Question about Gateway Mediatrix 2102 Dual FXS VoIP Phone
Mediatrix 2102 All my calls are ended after 31 mins, what is causing this to take place?
I have my phone connected to a mediatrix 2102 ata which is connected to my netgear hub. Iristel my phone provider says the problem is not with the 2102, but maybe the registration time in the 2102 is the problem ?
    Genius:
  • Gateway Master
  • 1,274 Answers
Well i'm no expert on this device, but here's the manual http://www.euteliavoip.com/download/original_manuals/MTX_2102_SIP_Reference_v5-0_Rev06.pdf if you can't figure it out, i suggest calling the manufacturer's tech support as this sounds like a very specific hardware question
Posted on Feb 10, 2012
2102 setup
The phones aren't on the system. You have to make sure to turn on "Auto Discover Telephones" under the system settings, system configuration tab within "tab to it" (on 5.0 and older software) and System wide settings, auto discovery with newer software. If the phones are plugged into the same network as the phone system, the phones will automatically come up with extensions.
Feb 04, 2013 | 3Com NBX 2102 IP Phone
My desktop has a local area connection with limited to no connectivity. I had my desktop pc connected to a netgear n900 router and a vonage phone connected to the router's lan1 port. This caused i
Did this connection ever work before? I have a similar setup with Iristel and once in a while it goes down (Hurricane Leslie generated the problem last week).
Check whether the setup works without the Vonage device. This will tell you whether the problem is with your router or the Vonage box. If it works without the Vonage, the problem is in the Vonage box, you may find a good time to call Vonage for support.
I don't know whether the Vonage box (in my Iristel case it's a mediatrix 2 something) has to 'call home' before it lets your router set itself up.
If your router does not work without the Vonage, you have a simpler problem, the router is the issue. You can reconnect the Vonage and if the phones work, this confirms that the router is the problem. At least you can use the phones.
With the router, you need to log in to the admin screens and poke around until you find the problem. It is always a good idea to only change one thing at a time and always remember what changed immediately before the problem was noticed.
Sep 16, 2012 | Gateway Computers & Internet
Can't make outgoing calls on cordless phone. Yet can receive calls just fine, when I call out, I get a message saying my balance is zero or a busy/hung up signal. This has been an issue since we...
Once the internet is switched on to a phone line, interference can become a big problem and a DSL filter is necessary at every socket where a phone is plugged in.
Some older equipment may cease working altogether even with a filter.
There is a limit to how much stuff can be connected to a single line and overdoing it is asking for trouble. Long and complex cable runs are also potential trouble increasers.
When there is a problem it is well to disconnect everything and start again. Connect the phone first and if that works ok reconnect the rest one at a time until the trouble recurs and if it does, stop there and do without any more...
If the phone doesn't work straight into the master socket even with a filter, there is probably a fault somewhere on the line...
Mar 06, 2017 | Linksys SPA-2102 NA Analog VoIP Adapter...
Sometimes my Linksys SPA-2102 NA does not generate "Ring back" (when calling my number a caller cannot hear ring back while my phone is rinning). Could you help?
You may need to reset your device and you will see a reset button at back of your router so all you need is to keep holding it for 10 seconds then unplug the power jack for like 1 min and then your device shall be reset.But please make sure to backup your all settings first. Cheerz
Mar 30, 2011 | Linksys SPA-2102 NA Analog VoIP Adapter...
All the lights on my voip blink and i can connect to net but my phone instrument dosent have a dail tone
the reason you do not have a dial tone ther is two reasons that could cause this either your internet is not connected to the adapter correctly or the device is de regiestered
Oct 07, 2009 | Linksys SPA-2102 NA Analog VoIP Adapter...
Phone lines shuts down
Sounds like you need a service tech to check your connection out there. VOIP hates latency and if it detects it, it will shut down.
You can go to PingPlotter.com and they will show you have to check if you have a good internet connection.
Aug 21, 2017 | Linksys SPA-2102 NA Analog VoIP Adapter...
Polycom IP501 and SPA2102 Router
If you know how eo access your configuration control panel then assign a Static IP address or place that assigned address on the other side of the firewall (DMZ). Steve Medley
Nov 01, 2008 | Polycom Computers & Internet
3com 2102 IP phone
You cannot program a key with an assigned function like tranfer call or conference call, only with the basic button keys can you program it like Key 0 and Key 1.
Aug 15, 2007 | 3Com NBX 2102 IP Phone
93 people viewed this question
Top Gateway Audio Players & Recorders Experts
Kolbrun...
richie46
Raj Patel
Are you a Gateway Audio Player and Recorder Expert? Answer questions, earn points and help others
