Question about Humidifiers
Wiring diagrams for franna at15
Emrgency steering and air conditioning not operating
Just stopped working. Tested switch,all contacts have power, capacitor is good. Need a wiring diagram so I can open motor and see what's wrong. Had very little use in ten years.
Can't help you, but I've read they have as high as a 20% burn out rate. Most report failure if they operate with the window screen on (creates too much airflow restriction) and most failures are with the capacitor. Other than that, you need to contact the company and try to get it replaced under warranty.
If you need to replace the motor, you can call the parts department at 800-233-0268 (M-F 8 to 4 EST.)
Mar 22, 2016 | Air King 9166 20" Wholehouse Window Fan
What does a E2 mode mean how do I reset?
The '2' in E2 seems to refer to list of conditions under 'Troubleshooting' in the user manual for this product. The version of the manual that I have found claims that in this condition the problem is: "The amount of heated air exiting the front of the portable heater is reduced."
The solution is to: "Check the electrostatic filter to make sure it is free of dust and dirt. Also check the front grill and rear air intake to make sure it is not being blocked by any kind of debris."by BillBell
below is a few links and the last one is sun heat where you can contact them. press the helpful button,
http://www.qcsupply.com/media/pdf/20451_IOM.pdf
Sunheat SH1500 Space Heater Parts
Welcome to SUNHEAT INTERNATIONAL Family Owned and Operated Since 1954
Feb 02, 2016 | Sunheat SH-1500 Electronic Infrared Zone...
Here is all the info I found Ser # 50908272 Holmes Humidifier HM-300
It depends on how humid it is in the conditioned space, how well sealed the conditioned room is, and how high you have the humidifier set. If you have low humidity in your conditioned space and you are asking for a higher humidity number, it could go through quite a bit of water. If your room is not sealed well, it will allow lower conditioned air into the room and put a larger demand on the humidifier
Jan 21, 2018 | Humidifiers
What is the differnce between a Humidistat and a Dehumidistat and will they both operate to get rid of humidity with the ducted air conditioning system?
Hello, a humidistat is a control used to adjust the amount of humidity you prefer. A demumidistat is the exact opposite and is used with a dehumidifier
Apr 08, 2012 | Humidifiers
I have an Aprilaire 550 model. I just noticed that it is not turning off when the furnace turns off. Please advise
The solenoid vlave is stuck in the on position and will need to be replaced...
Here is a tip that wrote about how to buy heating and air conditioning parts online.
How to find Air Conditioning, Heating and Furnace parts online.
heatman101
Dec 25, 2010 | Aprilaire Humidifiers
Not working
HI, Troubleshooting an Aprilaire Humidifier
Aprilaire, a manufacturer of indoor air quality products including thermostats, air cleaners and dehumidifiers, also offers a line of whole house humidifiers. Installed in your existing heating and cooling system, humidity is produced by a supplied water source that flows over a water panel before being distributed throughout your air through the heating and cooling system. Issues you may need to troubleshoot with your Aprilaire humidifier include error messages and the unit producing too little or too much humidity.
Things You'll Need:
Replacement water panel
Turn down the control dial by one setting if condensation appears on your windows or walls.
Turn up the control dial by one setting if there is a lack of humidity, often indicated by dry skin or peeling wallpaper or paint.
Turn the control dial to "Test/Reset" if the humidifier does not run. Verify the heating and air conditioning unit blower is operating. If the heating and air conditioning unit is not operating or you are unable to resolve the issue contact a heating contractor.
Contact a heating contractor if you turn the control dial to "Off" and the humidifier continues to run.
Contact your Aprilaire dealer (see Resources) if you notice an error code on the display and the "Call Dealer for Service" light flashes.
Turn the control dial to "Off" and turn off the water supply if the yellow "Change Water Panel" light flashes. Lift the front panel off of the humidifier. Slide out the water panel. Insert a new water panel. Replace the front cover. Turn the control dial to "Test/Reset" until the "Humidifier On" light flashes. If you feel uncomfortable changing the water panel, contact a heating contractor.
Tips & Warnings
Purchase replacement water panels through your Aprilaire dealer or a heating contractor.
You can get parts from the link below:
arnoldservice.com/humidifier_parts.htm
Hope it helps.
Thanks for using fixya....
Nov 17, 2010 | Aprilaire 700 Humidifier
FROM A CONDO IN FL WITH HEAT PUMP---I HAVE A WHITE-ROGERS THERMOSTAT (2 STAGE HEAT-1 COOL) AND WANT TO WIRE IN A HONEYWELL H46C HUMIDISTAT FOR HUMIDITY CONTROL. THERMOSTAT HAS THE FOLLOWING WIRE POSTS E O...
It's a little unusual to add a humidifier in Florida. The ambient humidity is usually high enough.
But anyway, if you want to do this and assuming you have central air with forced air heating, you could install the humdifier in a standard configuration, then use a sail switch or differential pressure switch in the supply air duct to turn the humidifier off or on when you are in the heating mode only. The sail or differential switch will ensure that the unit can't run unless air is moving and you can tie the humidistat in to the first heat stage.
Mar 05, 2010 | Honeywell Power Humidifier: Furnace...
Connecting an Aprilaire 700M to my HVAC system. I do not have the wiring diagram for the fan control board for the HVAC system. Aprilaire diagram says to wire the 120VAC to 24 VDC transformer to the HVAC...
If you don't have a volt meter, purchase one. I've seen them as low as $20.00 at Sears and even lower at Home Depot and other discount stores. The HUM terminals are most likely low voltage (24v). The "N" is the neutral. Assuming you have confirmed this is low voltage (24v, you will use HUM and "N" terminals. This control sequence is typically to allow for operation of your humidifier only when there is a call for your fan to run. The brown wires coming from your Humidifier are your low voltage circuit. One should be directly wired to "N". The other should be ran to your humidistat. The other side of the switch of your humidistat should be wired to the HUM terminal.
I hope you will find this helpful. Good Luck!!!!
Feb 06, 2010 | Aprilaire 700 Humidifier
Aprilaire 700 Humidifier Doesn't work
check this website for a wiring diaghram Aprilaire 700 Repair Parts & Supplies
http://www.arnoldservice.com/Aprilaire_700_repair_parts_supplies.htm
Dec 07, 2008 | Aprilaire 700 Humidifier
Model 760 Humidifier - need wireing diagram please....
I logged on to the April Aire website and found the wire diagram i needed.
they have really good information on all their units. thanks.sc.
Aug 18, 2008 | Aprilaire 700 Humidifier
Humidifiers Logo
62 people viewed this question
Top Humidifiers Experts
Paul Carew
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
