Question about Sanyo PLC-SW30 Multimedia Projector
Yellowed image projection
I have an issue with the quality of projection. The image itself is clear and legible however there is a strong yellow cast to a portion of the image when projecting. When the projector is powered on and projecting only light (not connected to a laptop), the same shape appears but as a darker blue. I've tried replacing the lamp and power cord with no change. Help!
    President:
  • 1,073 Answers
The yellow you see is all dust on the mirrrors inside your projector.
If u are lucky you can get the mirrors cleaned by a pro, if you are unlycky as i was, the blue mirror has burn and u need to replace it.
Take your projector to someone who repaire tv:s ot other electronics, they will help you. If its only the cleaning its cheap, if you need to replace a mirror its expensive.
Good luck
Posted on Dec 02, 2008
Picture blurred with yellow cast
Its a Dlp that uses a lamp---the yellow cast suggests a damaged Optical light Engine----Google the model number with problems and you may learn more---if the engine is bad it may not be cost effective to repair the set.
Dec 08, 2012 | Hitachi UltraVision CineForm 55VG825 55"...
First, it is not a printer, it is an LCD projector, Hitachi RS55. I gives a yellow screen and all images have s strong yellow cast as if there is no blue component. Changing the settings of colour makes...
This is due to the problem with the active component (capacitor) in the Blue beam generator. It might gone, so you better replace the same or take it to the authorized service station.
Jul 28, 2009 | Office Equipment & Supplies
Tip
I have the overall yellow tint in my lcd monitor there are no magnets close to...
The discoloration problem is due to the near by magnetic field appliances like speakers which are very near to monitors ...
so what you have to do is just keep some distance to the monitor from the speakers and other magnetic appliances and then press menu button & just give degauss..
on Mar 16, 2008 | Sony SDM-HS73P 17" LCD Monitor
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
We have an Infocus X3 unit that is getting a yellowed image
the colorwheel is collapsing and needs replacing. you can get one from any infocus authorized service centers and do it yourself or have them do it. if you are in ny, try av solutions. they've always done good work for me.
Oct 02, 2009 | InFocus DEMO X3 1600LUMEN XGA DLP MMPROJ...
Blue color bleeding
the color issue is most likely the crt coolant needs to be replaced you can get the phillips CRT coolant replacement kit at the following link which contains the coolant and the instructions on how to do the replacement.
http://servicemanuals.vstore.ca/
The crack you hear could just be the speakers or a intermitant ground problem in the audio circuit more likely the spealers if its only on strong Bass
Apr 03, 2009 | Philips 55PW9363 55" Rear Projection...
Nec projector vt 660
could be bad bulb is it setting in right is coler wheel freeley moving
Oct 06, 2008 | NEC VT47 Multimedia Projector
ViewSonic VE710b 17 inch yellowed photograph look
Check and make sure that there is no speaker, power supply or UPS around your monitor.
Mar 16, 2008 | ViewSonic VE710b 17" Flat Panel LCD...
Colour Cast
Updated section
This red issue has been bugging me over the last week. I have now created over 50 A4 prints of my test file and it was after reading a post from Dan P that the answer came to me. I had been trying to correct the over saturated reds by reducing it in curves, levels and colour balance. Of course this was not the way to go, unless the image has an overall cast. The better method is to enter into Selective Colour within Photoshop and adjust just the red only. The values I have used are Cyan + 15 (this reduces the red), Magenta -5 (removes the remaining traces), Yellow +10 (removes the blue and warms up the skin again), Black -15 (lifts the image). Save the settings and reload them on future images. Create an action and use one of your Function keys to apply the Selective Colours. Incorporate the print command within the same action, this way you can be certain that the selective colour will be applied each time you print. This may not be the ideal solution, but for me it will do for the time being, until Canon come up with a new profile. I expect to make colour adjustments on most images and this is just one of those steps.
8500_06.jpg ink.jpg Use the Selective colour adjustment - it works The ink levels after 55 A4 prints - I don't think so final-test.jpg final-reels.jpg As near perfect as I can get it Reels are now spot on Note: The above solution is a work-a-round which cures the excess red, once you apply the Selective Colour adjustment the screen image will not look right. The adjustment is applied to correct the printed version. Like so many things digital (and analog) you have to make adjustments to suit your own preferences. The strong vivid colours produced by the ip8500 will appeal to some, others may want to tweak their settings.
As a final note, I have just looked at the ink levels after 55 A4 prints and wow, this printer only uses the light Cyan and Magenta, the rest of the colours are all unused. I don't think so somehow. Canon, I think this does indicate that you have a problem with the driver and have another look at the profiles while you are fixing that.
Would I buy this printer?
Given that creating a new profile is not a major problem and I am sure a new one will follow very shortly, then yes I would buy it. Using Photoshop I have managed to correct the colours to suit my taste, however, some may like the bolder colours out of the box. The ip8500 features and image quality makes this printer stand out from the competition.
Price - £329
Pros:
Excellent photographic print quality
Lots of useful features
Speed
Separate ink tanks
Compact design
Cons:
The PictBridge port can't be used to transfer images to a computer
Colour needs to be sorted out
Black plastic case that reminds me of a cats coffin.
Print quality 85* Features 97 Ease of use 97 Design 96 Value 95 Rating 94 - highly recommended
* Note that this mark is for image quality and colour quality
www.canon.co.uk
Dec 18, 2007 | Canon PIXMA iP8500 InkJet Photo Printer
Duall image and strong yellow and green at bottom of screen
you have bad connections on convergance ic solder them if that does not fix then replace them
Nov 03, 2007 | Toshiba 50HX70 50" Rear Projection...
Sanyo PLC-SW30 Multimedia Projector Logo
404 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
Electro Med Services...
k24674
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
