Question about Refrigerators
Our 3 yr old gorenje gv 60010 dishwasher no longer heats the water & beeps about 20 times upon completion, would like to know if this a common prob & can then rectify myself as nightmare finding a technician to come out & fix??
Smart movie player Licence key for serial no. 355660008786909 in nokia 6681
Posted on Feb 10, 2012
Gorenje dishwasher e1 error
I know that this is an old topic but I have exactly the same problem. Did you manage to fix it?
Jan 26, 2013 | Gorenje GV 62110 23 in. Built-in...
The Dishwasher will not set to the desired program all the LED's are on can you help..? Many Thanks Ray
Hi, You may have a plugged drain hose. Clean it out That is why all lights are on. Also clean out the inside of the dishwasher where the drain is. Good luck
Jul 28, 2011 | Gorenje GV 62110 23 in. Built-in...
What does E3 meam on gorenji dishwasher
It probably means that your thermostat is no longer working.
Apr 01, 2011 | Gorenje GV 62110 23 in. Built-in...
My dishwasher(Bosch) makes sqeeling sound almost like beeping at the beginning of its cycle what is a problem?
Welcome to FixYa.
Based on your description " makes squealing sound almost like beeping at the beginning of its cycle "...it is likely to be either the pump impeller or the inlet valve.
With the Bosch built line of dishwasher`s this is a known problem...the carbon ring ( spring ) of the impeller pump seal kit. ( make sure it is indeed a SHU9915UC before ordering parts )
**Most common in units not used regularly, i.e. in a holiday cottage or vacation property, but time to time on daily used as well unfortunately...but also due to the heat from normal wear & tear**
You first must determine which is the source of course. Does the noise begin after filling with water and the pump starts, or does it begin upon the filling of water ?
If it's the valve, make sure the water supply line is completely "open" and if so replace the valve with part #425458
i.e.
If it is the motor wash impeller squeeling It can be remedied by one of two methods, replacing the entire motor & pump assy part # 442548...
i.e.
This retails between $99.00us. to as much as $170.00us. depending where you look. I usually go through "searspartsdirect.com" for about $100us. ( you can also investigate "repairclinic.com" or "appliancepartspros.com" to name a few.
Or if you are mechanically inclined, replacing the pump impeller kit. part # 167085
i.e.
The kit is typically around $50 -$75us, hence it can be cheaper when factoring labour for the complete motor/pump assy.
This is a pretty involved repair to explain, in fact I think it is harder to explain than actually do...but I`ve done many.
If you`d like to provide me with an email address I can attach a file in "pdf" showing you step by step how you can do this without much cost at all really...likely your time will be the greatest expense.
Let me know how you`d like to proceed and I`ll help in whatever manner I can.
Thanks for choosing FixYa and Good luck.
Regards,
Macmarkus :)
Jan 29, 2011 | Bosch SHU9915UC Dishwasher
Dishes not drying, greasy items not clean
You are alomost there. Yes these are some common issues and get resolved only by replacing the heating element.
Thanks for contacting Fixya and please accept the solution if it has helped you.
May 28, 2010 | LG LDF6810ST Stainless Steel Built-in...
Dishwasher will no longer drain completely
The pump is bad and needs to be replaced. The pump is not pumping out all the water from the system
May 05, 2010 | LG 24 in. LDF 7811 Stainless Steel...
20 yr old GE d/w, completes cycle but leaves bottom full of water
check your drain hose.if all is good most common with older ge dishwashers is the piston valve take the screen off the back end behind the heater and in the midle is the valve it unscrews from the base. look at it and if the rubber valve is detieriated replace it
Mar 02, 2010 | Dishwashers
Refrigerators Logo
118 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
