Question about Beko Washing Machines
My washing mashine wash's but wont go in for a full spin help me
jonniewalker
  • 1031 Answers
SOURCE: washing mashine
If there is a drain issue, sometimes there is an obvious solution. Check the drain hose for any kinks, as well as checking any lint filters in or on the drain hose. Is there a lint sock on the end that's full? Perhaps the drain line itself is plugged. You will want to make sure that the house drain system is not backed up or plugged. Always make sure that the washer drain hose is above the level of water in the drain tub. Some Whirlpool/Kenmore washers make use of a side-check valve near the tub outlet which may get clogged. A standpipe should be at least 1 1/4 inches in diameter, and never seal a drain hose into a standpipe. This can lead to back-siphoning. You also want to make sure that the standpipe is less than 96 inches in height. Pump problems show various symptoms. Sometimes the pump will lock up and seize. If the motor is running, it will continue to try to turn the pump. In the case of belt-driven pumps, the belt may break or burn through. The pulley may shear off. If there is enough tension on the belt, and the motor continues to try to turn it, you may wind up with a seized motor as well. The pump itself may have seized bearings, be jammed by clothing or another object; or the impeller blades may be broken off. The usual fix is to replace the pump.
If you think your pump may be jammed, drain out your tub and remove the hoses. Look inside the hoses and see if there are any obstructions. Feel around inside the pump inlets for anything that may be jamming the pump itself. You can also use long-nosed pliers to feel around inside the pump for any items that may be causing a jam. If you haven't found a jam, and you still believe there may be a jam in the pump, you can completely remove the pump from the washer and inspect it more closely.
Occasionally, transmission gears may become worn, or some other internal part may go bad. Some older washer models have an electric-mechanical shifter. If it won't shift, it's best to call a professional appliance repair person to address this issue. If your transmission is leaking oil, there are really only two options at this point, either run it until it dies completely, or replace it now.
Posted on Sep 27, 2008
SOURCE: Candy CN146
does it spin? It could be the coupler. What type is it?
Posted on Nov 01, 2006
  • 209 Answers
SOURCE: hotpoint aquarious wf620
funny my machine does the same, i have had 2 answers one says to hold both the on off button and start button till it comes out of test mode? well something like that, (didn't work) and another tells me its just the board thats faulty, I do believe myself this can be reset by the right test equipment from Hotpoint (Hotpoint not helpful and i have a Hotpoint engineer as a neighbour), its also most embarrassing as i am a recently retired appliance engineer myself of 20 years, i have also been told its a conspiracy to get an engineer to call out to reset it and charge for doing so (being a computer control machine (not sure myself, these things don't happen - do they) Ps if you get told a cure and it works tell me please
Posted on Sep 19, 2007
  • 20 Answers
SOURCE: Vibration of the wash mashine
How old is the machine? Have transit bolts been removed? Older machine is possible bearing failure or spider breakage( a 1 in 10 wash with a temperature of 95 degrees celcius will extend life of a front loader!- an empty wash or towels or sheets at this temperature). A grinding noise can simply be a worn drive belt, rotating drum by hand and finding grinding and lateral movement equals bearing/spider failure. Also a simple case of Underlaoding the machine will cause unbalanced load and vibration.
Posted on May 23, 2009
barkencoa
  • 3463 Answers
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Posted on Jan 19, 2010
My washing machine is washing but is not going to fast spin and water is still there my mashine is service 600
The reason is that the machine is unable to get rid of the water within it. Until this leve goes down, it will not go into "full spin" mode. Suggest that you check the machines filter (with some towels handy!) or for a kink in the discharge pipe.
Jun 09, 2014 | Washing Machines
Washing machine wont spin
Sounds like the belt either broke or jumped off the pulley. should be a simple fix from the back access.
Feb 25, 2013 | Bosch Washing Machines
My new omega washing mashine shows an E2 error code 5 miniutes into the wash how do I fix this?
Manufactured by omega washing mashine have an electronic controlpanel that must be unlocked in order to set or make changes to your washingcycle.
E2 indicates a water leak. When a leak occurs, it trips thefloat device by dumping water into the dishwasher's base. The incoming watervalve will be switched off, and the drain pump will turn on until the sump isempty
However, if an error light is blinking on your dishwasher'scontrol panel, the panel must be reset before you can gain access. Blinkinglights on your washer control panel may signal a mechanical problem that needsto be repaired. If the lights continue to blink after you've reset the controlpanel, contact Sears to service omega washing mashine or considertroubleshooting the appliance yourself carefully.Instructions
1 Press and hold the "Heated Dry" button onyour omega washing mashine for four seconds to unlock the dishwasher controlpanel.
2 Press the "Heated Dry," "Normal Wash,""Heated Dry" and "Normal Wash" buttons one after theother, in fairly quick succession.
3 Wait for the washer to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the endof the diagnostic test cycle. This should reset the control panel on your omegawashing mashine. Thankfor using fixya.
Jul 30, 2011 | Washing Machines
My hotpoint wf 000 will wash but wont rinse or spin any suggestions please
you need to check/clear filter, its located within sump hose @ bottom of drum quite trickey clip to remove slide it to the side to assist then withdraw nylon filter and clear....
May 05, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Not spinning when on Regular wash mode.
sounds like the agitator is damaged and needs to be replaced
Jun 21, 2009 | Washing Machines
Performa spinning banging problem
I assume it is not balanced. Try putting sponges under the feet of the washer.
Jan 06, 2009 | Washing Machines
Maytag neptune
When the door lock fails, there is a part on the electronic control board that fails (resistor burns up). Both will have to be replaced.
Jun 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing mashine repair
Plug off the wall. Clean out your outlet filter. Access is a door in the front bottom of your machine, be prepared for some water to come out. Refit.
Sep 17, 2007 | Washing Machines
Washing Machines Logo
62 people viewed this question
Top Beko Washing Machines Experts
micky dee
janman
Domenico Grillo
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
