Question about Nokia C5 Cell Phone
Nokia c5-00 just vibrate when turned on...
When turning off/on the nokia c5-00 just vibrate and does not open or does not work at all... its because after updating software version via N.S U
Nokia c5- only vibrate* not turn on !
Posted on Sep 07, 2012
Just my phone is ok.but when i do language change.after phone was switch off and not on.only vibrate mote.plz give me solution.
Posted on Jan 29, 2014
  • 22 Answers
Your phone is dead .. you can not solve it by your own.. have to go Nokia customer care
Posted on Sep 22, 2012
lexzy80
  • 943 Answers
SOURCE: I am using a Nokia
This is a very common issue with nokia phones. It occurs mainly when you have stored a particular number with more than one name.
For example if you have a number stored to your sim using one name and you have it stored to your phone memory with another name. In most cases, when you install a new SIM card to a nokia phone, it might copy the contacts from the SIM memory to the phone memory automatically and add some extra information or edit the name automatically. This can cause a conflict between which name the phone should display when any action associated with the number is to be performed. In this case, it displays just the number.
To solve this problem without having to delete any contact, all you need to do is to go to your contact settings and then select which memory should be the default display memory.
Hope this helps you? Please comment for more information and thank you for using FixYa.
Posted on Apr 03, 2011
  • 75 Answers
SOURCE: i want to latest update for my nokia 7610 phone software
Dear u can find the latest firmware update available for ur phone at the nokia.com/softwareupdate.You can update if any update is available via NOKIA SOFTWARE UPDATER.
Posted on Dec 07, 2009
SOURCE: nokia 6300 vibrator not working
where is the solution displayed.
my phone does not vibrate when rings.
Posted on Jan 07, 2011
SOURCE: i want to update my nokia 7610 phone software
power supply is actual but display not show anything & out going is not working .
Posted on Jul 08, 2011
SOURCE: i want registeration code for
i want registration code of nokia boldbeast call recorder for nokia x6. IMEI is 353422046742465
Posted on Dec 15, 2011
How to format E72 that won't charge in either nokia charger nor USB cable. But once it open it only vibrate then NOKIA sign appears and yet it won't open. please HELP ! thank you !
For Hard Reset:
This also restore your Nokia when it frezzes at the nokia screen logo only and didn't go any further.
hard reset is an options but will result to loosing all settings, contacts, data etc...
Turn your phone off and simultaneously press these four buttons circled in red.
* * (asterisk key)
* 3 (numeric 3 key)
* CALL / GREEN key
* On button
This is another method below found out by trial and error when the * + 3 + Call didnt work.
Switch your phone off.
Then, lay it down on a flat surface
With 3 finger of one hand, keep pressed shift, space bar and back space all at the same time
With one finger of the other hand, press the power on button
Do not release neither the 3 keys nor the power key till you see the nokia shakehands animation.
Jun 23, 2012 | Nokia E72 Smartphone
How do I turn vibrate on nokia 6700 slide. Don't want silent, want it to vibrate when working on set
ok first go to profiles aqnd in that general open it go for personalise in that check for vibrating alert make it on .....come back and above personalise you can see activate activate it and use.
Sep 23, 2011 | Nokia 6700 Slide Cell Phone
How can i enable vibration on my nokia e 52?
Go to Menu/Control Panel/Settings/General/Personalisation/Tones/
go down to Vibrating alert.
Turn it on. Vibrating turned on.
Mar 05, 2011 | Nokia E52 Smartphone
My nokia 6303 wont vibrate its turned on but dont work.please help
check out the profile settings and check the currently enabled profile that vibration alert is turned on or not.If alert is on then ur phone's motor or the ******** is damaged, take it to repair center.
Apr 04, 2010 | Nokia 6303 Cell Phone
My phone vibration is not working
I have problem with vibration of NOKIA E71, even I turn on the ******** still is not working, any advice? shall i restart or take to nokia service?? any idea...
Sep 19, 2009 | Nokia E71 Smartphone
My Nokia 5800 will not turn on. It only vibrates.
  1. With your 5800 turned off,
  2. Press and hold [Green] + [Red] + [Camera] Keys
  3. Turn phone ON, and keep pressing it until you see the Nokia Shaking Hands Logo.
The phone will be factory reset. If asked, default code is 12345. My phone did not ask- only the normal SIM PIN.
Jun 10, 2009 | Nokia 5800 XpressMusic Smartphone
Nokia 6110 nav was dropped wont turn on.....
The cell is still working but display of mobile has crashed u have to replace the same
Feb 27, 2009 | Nokia 6600
My Nokia N70 fell in water i removed it's battery and dried it quickly but now when i opened it. It is just showing white screen. Nothing else is visible no sound no vibration no display. i cannot turn it...
take a hair dryer and dry the phone till u feel it completly dried off may be then it will work as same problem was with my 6300 phone and its still working
Dec 16, 2008 | Nokia N70 Cellular Phone
Back Light
First, check that the something is actually displayed :
Turn off the phone then put it on charge.
Check to see if the NOKIA logo appears even if the display is unlit. (try angling the display towards a sunlit window).
Having charged it, try to turn it on.. Do you detect the vibration the phone makes when starting up?
If nothing is displayed but you get that vibration I suspect that the display is somehow damaged and you'll need to look at replacement.
You local nokia centre should be able to provide you with a quote for the repairwork otherwise if you're confident opening it you might be able to replace the screen with one obtained from here for example:
http://www.accessorylink.co.uk/search.asp?Action=search&Keywords=N95
Aug 26, 2008 | Nokia N95 Cellular Phone
VIBRATING ALERT DOESNT WORK
Open the unit and clean the contact on the vibra and check the vibra to see if its stil ok. Use an eraser to clean the contact.
Jul 24, 2006 | Nokia 3220
Nokia C5 Cell Phone Logo
963 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
