PACE MSS 1000
I AM JUST ABOUT TO GET MY OLD PACE MSS 1000 WIRED TO RUN AGAIN AND WOULD LIKE HELP WITH THE WIRING INSTRUCTIONS FROM THE DISH AND MAINS ETS TO GIVE TO MY ELECTRICIAN
mANY THANKS
  • MPHAKEY Oct 25, 2008
    Sorry, I forgot to mention that it was a motorised dish
  • 417 Answers
You will need a low loss co-axial av cable from the dish lnb tp the receiver (normal centre core and braided outer) . The electrical supply is normally by plug-in to a domestic outlet, 13 amps 240v in the UK
Posted on Oct 23, 2008
Find a clear wiring diagram of the motor conections
Go online and do a google search for the model and see if you can get info on it also call the manufacture to see if they will give you tech support on it also check the machine there is usely a diagram on the machine showing the wiring of unit.
Mar 03, 2015 | Hobart Dishwasher Am-14 Commercial Dish...
How to wire slave pir to a master unit touch swtich on a stairwell with two-way switches
sounds like two way switching , 2 switches wired parrell 1 to 1 2to 2 3 to 3
power 2 and 3 , but seek professional advice if using mains
Jul 19, 2014 | Elkay Computers & Internet
Timer wiring
there should be some schematic on the new timer , if you can send it can help to understand how to configure/ or at least the brand and model for the timer can help.
Sep 30, 2017 | Hardware & Accessories
We have a Sole treadmill F85 purchased about 3 years ago with lifetime warranty. When my son would do speed workouts (he is a large kid, about 215 lbs), the machine would shut off after running a 5-minute...
DEAR
THIS MODEL IS WEAK FOR HIGH WEIGHT PERSON AND YOUR ROOM IS NOT YOUR PROBLEM BUT YOUR TREADMILL CHOOSE IS YOUR PROBLEM .
you can countiue contact us with smart phone on wattsapp or telegram by :
+989195116738
Mar 15, 2017 | Exercise & Fitness
It just stopped working. It finished the last load. But new when the disk is turned nothing happens. I don't know where to begin with troubleshooting. I flipped the breaker but that didn't help. Any...
Some dish washers fail because of a sticking float switch, Iwould disconnect from mains, give it a good rock to move the float switch , and try again, had this on my dishwasher, cured problem,
(worth a go)
pete
Nov 17, 2010 | Dishwashers
Output of amplifier gives wired noises no Bass
check how your wires are run from the radio to the amp try to split them up and see if the noise still comes. buy some new rcas this will help with noise. make sure you have tru connections
Mar 10, 2010 | Jl Audio 1000/1 Car Audio Amplifier
Cannot reset or access configuration page.
The PC will detect a closed loop within the Network cable so forget that. Sorry but the router is bad if you cannot access it and the reset button does not help.
Have to get another 1
Nov 11, 2008 | D-Link AirPlus DI-524 Wireless Router
Pace i.3.33
get a multimeter and connect the black probe to the metal part of the closed box, connect the red probe to the middle pin hole of the sattalite input connector and tune into a channel
You shold be getting around 13v +/- 2v
OR
+18v +/- 2v
If you are not getting this your tuner has failed.
Jun 07, 2008 | Pace Type 30-0060 1121-0369 D1 .060 D2...
Missing fitting instructions
I just hardwired it into my vehicle, I use it for both road and water, I goggled garmin 276c wiring and I located the schematic. Unfortunately I cannot locate my printed hardcopy now. Give it a shot.
Apr 23, 2008 | Garmin GPSMAP 276C GPS Receiver
230 people viewed this question
 Grubhead
Grubhead
