Question about Compaq Computers & Internet
BIOS clean up
System is running slowly need instructions on cleaning the BIOS
  • 807 Answers
You dont clean the Bios, you can reset it to the defaults or you can usually update it, but thats not recommended unless it needs a critical update, so many people have tried it with bad results, like the pc not starting up after an update, but it is highly unlikely that anything has changed in there so I would leave it and concentrate on the actual computer hard drive.
You can clean you hard drive if you right click on the C: drive icon in My Computer. Then click on Properties, then click Disk Cleanup. There is also on option to clean all but the latest restore point, that saves a lot of hard drive space.
You can also defragment your hard drive which sorts all the files out so that when a file is accessed it finds all of it at once, instead of finding fragments and putting them all together. Files are not usually stored all in one but are spread around the drive, taking longer to find the fragmented bits. It also consolidates all the free space for faster writing to the drive.
You can also go in to MSCONFIG and click the Startup tab and see what programs are running. Anything in there automatically starts running as soon as Windows starts. You can dissable the ones that you know don't need to be running. Not things like Antivirus, Firewall or anything to do with Internet though.
Go to the start menu and type msconfig in the search / run box and press Enter. When you have unticked the ones you dont want running restart the computer.
You will probably get a box pop up when you have restarted saying that you have been in to the configuration settings etc. Just tick the little box on the left that says Don't show this again or whatever it says.
You could also uninstall any programs that you don't actually use.
Go to the Control panel and click on Add and Remove Programs for Windows XP, or Programs and Features in Windows 7.
If it's just got slow gradually,cleaning up usually helps a bit.
If you just want it to be a bit faster then maybe it can have more Ram fitted on the motherboard, that helps, also upgrading the processor, and a faster hard drive will help.
You can also use a little program called CCleaner whhich searches the hard drive for all the rubbish left over from uninstalled programs, unused files, temporary files that are no longer needed etc. It's a free program and very popular.
You can also clean the registry which gets rid of a lot of rubbish left in there. There is an option in CCleaner whhich will do that.
Hope this helps.
Posted on Feb 10, 2012
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
http://hoover.com/file/604/
Hope this was helpful!
Jun 19, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Tip
FLASHING BIOS - THE PROCEDURE
BIOS Update Procedure
All latest Motherboards today,ensure that upgrades are easily obtained by incorporating the system BIOS in a FLASH Memory component. With
FLASH BIOS, there is no need to replace an EPROM component. Once downloaded, the upgrade utility fits on a floppy disc allowing the user to save, verify and update the system BIOS. A hard drive or a network drive can also be used to run the newer upgrade utilities. However, memory managers can not be installed while upgrading.
Most pre-Pentium motherboards do not have a Flash BIOS. The following instructions therefore do not apply to these boards. If your motherboard does not have a Flash BIOS (EEPROM) you will need to use an EPROM programmer to re-program the BIOS chip. See your dealer for more information about
this.
Please read the following instructions in full before starting a Flash BIOS upgrade:
A. Create a Bootable Floppy (in DOS)
•With a non-formatted disk, type the following:
format a:/s
•If using a formatted disk, type:
sys a:
This procedure will ensure a clean boot when you
are flashing the new BIOS.
B. Download the BIOS file
•Download the correct BIOS file by clicking on
the file name of the BIOS file you wish to download.
•Save the BIOS file and the Flash Utility file in the boot disk you have created. Unzip the BIOS file and the flash utility file. If you don't have an "unzip" utility, download the WinZip from www.winzip.com or www.pkware.com. Most CD ROMs found in computer magazines, have a shareware version of WinZip on them.
•You should have extracted two files:
Flash BIOS utility eg: flash7265.exe (for example)
BIOS eg: 6152J900.bin (example)
Use the latest flash utility available unless otherwise specified (either on the BIOS update page or in the archive file). This information is usually provided.
C. Upgrade the System BIOS
During boot up, write down the old BIOS version because you will need to use it for the BIOS backup file name.Place the bootable floppy disk containing the BIOS file and the Flash Utility in drive a, and reboot the system in MS-DOS, preferably Version 6.22
•At the A:> prompt, type the corresponding Flash
BIOS utility and the BIOS file with its extension.
For example:
flash625 615j900.bin
•From the Flash Memory Writer menu, select "Y" to
"Do you want to save BIOS?" if you want to save (back up) your current BIOS (strongly recommended), then type the name of your current BIOS and its extension after FILE NAME TO SAVE:
eg: a:\613J900.bin
Alternatively select "N" if you don't want to save your current BIOS. Beware, though, that you won't be able to recover from a possible failure.
•Select "Y" to "Are you sure to program?"
•Wait until it displays "Message: Power Off or
Reset the system"
Once the BIOS has been successfully loaded, remove the floppy disk and reboot the system. If you write to BIOS but cannot complete theprocedure, do not switch off, because the computer will not be able to boo, and you will not be given another chance to flash. In this case leave your system on until you resolve the problem (flashing BIOS with old file is a possible solution, provided you've made a backup before)
Make sure the new BIOS version has been loaded properly by taking note of the BIOS identifier as the system is rebooting.
For AMI BIOS
Once the BIOS has been successfully loaded, remove the floppy disk and reboot the system holding the "END" key prior to power on until you enter CMOS setup. If you do not do this the first time booting up after upgrading the BIOS, the system will hang.
BIOS Update Tips
Note:
1.Make sure never to turn off or reset your computer during the flash process. This will corrupt the BIOS data. We also recommend that you make a copy of your current BIOS on the bootable floppy so you can reflash it if you need to.
