I have a wood burning stove fitted in our modern home. The stove has a vertical flue pipe fitted from the top and up through a purpouse built chimney liner in the ceiling. the lower parts of the system are enamal pipe and the remaining parts are stainless steel liner. We have just started using the stove again for the second season and this time we have lots of sticky black tar dripping and running down the OUTSIDE of the flue, eventually dripping down to the top plate of the stove creating horrible smoke and fumes. The flue was cleaned recently. Firstly, what is causing the tar? and secodnly why is it coming down the outside and can it be stopped? Thanks in advance
    Habit-Forming:
  • 47 Answers
(1) The lower "enamel" pipe is possibly Ceramic coated pipe, used for high temperature flue applications.
(2) The "stickey black tar" is creasote. Whoever installed the flue pipe did it wrong. It needs to be reversed so that the "Crimped" end of the pipe is pointing down. That way the creasote will drain back into the stove and get burned up.
Posted on Apr 02, 2017
  • 1462 Answers
SOURCE: I have just fitted a
i have seen this problem solved by fitting a fan at the top of the chimney - sounds daft but it worked. was in a house in france
Posted on Sep 01, 2008
Richie_asg1
  • 1036 Answers
SOURCE: Water and debris in flue liner of Jotul Stove
You should have a swept T connector at the base, with the sweep going from the stove upwards, but the other end of the T going into a removable cap - or very short length of pipe. If you only have a standard bend - replace it with the T.
This is actually normal for wood burners. In an unlined chimney, the lighter "tar" fractions from the wood would soak into the brickwork, and show through the wall in a few years. In a lined system - they have to go somewhere, and usually condense inside the flue - running back down to the base.
The "chinese hat" style cap is actually very good for everything except sideways hail.
Sorry - but it's the nature of the fuel. It is possible to use a clay based absorbent at the base - Cat litter is actually fine.
Posted on Jan 03, 2009
gasman44
  • 83 Answers
SOURCE: I have just opened up my chimney and took it back
You will need to install a flue liner ( i know its a nuisance) to allow the products of combustion to escape as quickly and as safely as possible.
If you installed a gas appliance without a liner, due to the temperature of the flue gases (lower than solid fuel) the emissions would struggle to exit via the flue terminal.
If you install the appliance following the manufacturers instructions, you cannot go wrong. The other recommendation is get a 'Gas Safe' engineer to carry out the commssioning/testing.(house insurance void if not certified)
I hope this helps.
Posted on Jul 07, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: does the chimney need a
If the fuel is either wood (or any wood products) or oil it is required to have a stainless steel liner. Gas burning appliances need an Aluminum liner. Make sure it is sized correctly and not over sized.
Posted on Feb 17, 2011
  • 4736 Answers
SOURCE: i have a sfw 55
It may be the type of coal you're burning. Have you tried burning anthracite coal rather than Bituminous coal? It's a little more expensive, but it burns cleaner. Also, you may need to open the air intake a bit with what you're currently burning. That way it will burn a little hotter and hopefully cleaner.
Posted on Mar 07, 2011
How do I stop downdrafting? Is there a damper that could be installed? We live off grid and power consumption is a consideration for us.
Downdraft will extinguish the pilot light flame too. there are flue fans that run off solar. You might want to look into one
Mar 09, 2016 | Water Water Heaters
I have a free standing wood burning stove Hearth Stone brand Is there a product that one could wrap the chimney flue with to avoid a small child from burning its hand? Thanks
There is a completely double insulated flue pipe available on the market by SELKIRK and more
INSULATED stove pipe DIY CHIMNEY FLUE - YouTube
? 4:06
https://www.youtube.com/watch?v=D6AHJ_XbOCo
Oct 19, 2011 - Uploaded by ROCKNTV1
CHIMNEY FLUE DOUBLE WALL INSULATEDhttp://www.rockntv1.com/2011/10/insulated-stove-pipe-diy .. And see google for vendors
Nov 29, 2015 | Home
I need to build a hearth for my Waterford 106 Wood Burning stove. How big should it be? Especially, what did Waterford recommend when it built this stove?
