-like cord that has a long interlocking and connecting device attached to it.
4 Remove the metal housing. This should be as simple as removing a few screws.
5
Disconnect the hard drive. All you have to do is pull the interlocking end of the lock ribbon cord until it coves free. This should not require an extraordinary amount of strength. It is similar to pulling an electrical cord from a wall socket.
Read more: How to Take a Hard Drive Out of a Computer | eHow.com http://www.ehow.com/how_4450021_take-hard-drive-out-computer.html#ixzz0qvQCfJhS
  • Step 6 Unscrew anything that is still holding the hard drive in place and then pull the hard drive unit out of the computer. Now you can externally hook the hard drive to another computer to double check the data base. For this you will need an external holder, which you can purchase for $25 to $50 at your local computer store. Or you can add the hard drive unit to the inside of another computer tower.
  • Read more: How to Take a Hard Drive Out of a Computer | eHow.com http://www.ehow.com/how_4450021_take-hard-drive-out-computer.html#ixzz0qvQ9MXYe
  • Step 5 Disconnect the hard drive. All you have to do is pull the interlocking end of the lock ribbon cord until it coves free. This should not require an extraordinary amount of strength. It is similar to pulling an electrical cord from a wall socket.
  • Read more: How to Take a Hard Drive Out of a Computer | eHow.com http://www.ehow.com/how_4450021_take-hard-drive-out-computer.html#ixzz0qvQ5WTOQ
  • Step 4 Remove the metal housing. This should be as simple as removing a few screws.
  • Read more: How to Take a Hard Drive Out of a Computer | eHow.com http://www.ehow.com/how_4450021_take-hard-drive-out-computer.html#ixzz0qvQ1AnQp
  • Step 3 Locate the hard drive.The hard drive usually comes in the shape of a black-plastic rectangular box enclosed in a metal casing. It is linked to other components by a unique connecting device that is easily recognizable. This device is a long plastic ribbon-like cord that has a long interlocking and connecting device attached to it.
  • Read more: How to Take a Hard Drive Out of a Computer | eHow.com http://www.ehow.com/how_4450021_take-hard-drive-out-computer.html#ixzz0qvPuIEwv
  • Step 2 Pull the cover off the computer. This should be as simple as removing a few screws and sliding off the cover. If the process seems more involved that this, then consult your owner’s manual for the computer.
  • Read more: How to Take a Hard Drive Out of a Computer | eHow.com http://www.ehow.com/how_4450021_take-hard-drive-out-computer.html#ixzz0qvPnVKmo
    Jun 14, 2010 | Sony VAIO PCV-V200G PC Desktop
    Computers & Internet Logo
    23 people viewed this question
    Brian Sullivan
    Brian Sullivan
    David Payne
    David Payne
