Question about JVC AV-27D302 27" TV
TV, i plug it in, turn it on, no image, "on timer" light comes on.
JVC D- Series, AV-27D302 TV, i plug it in, turn it on, no image, "on timer" light comes on. I tryed unplugging it, all the buttons on the remote, nothign seems to work.
  • Anonymous Dec 12, 2007
    same problem with timer
  • Anonymous Feb 27, 2008
    I have the same problem.
    The television has not been turned on since 2005. Should I throw it away?
    President:
  • 3,130 Answers
If you dont hear a click theres a problem in the standby power supply. if you do hear a click theres a problem in the Main power supply or sweep supply. Get a good tech to look at this for you if your not a tech. Good Luck
Posted on Aug 07, 2006
Tv shut off and the timer light is blinking. we unplugged tv but its still happening. please advise
hello,usually the cause in jvc tv is, a bad contacts on the vertical chip leges. you should solder those contacts. another option is to change the vertical chip . more rare is a missing of the 27v voltage that goes to the chip. in that case you should check the port of the high voltage transformer.
good luck!
Jan 29, 2011 | JVC AV-27D302 27" TV
On timer light is flashing.and tv shuts off in about 5 seconds after turnig it on.
Hello
Timer function is in ON position and have been set to the least time I thinks. You just go to the menu and put the timer fuction of OFF.
The On/Off timer lets you program your television to turn itself on or off. You can use it as an alarm
to wake up, to help you remember important programs, or as a decoy when you're not home.
Press the MENU button
Press UP or DOWN button on the remote control hanset to ON/OFF TIMER
Make it OFF.
Switch off the TV by its front panel power button, and switch it ON again after 10 seconds.
OK.
Dec 06, 2010 | JVC AV-27D302 27" TV
My tv will not turn on and the on timer light is
Try the following blog. It has detailed instructions on how to fix a common problem on this JVC TV series. I did and I fixed my TV for 2 bucks at home.
Good Luck...Kim
http://brentlavelle.blogspot.com/2007/12/i-fixed-my-jvc-av-36980.html
Jan 14, 2010 | JVC AV-36950 TV
AV 1, AV 2, AV 3, but no TV
that's thing happening you tv epprom ic. replace back same # epprom . good luck!
Mar 21, 2009 | JVC AV-27D302 27" TV
JVC TV with time displayed and will not turn off.
use your front control button to try to enter yoyr menu settings and if possible turn off display function.
Oct 22, 2008 | JVC AV-27D302 27" TV
My JVC TV Problem
hi.. sir
if universal remote does not work properly.. i am not sure
just open the tv and see if any cmos battery is inserted .. in circuit board.. if any present.. answer me sir..
Sep 01, 2008 | JVC AV-27D302 27" TV
Av-32d302 tv
The set is shutting down because a problem has been detected. Replacing the remote will not help. Count the flashes and call a JVC servicer to get an idea about what the specific problem may be.
Dan
Jul 29, 2008 | JVC AV-32D302 TV
In a large number of failures with these symptoms it's usually the HOT (horiz. output trans. Q522, which is a 2sd2499) and the regulator (Str30134), together with fuse F902 (Gma 1.25a). Not an expensive repair or that complicated if you're fairly good with electronics and know how to solder correctly. Otherwise take it in and have it repaired professionally - it's worth it...
Bill
Nov 29, 2007 | JVC AV-27230 27" TV
Jvc av-32fa44 television
My JVC AV-32FA44 wont turn on. the on timer light blinks. When i unplug it and plug it back in i get beeping (i stoped counting at 50 beeps) then it stops and the light just blinks.
Jan 12, 2007 | JVC AV-32FA44 32" TV
JVC AV-27D302 27" TV Logo
259 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