Anyone heard of a Waterford 103? ' Hearth.com Forums Home
www.hearth.com/talk/threads/anyone-heard-of-a-waterford-103.9653/
Nov 28, 2007 - Hello, I'm new here and I have a stove in my house that arrived with no... Does anyone know anything about this stove? Coal? Wood? Age? Make? ... The 103 was a wood-burning "Fireplace Stove" from the mid-80's. Installing an insert without using 6" flue liner tube because of ...
Sep 23, 2014
Looks like it's officially 24/7 burning time...
Dec 10, 2009
More results from www.hearth.com
Wood Stove Hearth on Pinterest ' Corner Wood Stove ...
https://www.pinterest.com/explore/wood-stove-hearth/
Pinterestfrom My Paradissi ... decorating around a wood stove ' Cosy wood burning stove fireplace: how to decorate around it. love the ... 893 106 ... wood burning stove hearth ideas ' old wood stove on brick hearth by Brian Powell - Stocksy United . .... Corner Wood Stove Surrounds ' How to Build a Hearth for a Wood Burning Stove.Missing: waterford
Oct 21, 2015 | Home
Can't keep the wood burning in stove. How does the buck stove take in air?
To burn properly, it needs proper combustion air and proper draft. Draft is effected by the size and height of the flue the appliance is connected to and by how much combustion air is available. The appliance flue connection should not be reduced to fit a smaller chimney size. That is, an 8" flue should not have an 8 x 6 reducer to vent it into a 6" chimney.
The wood you are burning could contribute to a poorly burning fire. To burn properly, the wood needs to have been "seasoned" for a minimum of 1 year or close to it. Two years is even better. "Green"
or freshly cut wood contains an unbelieveable amount of moisture in it and a tremendous amount of the heat is wasted just "preheating" the wood to the temperature that causes it to release gasses for ignition.
I don't know the style or model of your Buck, but all wood burning appliances should have combustion air dampers of either a sliding design, rotating round design or hinged design with handle at the bottom front of the firebox. I'm sure there are some fancy new designs that have air piped in from outside the structure.
Every wood fired stove, fireplace or furnace has its own idiosyncrasies and its up to the user to determine what's required for making it operate as designed.
Dec 06, 2014 | Buck Stove Home
Why does my blazeking wood burning stove get creasote in the fire box and how do i get it out?
Hi Darlene,
Creosote consists of combustion byproducts,[smoke] that gradually builds up in the stove & chimney.MOISTURE in the wood,and slow burning greatly increase build-up. 1/4 '' of creosote is considered a hazard. Consult a professional chimney sweep,then burn only 'seasoned' dry hardwood,and when you start or re-kindle the fire,burn it hot enough to thoroughly heat the flue; this will draw the smoke up the chimney faster,decreasing the time build-up can occur. Stay Warm!
Nov 25, 2014 | Home
I bought a house with a wood burning stove but I don't know how to operate it
First make sure everything is clean,from the chimney to the stove.insure all metal flues are tight from stove to chimney. Open damper on top of stove(some are in metal pipes). Open your draft vents, usually on clean out door at bottom. Depending on chimney draft you may need to open clean out door to get it started. Load your kindling and get it started. Add bigger wood as it catches. Turn down venting and drafting as the fire roars. Just don't shut draft before vents. You'll get used to balancing draft and vent as you go. I hope this helps
Nov 19, 2014 | Home
How is air supply regulated in wood burning stoves?
To regulate air flow, there are damper devices built into the stove, flue and stove pipes. Keeping the air flowing correctly through a wood-burning stove is essential for safe and efficient operation of the stove. Fresh air needs to enter the wood compartment to provide oxygen fuel for the fire; as the fire burns, the smoke must be allowed to rise through the stove pipes, and exit through the chimney.
May 07, 2013 | Home
Jan 03, 2009 | Kitchen Ranges
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
