Question about HP Officejet 7210 All-In-One InkJet Printer
Hp 7210 remove and check color cartridge - HP Officejet 7210 All-In-One InkJet Printer
SOURCE: Printer telling me to remove and check right bay ink cartridge on hp 2410
Just some ideas you probably already tried: 1. make sure you took off the bit of paper / tape covering the vulnerable bits. 2. try another cartridge and/or a friend with similar machine & cartridge 3. make sure you load it correctly: only when machine is turned on, the slight overhang at top each side aligns with grooves, and you are reading the number OK from the front = it is in the right way (deeper end at back). 4. Keep searching different Google reviews and knowledge bases- with different questions.
Posted on Apr 11, 2007
SOURCE: Remove and check color cartridge
I, too, am getting the cartirudge error (mine is for the black side) and I am unable to proceed past that message. I do see the broken tab which aligns the metal spring inside the plastic cartridge holder, so the spring is hanging. I suspect that this is the problem (I think I may have done that when I attempted to put the color cartidge in the wrong side in error?). Anyway, does anyone know where I can find a repair manual for the HP 2610 and where I can get the part to fix this?
THANKS!
Doug
Posted on Dec 19, 2007
the problem is the little poorly designed metal thing that is holding up the ink cartridge get's stuck between the cartridge and the printed circuit and it brakes the circuit.must have been some **** drawering on a napkin that came up with that one.wasted a nice unit for that two cent piece of metal.
Posted on Jul 31, 2008
SOURCE: HP G85 All says remove and check color cartridge and prints only green/blue color
This is a known issue on this machine. What I do is open the printer as if replacing the cartridge and allow the cartridge holder to move to the exchange position. Then I unplug the power cable from the back and close the printer again. Keeping your finger on the power button, plug in the power cable again. Keep the button pressed for about 10 seconds, allowing the error flag to reset. Switch on again and wait for the initialise to finsh. It sometimes takes another 5 minutes for the message to disappear but it should go eventually.
Posted on Sep 05, 2008
SOURCE: "Remove and Check Color Cartridge" won't go away w/ new cartridge
Replaced with brand new HP cartridges. If either one (black or color) is a refilled cartridge, my machine has issues.
Posted on Dec 21, 2008
I have an HP Officejet 7210 All-in-One. I would like to know if there is any way to print a document that only needs black ink, even though a message always pops out that I have to remove and check the...
Hi
Black is not True black. It is slightly brown.
Printing in black uses mainly black but may also a tiny amount of a mixture of some of the other colours.
To minimize the usage of other colours:
HP Solution Center > Settings > Print Settings > Printer Settings > Color > tick Black Print Cartridge Only > OK.
HP ink can be expensive. It is possible to economize on HP inks in some cartridge formats by using Ink refill kits.
I hope this helps.
Aug 24, 2011 | HP Officejet 7210 All-In-One InkJet...
HP officejet 7210 error message color ink refill
this error is recomded for the printer becouse printer will count the print out
Apr 12, 2010 | HP Officejet 7210 All-In-One InkJet...
I have the HP officejet 7210 and after refilling the color ink, it asks me to check the color cartridge and refuses to print. is there a way to hack the cartridge so that i can continue to refill?
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Jan 13, 2010 | HP Officejet 7210 All-In-One InkJet...
Message says Remove and check color cartridge. We
The cartridge cavity in the printer may need cleaning.... perhaps a colorful "spit wad" is lodged in the cavity.
If the printer will allow, run a "clean nozzle" utility from the printer or computer.
Hope this helps!
Sep 08, 2009 | HP Officejet 7210 All-In-One InkJet...
Printer won't recognize color cartidge
Did you try another cartridge? Try reinstalling the old cartridge and see if the message is different. If so, replace the cartridge.
Aug 18, 2009 | HP Officejet 7210 All-In-One InkJet...
Not recognizing color cartridge
Possible cause the silver spring came away from side of cradle and damages the ribbon behind!
Jul 16, 2009 | HP Officejet 7210 All-In-One InkJet...
The ink cartridge I replaced in my printer is not working.
I have one of these printers (7210-7310) with this same problem and this is what is wrong with it. There is a small wire spring that holds the ink cartridge in place in each cartridge holder. Remove the color cartridge and inspect the ribbon cable (it gray) inside the ink cartridge holder. There is a big problem with these HP printers where the spring pokes a hole the ribbon cable breaking one of the wires and rendering the printer useless. Poor design by HP, sorry.
Mar 07, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Remove and ck right cartridge
Once remove both the cartridges from the all-in-one and then clean the copper contacts of the cartridges and then put only black cartridge and check for the message displayed on the all-in-one if it even reads check right cartridge then the issue is with the all-in-one hardware. If it reads insert right or color cartridge then the issue seems to be with the cartridge.
Remove the cartridges from the all-in-one and power cycle the all-in-one and then reset.
Now insert the cartridge and check for the result. If the issue still persists then check the expiry date on the cartridge and once replace the cartridge and check for the result.
May 27, 2008 | HP Officejet 7210 All-In-One InkJet...
Last night I spent an hour with HP Technician on-line trying to diagnose the problem with my 2 year old HP Officejet 7210 All-In-One. After trying everything HP came up to resolve the problem, the technician determined it is a hard failure in the electronics hardware. Since my warranty is expired they offered me a deal on the L7680 All-In-One. My 7210 was very lightly used (still on first set of cartridges). If this is the quality of the latest generation of HP hardware, I am probably going to look at something else.
Nov 28, 2007 | HP Officejet 7210 All-In-One InkJet...
HP Officejet 7210 All-In-One InkJet Printer Logo
121 people viewed this question
Seeker5211
Seeker5211