(This option is not available when flashing an AMI BIOS).
2. If you have problems installing your new BIOS please check the following:
Have you done a clean boot?
In other words, did you follow the above procedure for making a bootable floppy? This ensures that when booting from "A" there are no device drivers on the diskette. Failing to do a clean boot is the most common cause for getting a "Memory Insufficient" error message when attempting to flash a
BIOS.If you have not used a bootable floppy, insure a clean boot either
a) pressing F5 during bootup
b) by removing all device drivers on the CONFIG.SYS including the HIMEM.SYS. Do this by
using the EDIT command.
Have you booted up under DOS?
Booting in Windows is another common cause for getting a "Memory Insufficient" error message when attempting to flash a BIOS. Make sure to boot up to DOS with a minimum set of drivers.
Important:
Booting in DOS does not mean selecting "Restart computer in MS-DOS Mode" from Windows98/95 shutdown menu or going to Prompt mode in WindowsNT, but rather following the above
procedure (format a: /s and rebooting from a:\).Have you entered the full file name of the flash utility and the BIOS plus its extension?
Do not forget that often you will need to add a drive letter (a:\) before flashing the BIOS.
Example: when asked for file name of new BIOS file which is on your floppy disk, in case you're working from c:\ your will need to type
a:\615j900.bin, rather than 615j900.bin only.
on Dec 30, 2009 | Computers & Internet
Hp probook 4720s keeps crashing? after a period of time the fan seem to be running at full power and the bang the system cashes? any ideas?
need to clean your laptop.()it is full of dust!!!!!immediately!!!!if not, will keep crashing and die slowly...
cleaning means disassambling it and clean the fans for dust
Oct 28, 2013 | HEWLETT-PACKARD HP ProBook 4720s 173...
BIOS clean up
you can reset your BIOS to factory default. go into the BIOS setup screen and follow the instruction for the setting BIOS default. without know what BIOS you i can give correct instruction to reset your system.
Feb 10, 2012 | Mozilla Firefox
I am using Intel D845GVSR board with Genuine Intel 2.4 GHz processor accompanied with 80GB Hard disk 7200 RPM and 512MB DDR 266 MHz RAM No problem in my system for past 9 months Recently it behaved...
Software Utilities are not only the solution for a PC to run proper, you also need to clean the hardware manually and periodically, have you ever cleaned your motherboard or other components during the nine months? if not there might be lots of dust clogged on the chips of the motherboard.. Remove everything which is connected on the motherboard, clean them on by one and don't forget to clean the CPU fan as well. and reconnect everything, and see the result. You also need to clean the bios battery to make sure everything is cleaned. Good luck...
May 08, 2010 | Computers & Internet
Hello my dell 3000 is running very very slowly, pc scans tell me that I need to clean the registry, would I be better rebuilding th esystem - if so how do I do this? thanks Andy
STOP!!! there is no need to rebuild the system just because it is running slow..first- boot into safe-mode and run a reputable virus scan (there are free ones like AVG and Avast) second--there is a free program you can download and run to clean and optimize the system.. IOBIT.com--(AdvancedSystemCare)
Mar 18, 2010 | Dell Dimension 3000 PC Desktop
My laptop is slow and wont reboot
Put the Windows Op Sys CD in the drive and boot the system, Interrupt the boot process and go to the BIOS. Select the first boot up device to be the CD/DVD drive and then save the settings. Exit from BIOS and reboot the laptop. Windows should start from the CD. You will see an option to repair etc. Select the R Repair option and follow instructions. Once this has completed, and it may take some time depending on how full the HD is go to www.ashampoo.de and download the 30 day free trial application of Ashampoo and run this over your system to clean it up. Then run the defrag option in the MODULES tab - Optimise Performance Option- Defrag 3. Once completed your system will be cleaned and optimised. In order to make the performance even better - add additional RAM to the unit - you can never have too much and make sure that the HD has a minimum of 10% space remaining otherwise the laptop will slow down in operation.
Oct 13, 2009 | Computers & Internet
Inspiron 1100--fan has recently started running often & long. Computer gets very warm to the touch & runs very slowly. Shuts down randomly--during virus scans, disk clean ups, etc
sounds like the heat exchanger is clogged. Try using canned air blowing in both the air intake and exhaust to unclog the heatsink and also make sure the system has the most current BIOS version.
Sep 26, 2009 | Dell Inspiron 1100 Notebook
How to install windows xp into compaq presario cq40
compaq cq40 is one particular model from compaq which is literally designed for vista and when you want to install win xp ;it doesn't work becoz the BIOS block it;the only way out is to downgrade the system BIOS which is a risky thing.check your bios model and version and google for a lower version and download it and flash the ealier BIOS.gooogle more on How to downgrade BIOS
Sep 21, 2009 | HP Compaq Presario CQ50Z-AMD Sempron(TM)...
My oven flased an F9 error....
The solution to this issue is to finish running the self cleaning feature to this oven, Shutting off the oven or opening the door before the self cleaning feature has completely run will send a F9 error from the safety co0ntrol unit feature built in to the system bios of the control circuit, You will need to close the oven and set the option self cleaning to run now. if your error message prevents you from taking these steps you will need to unplug the oven from the wall socket and let it sit for an hour to reset the screen and then run the self cleaning feature all the way trough, it will shut down on its own when the self cleaning cycle has completed
Oct 24, 2008 | Frigidaire FEF366 Electric Kitchen Range
Computers & Internet Logo
57 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
