Question about Canon iPF700 InkJet Printer
Can't allign the paper.
Have tried to allign the paper and to no avail it will not load. Tried to cut a single sheet and load that as well. Still will not load.
Help!
  • helen207 Oct 23, 2008
    Took roll out, pulled it tight. Re-loaded the roll, made that tight. Put the paper in and pulled it through about 3 feet. Closed everything, it attempted to load and told me again that the alignment was off.
  • 34 Answers
Make sure that the paper roll is pushed all the way down on the rod and the piece that you put on it is fitted snuggly against the roll. When you pull the paper through the feeder pull it about 2-3 feet outward and it should align.
Posted on Oct 23, 2008
Paper wont load
The obvious thing is to turn the printer off, remove paper tray, take out the paper, look to see if anything clearly amiss with either the printer or the paper tray itself, reflll the paper tray with a moderate quantity of preferably fresh paper - though this should not matter - and replace the newly-loaded tray. Turn the printer back on and see if it works or not. You may also try single sheet manual feed if this available for your printer.
12.March.2015
Mar 12, 2015 | Office Equipment & Supplies
How do you remove the top to see the gears in a Royal 16CDX cross cut paper shredder. The overload message is displayed, and I don't know how to get it unjammed.
a possible solution is to UNPLUG the unit, reach in from underneath and start pulling stuck paper out. On mine (different model) I can remover the paper receptacle bin and reach up to remove stuck paper. this usually is caused by overloaded bin pushing shredded paper back up to cutters because it is overfull......BE SURE TO UNPLUG FIRST !!!!!
Nov 17, 2012 | Royal 160MX Also called 16CDX Cross-Cut...
Load error
When trying to print on continuous stationery, the display may show "Online Single Load". This will occur if the printer is expecting to print on single sheet paper even though you may want it to print on continuous paper. To clear the error follow this procedure. • Take the printer off-line by pressing the Online key • Press the Setup key • Press the key under "Paperway" in the display • Select Tractor 1 (or Tractor 2 if fitted/required) • Press the key under "Set" • If the job still refuses to print try loading the printer with a single sheet of paper to clear the command. To do this remove the tractor feed paper and close the cover on top of the tractors but not the outside cover. You will see a guide into which put a single sheet of paper and press the key under "Load" in the display. • The printer should commence printing. If it does not, then press and hold the key under "LF/FF" to eject the single sheet. Now follow the instructions above again to select the Tractor. The display should read "OnLine Tractor Load". Load the tractor fed paper into the Tractors and press the key under "Load". The printer should now be ready to print. Check your software settings for the correct paper path type. Ensure that the display does not show "Manual" otherwise you will have to clear this error in the same manner as you have for Single sheet
Dec 06, 2011 | Tally Dot Matrix T2265C Printer
Epson Stylus photo 340 r printer paper jam when trying to print
first, make sure you the paper correctly to avoid paper jam.
Single Sheets 1. Open the paper support and raise the extension. 2. Place your paper short edge first against the right edge of the feeder, under the tab, with the printable (whiter or glossier) side up. If you are loading multiple sheets, fan the stack of paper before loading it to prevent paper jams. Note: Don’t load paper above the arrow mark inside the left edge guide. Some special papers can be loaded only one sheet at a time. Slide the left edge guide against the paper. Make sure it is snug, but not so tight that the paper is bent. (For letter- or A4-size paper, you may not need to move the edge guide over.) paper.4.2.1.jpg 4. Open the output tray and pull out the extension. You should also follow these guidelines:Always load the short edge first, even when you’re printing landscape-oriented pictures. • When using special papers, check the paper package for additional instructions. Some papers require using a support sheet included in the package. Note: Always keep unused paper in the original package and store it flat to prevent curling.
if you loaded the paper, it jammed again, remove the paper and tried to print, still the same, its a hardware issue, alraedy, the printers roller is broken
Feb 09, 2010 | Epson Office Equipment & Supplies
When I try to print photos from a memory stick it fails to print and tells me to load paper glossy side down even though there is enough paper properly loaded. When I take out the paper the top sheet has...
The problem is that the metal paper stop is not fully recessing into the guide at the rear of the printer and the photo paper is catching on the lip on top of the stop. Take the back cover off the printer and check that the guide has not moved out of position. Also try to twist the photo paper tray to the left or right so the stop lines up better with the guide recess. This worked for my printer tempoarily, but then things went out of allignment again, so I took a slightly more drastic step. With only a single sheet of photo paper in the tray, print another photo. When the photo tray slides back to deliver the paper to the rollers, unplug the power cord from the rear of the printer to stop the tray from moving forward again. With a pair of needlenose pliers, bend the lip on top of the metal paper stop upward. This fixed my problem permanently.
Oct 19, 2009 | HP C7200-69016 Network Adapter
When loading 1st sheet of paper, the white guide bar on the left does not move to the right & the paper jams between the print head & the curved guide above. Chris of Devon England.
Hi, this is a vey common fault.If you look down where the white runner is you should be able to see two grooves cut in the base of the unit.This is the guide for the white plastic arm you are referring to. What you need to do is take a paper clip, open it out so you have a pointed end available. Push it in to these grooves and run it along to the left hand side. You'll find paper debris is stuck in these grooves which prevents the printhead from pushing the white arm across enough so it will not return. Because the arm cannot get far enough to the left hand side it sticks and you will encounter paper jammimg under the plastic guide on top of the printer. This is a very common problem on this model of printer and the Oki 520
Oct 15, 2009 | Samsung OKIDATA - OKI Microline 590...
My photosmart C3150 printer keeps feeding many sheets of paper when it goes to print. This causes a paper jam. How do I get it to only take a single sheet?
Try cleaning the rollers with purified water. See instructions here. Also make sure you fan the paper before loading, try flipping it upside down, and see here. If you have no luck, try another brand of paper, or loading more or fewer sheets...
Good luck, that's a frustrating problem...
Jul 30, 2009 | Office Equipment & Supplies
Photo paper loading
is this still current issue?
Apr 15, 2008 | Canon PIXMA iP1600 Printer
SCX-4216 "No Paper" message
I've had this happen to my scx4521f a few times. I think I had too much paper in it. Or maybe it was poorly loaded paper. Take the stack of paper out and turn it around so you have no dings or dents on the inward facing side. You need to make sure that the paper is stacked evenly. Good luck. And now I will post my problem.
Apr 09, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Loading cut sheets
Try to check the paper media set on the plotter (roll/plain paper). It usually happens if paper media is not the same with the plotter setting. To change it, unload the paper, press the media button on the printer to the right media and load the paper again. It should work now.
Dec 06, 2007 | Canon iPF700 InkJet Printer
Canon iPF700 InkJet Printer Logo
176 people viewed this question
old marine
old marine
