Question about Home
Leaking Bristan shower
Bristan 1901 recessed shower is leaking
2 Suggested Answers
  • 12173 Answers
SOURCE: temperature too hot on bristan art deco mixer
if the water is that hot then lower [adjust] the temp of your hot water heater -if need to adjust the shower you can adjust the mixing by removing the handle and on the valve stem are the adjusting clips the red [hot] and blue [cold]plastic clips can move them around to adjust the mixing of hot and cold water
Posted on Jul 23, 2010
Bathroom tile
If I need to replace a broken recessed soap dish in the shower then I would definitely contact with a professional as they can fix this problem very easily.
Jul 16, 2013 | Home
How to stop a dripping Bristan shower?
Hi Paul it could be mixer valve, when not closing properly.Reason of tear washers or faulty valve manufacture issue.Hope it helps.
Sep 16, 2012 | Home
The Fairmont has no apparent way to remove the handle to permit replacement of the cartriodge. How?
they either have a small cap on front to pop off then screw under cap..or they have under or to side of handle a very tiny set screw recessed...it is a allen screw...loosen and pull out...
Mar 12, 2011 | Danze Sheridan Tub & Shower Faucet
My Bristan Meridian Show start ok with hot water then after a few minutes the water runs cold. Even if you try and increase the temp it still remains cold. You can switch of the shower and start again...
It sounds like 1 of 2 things to me. I will start wit hot water heater. The first test for the water heater is to have someone run the hot water while you hold the hot and cold pipes and see if the water is coming out of the water heater cold when the shower goes cold. Of the water heater is cold coming out then the problem is in the heater. ether a lower element is bad or the dip tube is broken at the top of the tank. if the hot water heater continues to put out hot water when the shower goes cold then it has to be the mixing valve for the hot and cold mix at the shower and that valve will have to be repaired or replaced. hope this gives you a good start. let me know if I can help further.
Dec 24, 2010 | Home
Temperature too hot on bristan art deco mixer shower even on lowest temperature setting.
Jul 23, 2010 | Home
Leaking shower faucet
I do believe that Delta guarantees their faucets for life. Go online to get the 800 number and call them, have the model number ready. They actually sent my girlfriend a replacement for her $300 kitchen faucet and also the guts to 2 bathroom faucets. They come with diagrams also. Of course I had to install them, but they stand behind their stuff.
Nov 20, 2009 | Delta & Single Handle Shower Faucet
How far from the shower head do recessed lights have to be fitted
552.54 Luminaires.
((B) Shower Luminaires. If a luminaire is provided over a bathtub or in a shower stall, it shall be of the enclosed and gasketed type and listed for the type of installation, and it shall be ground-fault circuit-interrupter protected.
The switch for shower luminaires and exhaust fans, located over a tub or in a shower stall, shall be located outside the tub or shower space.
Essentially there is no distance specified BUT the fixture must be sealed AND protected with a GFCI
Nov 17, 2009 | Westwind Classic Hugger Polished Brass 52"...
Walk in shower leak into room below
I would unscrew shower head pipe and either pipe dope it or tefilon the threads and then reinstall it. I would also take the handle(s) rosettes off and look for a leak from there with a flashlight, while shower is on. I believe the most comon leak for walk in showers are the door seals. Are you sure it is not coming out from under the door? Another test that yuo may want to preform is to Stopper the drain, fill the shower pan with water and watch for bubbles, or look for leaks from below.
Mar 20, 2009 | Home
Home Logo
51 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
