Question about Panasonic DP-3030 Grayscale Copier
PANASONIC DP-3030 DUPLEX PROBLEM
Single sided printing works great. When ever duplexer is used, first side prints fine but jams when it is sucked back into print second side. Have replaced duplexer unit, dc controller, drivers, have had a tech out for hours working on it to no avail. HELP!! You can actually watch the papers go through the duplex part of the machine. Suddenly one will bend at a corner and cause a jam. There is also an odor like the machine is hot. This machine is less than 2 years old.
2 Suggested Answers
  • 643 Answers
SOURCE: Paper jams only while duplexing
What kind of brand and model of your copier?
U need to perform checking on the exit unit and fuser unit for physical deforms also.
Other than that, u also need to check the temperature, if too hot, try to reduce it, cosz it will affect the paper quality on 1st heating. What kind of paper u r using? Recommend 80gms ...
Posted on Mar 12, 2009
Duplex feed not working
Check the C6200 Device Settings in the properties and make sure that the Duplex Unit is installed.
original?v=mpbl-1&px=-1
Dec 09, 2013 | Brother HL 5250DN Laser Printer
Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Sep 09, 2008 | Minolta magicolor 2350 Laser Printer
HP Laserjet p3005x printer - Just received this printer from used stock. Every time we try to print in duplex, the paper jams under the toner cartridge after printing the first page and then being sucked...
Hello, This problem is commonly caused by what is known as the (DPA) duplex pendulem assembly. The function of th DPA is to switch the direction of the paper in order to print the duplex side. The DPA sometimes will bind and not work properly which results in the paper jam you have described. See Photo Below.
Pendulum assembly RM1-3748
In order to change this part, the printer needs to be dis-assembled. AN HP Certified Technician would be best to do this repair.
Find a Rpair Delaler near you USA http://h20465.www2.hp.com/GPL/search.aspx?language_code=en&country_code=us&SearchType=SSP
Dec 17, 2010 | HP LaserJet P3005x Printer
Panasonic workio dp-1820, double sided printing take off
Look for a setting in the print dialogue box, about 2 sided or duplex printing
Apr 24, 2009 | Panasonic Workio DP-1820P Laser Printer
Mar 12, 2009 | Panasonic DP-3030 Grayscale Copier
Copy/Printing machine jams
This tells me your DUPLEXER is the one causing the jam, Ok like when you open the duplexer do you see the paper in their
second does your copier indicae that the duplexer is in stalled ?m print the config page to verify. if it worked ok until this incident then your paper feed tires in your Duplexer is worn and needs to be replaced, do not do this yourself call a Service tech or A dealer to do so, uf your in CT we can help.
Mar 06, 2009 | Panasonic Workio DP-3530 Copier
Oki C9300 - paper keeps jamming in the 2 same places, reads either 383 paper jam or non paper sense error. All drums and tonners are new, paper is loaded.
your getting a 383 paper jam, find paper in two different places.
See if it's a duplex related problem. print single sided documents, if that works, try printing two sided documents (it'll be the duplexer) if it only fails while printing duplex.
Also, check the back door. Make sure the back exit tray is closed all the way.
You can also have a paper jam in the duplex unit (open the front door), the duplex unit slides out the front. You can easily remove the duplex unit and run the printer without it.
Oct 20, 2008 | Office Equipment & Supplies
HP 1320 duplex printing paper jam
Managed to solve this myself: I disassembled the printer and noticed there was a paper jammed in the duplex tray. Rolls were all ok, but the paper blocked the use of the duplex pathway. For disassembly help check the HP 1320 service manual, which you can find on the net as a PDF.
Jul 14, 2008 | HP LaserJet 1320 Printer
Back door broken, diverter gate broken?
I would look for something like this. did the tech clean the duplexers tires??
I would also try a different duplexer if possible-paper path sensor may be dirty or obstructed
Mar 07, 2008 | HP LaserJet 4350 Printer
I am trying to print double-sided copy on card stock
HI there sounds like there is a blockage in the duplex area that is not holding any sensors down. Check the duplex area for torn paper, failing this it maybe a sensor problem which will then need a engineer.
Hope this helps
Thanks J
Jan 30, 2008 | Brother HL 5250DN Laser Printer
Panasonic DP-3030 Grayscale Copier Logo
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
