Question about As Seen On TV Handy Stitch Mechanical Sewing Machine
Where can I buy needles for the handy stitch sewingmachine
  • As Seen On TV Master
  • 7,365 Answers
Try sewvacdoctor.com
Posted on Feb 11, 2012
3 Suggested Answers
SOURCE: Handy Stitch sewing machine
How do you thread and use the Handy Stitch?
Posted on Jun 26, 2008
  • 149 Answers
SOURCE: how do i thread my needle with the singer handy
  1. Loosen needle screw & insert needle with shank's flat side facing front of machine. Push needle in all the way, then tighten screw to hold needle in place.
  2. Install a fully wound bobbin by loosening bobbin nut & placing bobbin on top. Re-attach bobbin nut & tighten. If standard thread spool will be used, then attach spool pin to bobbin shaft & place thread spool onto shaft. Attach white spool cap on end of thread spool, then tighten. Bobbin/spool should unwind facing forward toward needle.
  3. Bring end of thread through thread guides & over tension control. Pass end of thread through needle eye, from back to front, & pull it out about two inches.
  4. A spring pushes pressor foot onto fabric that is being sewn, so lift pressor foot & place fabric underneath.
  5. Turn large handwheel on side of machine (handwheel can be turned in either direction) to raise needle arm to its highest position.
  6. Holding the Handy Stitch in place with your right hand, press on power switch & begin sewing. Guide fabric (being sewn) with your left hand.
  7. To end this sewing session, turn off power. Turn handwheel to raise needle to its highest position. Carefully pull out about three inches of thread through needle & snip, then lift pressor foot to remove fabric. Turn fabric over & loop needle threader through last stitch. Place end of thread from underside through eye of needle threader, & pull to loop through. Pull to tighten and snip end of thread.
Posted on Nov 11, 2010
My pfaff2044 started sewing uneven stitches. It can sew nice then next second leave a big stretch then sew normal again and then itll leave a bigger stretch it also wont blind stitch.
3 Common Sewing Machine Problems (and How to Fix Them)
www.marthastewart.com/.../common-sewing-machine-rep...
Martha StewartSep 26, 2014 - We consulted Becky Hanson of Singer Sewing Company for her tips on ... The Problem: Stitches are coming out uneven or skipping entirely.
Basic Sewing Machine Troubleshooting - Sewing School
sewingschool.org/2011/03/16/basic-sewing-machine-troubleshooting/
Mar 16, 2011 - The thread breaks, my needle bends, or skipped stitches - UGH! Don't get ... Problem: My stitches are uneven and sometimes skipping!
My stitches are coming out uneven - SewingSupport.com
www.sewingsupport.com/sewing.../sewingsupport.../sewing.../my-stitches...
What to do if the stitches from your sewing machine are coming out uneven. Sewingmachine troubleshooting guide.
Dec 12, 2015 | Sewing Machines
What is the difference in the length of the needle on a "handy stitch" as opposed to the "stitch sew quick machine?
Check your manual for the "System" of needle
a normal sewing machine needle has a "System" or dimension
called 15x1 or 705 H. That indicates the length, the circumference
etc. If the needle you received with the machine is the same length as the above system then you should be ok. Also most often the needle package for most machines will be labeled "Universal"
Aug 04, 2014 | Singer Handy Stitch Hand Held Portable...
My wife broke several needles on her Juki DDL 555 machine and I need to know how to adjust the timing as she put a new needle in and the point was damaged
First thing to check is if you've got the right needle system: http://partsbooks.sewingmachine.com/Instructions/Juki/Industrial/DDL-5550%20&%205530%20Instruction%20Manual.pdf and that the needle is correctly oriented... the scarf has to be precisely set.
The next things I'd check are the stitch cycle -- hand crank the machine through the normal stitch cycle and see what's hitting. Then fix that. I've got my suspicions this may be a needle bar height adjustment. Don't thread up for this test... misthreading can also cause the needle to hit something and break, so start with the fewest possible variables first.
Feb 18, 2014 | Juki DDL-5550 Industrial Straight Stitch...
Bobbin thread is tangling around bobbin carriage as I sew. So I can only go a few stitches before the machine stops sewing and it's tangled.
Hello
This is Really not that big a problem. Simply pull out the bobbin thread with a long lead, put the assembled bobbin into the sewingmachine and take that long thread and close it between the sliding door and the machine itself to hold it temporarly.
Most sewing machine problems are caused by the usasge of wrong thread type. Make sure you have a thread that is for a sewing machine use, that is, good strong stuff, not hand needle basting thread as that will cause much problems.
Often the bobbin is thought to be the problem, those things are almost never the problem. A source of problems also is the usage of wrong or improperly machined flat on the needle itself. Be sure to buy a quality needle as that flat on there, if machined not deep enough will not allow the bobbin to pick up the thread, wind it around and form the stitch.
Jul 12, 2011 | Singer 4830
How do i thread my needle with the singer handy stitch?
Nov 11, 2010 | As Seen On TV Handy Stitch Mechanical...
Handy stitch sewing it goes into motion of sewing, but it does not stitch at all, I opened it up to see what it going on inside and I see that the thread does not hook. What is wrong! Can you help me...
First, try making sure the needle is in the correct way, second you have the needle threaded from the correct side.
I am sorry to inform you that these type of machines are nothing more than a toy. As the old saying goes, "you only get what you pay for"
Dec 12, 2009 | As Seen On TV Handy Stitch Mechanical...
Stitch unravel
Try changing the needle it might be dull
Feb 16, 2009 | As Seen On TV Handy Stitch Mechanical...
Friends broke needle on my euro pro multi stitch sewing machine.
According to Euro-Pro.com
Where can I buy new needles?
Answer: The needles are universal and can be purchased at any sewingmachine notion department. The size and type of needles should beappropriate to the fabric used. See the needles and fabrics chart inyour instruction book.
http://www.euro-pro.com/europro/faqdetail.aspx?modelno=9000
has all the information including a downloadable manual (pdf file)
Jan 24, 2009 | Euro-Pro 9120 Computerized Sewing Machine
i cant sew i try and do all i can i just seem not to get it to work.
Apr 01, 2008 | As Seen On TV Handy Stitch Mechanical...
As Seen On TV Handy Stitch Mechanical Sewing Machine Logo
145 people viewed this question
Top As Seen On TV Sewing Machines Experts
Harjeet Singh
R.A. Ellis
R.A. Ellis
CrisO
Are you an As Seen On TV Sewing Machine Expert? Answer questions, earn points and help others
