Question about Home Security
WIRING DIAGRAM FOR CAMERA TO TV MODEL NO. XC16A
WIRES NOT CONNECTED INSIDE OF CAMERA, I HAVE RED YELLOW VIDIO AND AUDIO HOOK UPS, AND POWER ADAPTER PLUG IN.
szanti
  • 36 Answers
SOURCE: Security Camera
it is important to know model and make or camera if you want a solution
Posted on Nov 29, 2009
  • 9 Answers
SOURCE: micromark wiring diagram
hi have the same issue found it to be red power black negative yellow video white audio and bare wire is the shared ground for the yellow and white hope this helps
Posted on Jun 05, 2010
  • 9 Answers
SOURCE: RIPD CAMERA WIRES!!!
you need power to the red and black, white to a rc plug center pin yellow to the center pin of a rc plug and there should be a bare wire you need to split it off to the outside section of the yellow and white rc plug
  • 3197 Answers
SOURCE: I need a wiring diagram to hook up the wires on my
From the wall control there are 2 wires. One with a red stripe goes to terminal #1. One solid white goes to terminal #2. From the door sensors the solid white wires go to terminal #2 and the 2 wires with black stripes go to terminal #3.
Posted on Sep 04, 2010
  • 3197 Answers
SOURCE: I need a wiring diagram for a Chamberlain
I would suggest you call around the Chamberlain dealers in the yellow pages. They may have something you can use.
How do you connect a ps2 to the led24916dvdfhd
Well the LCD or TV must have rca..jacks yellow video..red and white is audio..if not u can get a component jack wires for PS2..red.blue..green...video....red and white audio..the TV must have those connections ..for PS2..or get old school cable connected hook ups for PS2..hooks in cable or antenna connecter on TV..UHF connected for ps2
Jul 21, 2014 | Video Game Consoles & Games
Where could i fond the wiring diagram for my Kenwood Excelon KDC-X592 Car CD/ MP3 Player?
There are vehicle - specific adapter plugs for after market radio hook ups. These adapters are used to connect the original plug that was connected to the original radio with the new radio's plug.
You didn't list what vehicle you have, year, model. You can do a web search with " (year and model of vehicle) radio wiring adapter".
Hopefully you'll find the adapter for your vehicle.
May 28, 2014 | Kenwood Excelon KDC-X592 Car CD/ MP3...
I trying to connect my SFC-4160 (security first color ccd camera) the wiring has been cut n there is 5 wires black,red,yellow,white and a bare wire ???? help
Inside the camera is a 4 pin connector connected to the LED Board, with the connector in hand, turn it till you see the pins inside the connector, from left to right wires 1st-white, 2nd-black, 3rd- bare wire or shield, 4th-red, yellow is not connected, the RJ45 end, face the latch away from you, wires are 1st-red, 2nd-white, 3rd-yellow, 4th-shield(bare wire), 5th-black, the LED Board has the wire positioning marked,,,,,
Nov 27, 2012 | Car Audio & Video
HOOK UP VIDIO SURVALENCE CAMERA TO BACK OF TV
The camera output would have to be composite---and if so go to one of the rear audio/video inputs: yellow (composite video) is likely all you would need unless the camera has audio as well (go to red or white on same input).
Jun 02, 2012 | Hitachi 43UWX10B 43" Rear Projection...
I WANT TO KNOW HOW TO CONNECT MY PANASONIC MODEL SC-HT830V HOME THEATER SOUND SYSTEM TO A SHARP AQUOS MODEL LC-37D62U TELEVISION I NEED A WIRING DIAGRAM
U do not need a diagram-simply hook up red/white wires from audio output of sharp tv to audio input(tv) of panasonic unit.any questions contact us- djstvrepair@comcast.net
Sep 10, 2009 | Televison & Video
Unmarked wires
your jvc is pretty standard on hook ups.red wire is on a keyed power wire,black is chasis ground, blue is remote wire to amp.yellow also keyed power wire.speaker wires there will be 8,usually whit violet so on. white solid for exzamle is + white with black stripe is - you can figure out front and rear with an old speaker and buy fading front to rear on your head unit youll know front and rears.same for left and right.did you look on the unit usually the have the wiring diagram on the unit itself.mine all do
Jun 21, 2009 | JVC KD-S580 CD Player
4-wire surveillance camera wiring diagram
Cut wires Blue whight yellow orange wires go to what on a security camera
Jun 20, 2009 | Home Security
Hook it up to the tv
If your hooking it directly to the tv depending on how old the tv is use one of the inputs. Hook the two red and white to red and white and the yellow to the video in input. If it's an older tv you will need whats called an rhf adapter. Hook your color codes together and use a cable cord to go from the antenna out to the tv's uhf input. I hope this information was helpful........... : )
May 10, 2009 | Televison & Video
Sony cdxm610
Red- Constant Power -
Yellow - Ignition power - 12v
Black - Ground
Blue - Ant & memory
Orange - Dimmer
All the wires that have 2 of the same color are speaker wires
ex - green, and green with stripe. The one with a stripe is the Negitive
In most cases the red and yellow need to be together to get the cd player to start if you dont have 2 hook ups for both constant and ignition powers.
The black ground can go to any bolt that is screwed into a metal grounded object. The blue and orange are not needed unless you have a harness that supports the dimmer and memory feature.
If you cd player works with this but wont keep settings or time, hook up the blue to the power so it can constantly save your settings.
All the speaker wires a total of 4 diffrent sets of 2 can go anywhere as long as you dont want to fade or bal your speakers if so you need to test them by hooking up 1 speaker at a time to find out where it leads to. GOOD LUCK
And
Thank you for your question
Aug 04, 2008 | Sony CDX-M610 CD Player
Need to watch recording on tv
If your camera has audio vidio cable (just get a cheap one which has a yellow, red and white connector) connectors. simply plug them in the audio vidio out on camera and audio vidio in on TV and thats it.
Let me know what type of connectors you have on your camera?
THanks
Dec 07, 2007 | Sony Handycam CCD-TRV107E Camcorder
Home Security Logo
96 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
